Can anyone recommend a small, hand held reciprocating (back and forth) narrow kerf saw?
I need to cut some pieces from 1/8 inch (3 mm) plywood and don't relish doing this with a coping saw or jeweler's saw. I do not have a band saw (or a place to put one) nor do I have a laser cutter.
Edited by Dr PR
Phil
Current build: USS Cape MSI-2
You might check Micro-Mark.  It's been a long time since i've visited their site but they did have some. Two types as I recall... one a single-blade and another that used two blades.
Mark,
Thanks. Dremel makes a small hand-held version that gets pretty good reviews. I'll check Micro-Mark. But that is dangerous - I might find other things I am tempted to buy!
I just checked. Micro-Mark has several options - all out of stock!
Edited by Dr PR
Phil
That's a bit of bummer, Phil.   I'm assuming supply side issues which seem to hitting at this point.   So at least you didn't dive too deep into their site.  Better for the budget.
I didn't know Dremel made one....  that's good to know
