@Seventynet thanks for the compliment. I went with 1 x 5 for 2nd layer. Up til this model, I've used veneers. I like the 1 x 5 better for a lot of reasons, but what I didn't count on was it shrinking. I have some hairline gaps that weren't there when originally planked. I can fix it, but I was still kinda dumbfounded by it. Oh wood is such a fickle entity.
Mikki
"You're gonna need a bigger boat."
Working on: Dusek's San Martin
Completed: Good ol' first ship build- Constructo's Albatross; Mamoli's HMS Bounty; Mamoli's Golden Hinde; Amati's Drakkar; Occre's Revenge; Artesania Latina's San Fran
Sanding is donne, so the fun has begun! Wales will border this line of decoration above and below. I'm not sure if the wales will be black or natural.
Mikki
May need another coat and a few touch ups. The other side needs another coat for certain then on to the wales. I at least got the transom attached.
Mikki
Making some progress albeit slow. I opted to keep the wales natural, so I picked the darkest walnut pieces I had. I have one more to install. Pic was taken before I installed a few more.
The piece under the holes for the windows is just a temporary level you know like when you install upper kitchen cabinets. 😁 I started on the floor of the stern galley, but I must have removed it before the pic. Oh well. It will show up eventually.
Mikki
So I think these are called "standards," but I could be wrong. Please correct me if I am. I need to rename them "the bane of my day." I struggled with these. I also didn't glue them where the paint is in case I have to tear them out (which I really can't see me doing.)
In the past, I've cut out the wale and placed them that way. Why I decided to try this method I do not know. Does anyone know why some are higher than the wales and others are flush? Just curious. I've seen it that way on many models.
Mikki
Correct
As far as I know.
These standards serve as a reinforcement of the hull.
Especially also on rear and fore castles
if you do them flush with the wales (in pieces) then they have no strength anymore, and consequently little use.
And, very nice work.
Thank you...all. I can always change the ones that are flush. I've seen the flush ones in many logs and plans. Wasn't quite sure what to do.
Mikki
Well it's been a bit, but I've made some progress. Working towards the railings so I can get to transom galley and beak.
Mikki
I must admist that the white dots gave me A LOT of trouble. They were hard to paint and outline, so I cheated on those. I painted the heads of nails. It was a clean solution.
That red/yellow combo kills me though. Reminds me of ketchup and mustard and a worldwide fast food chain that used to have red roof on the building with a giant yellow (golden) "m" (arches) on top. 🙃
I'm sure the original ship had little to no blue and white, but I'm giving a nod to the Portuguese who built her.
Mikki
