KG, that was impressive.
Do you mind me asking which paint you were using and did you have to thin it for the pen?
It's been many years since I used my own; some would like to know that the pen is best charged with a brush.
I used just regular old craft paint for striping.  So if I messed up. It was easy to remove without any damage to the base color.
 After thinning the paint (in a spare jar) I would dip the pen in the jar to load it then wipe the outside of it on a cloth (careful not to press too hard or you might unload the pen) and then do your striping.  Using a straight edge you have to have it off the part you want to strip or you run the risk of the paint running under your straight edge.
 The trim on the coach help me with this but you could easily glue small blocks on just enough to raise it and it will help a lot.
free hand I’m not that steady anymore so some free hand stuff is a bit shaky but I got it done.
i tried Vallejo paints and for some reason I couldn’t get it to work.  I would think any paint should work just get the consistence right.  You want it to flow out smooth but not too thin to where when you start it blobs before you strip.  Hope that makes since.
 Hope this helps answer some questions you all have.  Paint pens that you can buy are a good choice to, I just have done it this way before so I knew what to expect.
it takes a steady hand to get those lines straight. thanks for the video.
edit...
i remeber as a kid taking up drafting, i bought an expensive compass kit that had that pen as an accessory. but instead of using that ruling pen, we used drafting ink  koi nor pens, they came in different widths n weights.
after seeing your video i dug through my tools and found my compass set to try the ruling pen. its one of those lost arts like fountain pens and speedball pens for caligraphy (another hobby of mine), which i still use to this day.
thanks for inspiring me. here is a basic tutorial i found online showing how to use the ruling pen. ill try it later tonight thanking you for the fun.
https://www.jeeamirza.com/blog/2020/5/27/quick-guide-how-to-use-a-ruling-pen
Edited by paul ron
Paul Ron,
When I was building my first scale horse drawn vehicle I thought how in the heck am I going to get a thin pinstripe.  I tried the drafting pen and it worked !!  Been using that trick ever since.
Give it a try, it takes some practice (on scrap painted surface) but once you get the technique down, it looks a lot better than trying to use decals, or try masking for a stripe.
Let me know how it works for you.
well since my last posting, i dug out my drafting equipment and got all the ruling pens together for a quick try.
a couple of them were cacked up with india ink. i cleaned all the pens. for my experiments i used a water based ink for calligraphy i got for the grand kids. they were metalics and opaque colors which do look great. i adjusted the pen so the tips just barely met. a dip about 1/2" and a quick wipe and pen to paper.
i really never used these although i may have for the drafting classes. so with a bit of adjustments, drawing was very nice. i got very consistant width lines and even flow. it reminded me of using a fountain pen and speedball pens with fine nibbs. it was a pleasant experiance. i think ill be using these pens more often now that I've gotten a feel for them.
KG,
Very nice striping, indeed! As a retired designer/draftsman (CAD/Board), your method of striping is quite alive in spite of all the alternative ways available today.
For those who might be interested, using a straightedge (or other drafting instrument such as French curves, etc.) as a guide - in order to keep the instrument OFF the material being painted, simply turn the straightedge over and apply masking tape along the back side of the tool. This will allow sufficient space to keep the tool off your material and as KG mentioned, not leave a paint smear. I have a whole set of drafting tools in my case which have tape applied to the underside. This works very well for doing drafting with tech. pens and scribes (and pencils!!).
Hope this helps!
Construction Underway:
Builder's Yard - USS STODDARD (DD-566) 1967-68 Configuration (Revell 1:144 FLETCHER - bashed)
In Development - T2 or T3 Fleet Oil Tanker (1:144 Scratch Build Model) - 1950s era
Currently - 3D Design/Printed 1/200 scale USS PURITAN (BM-1)
Completed:
Armed Virginia Sloop (1768)
Royal Caroline (1748)
Sloop/Ship PEACOCK (1813) (Scratchbuilt)
USS NEW JERSEY (BB-62) 1967-69 Configuration (Trumpeter 1:200 bashed MISSOURI)
3D Design/Printed various scale USN Gun Mounts/Turrets, and GFCS Directors
Member:
New Bern Ship Modeler's Guild
NRG
NCMM Beaufort -CSMA
Everything old is new again! I've been using a ruling pen for years with acrylic paint. It take a little experimentation to get the dilution 'just so', and, as Hank suggests, keep the support off the work to prevent bleed-under.
