Oops - made a big error trying to attach my new build log to my signature - Yikes - Don't know how to remove the error nor fix it. Help!!
Regards,
Under the table:
Woody Joe Higakikaisen
Completed:
Santa Maria-Mantua --
Vasa-Corel -
Hi as I mentioned I tried that -
BUT don't know how to remove the entire log as well below signature  - the log show up NOT the link at the signature. Hmmmm 😕
Under the table:
Completed:
Vasa-Corel -
Not sure how you have your signature formatted. If you have a raw html address the web site might be auto-formatting to show a snapshot of the log. If you're editing your signature, you should just be able to delete the web address (or the snapshop of the log) and then use the link formatting in the signature editor. (Give my experience editing web sites - the view of your log is being generated by the web site - it's not actually in your signature. If you "delete the log" in your signature you're likely just deleting the web address.) Try not putting the full web address, but use the "link" formatting command to add the link to some text.
Edited by palmerit
  • Solution
You cannot copy & paste your build log link directly into the signature pane. You need to type the name of your subject, then highlight the text and use the link tool as mentioned above.
Thanks
I tried several times to fix this mess - just can't -- I have a Mac does that make a difference?
I still don't know how to delete new log from signature rea. YIKES -- sorry to be a bother
Somehow - it's there in the signature area  --- the new build log.
Under the table:
Completed:
Vasa-Corel -
Go to the signature editing pane. Click and highlight everything between the red arrows. Hit 'delete'. Easy-peasy.
Thanks --- Ok half done - now need to have current build as a sentence - not the htpps: I'll try to figure that out
Under the table:
Completed:
Vasa-Corel -
