Thank you David , I appreciate it
Best Regards,
Pete
"may your sails be full of wind and the sun on your back"
Current Builds :
 Future Builds :
N.G Herreshoff 12 1/2 Scratch Build 3/4" = 1' - 0" Scale
Completed Builds :
Volvo 65 Farr Yacht Design
Herreshoff Alerion
Herreshoff Buzzards Bay 14
Volvo Open 70
 Member :
The Herreshoff Registry                                  Montgomery Sailboat Owners Group       Peter Kunst Sailboat Models
http://www.herreshoffregistry.org/                       http://www.msog.org/                      http://www.facebook.com/Peter-Kunst-Sailboat-Models-1524464774524480/
  • 3 months later...
Today, Was one of those day's , that I did not feel like making parts for the VOLVO  70 , Keel # 5 had made the journey to the Boat shed, and Has been sitting on the shelf by my work Table.( so I look at it while I have Coffe ) The Hull had been coated with West System ( I did it at the time , that I did the Herreshoff Buzzards Bay 14 ftr. ) I started by Cutting out a piece of Birch ply for the Cabin top and another for the Cabin companion way wall. I then installed the Cabin Top and Companion wall, and Made the Rudder blade and installed it as well. Next I sanded the Deck, Coamings , Cabin top and Rudder Blade to 600 Grit Sandpaper. I then wanted to try this experiment wich is to see how a cut out Logo ( Paper ) would do if Epoxy was applied over it ( I choose a Loyd's certified logo and a small West System logo ) I first apllied them with Elmers white glue and  applied epoxy over the top of it . I worked out great no ink bleed or seperations of any kind . ( this experiment will now be applied to future builds where this kind of application is needed) , So now Keel #5 has turned into a Shed model/ Test Boat , wich works for me. And as I am not going to do any more work to her, I will close this build log ( the other 2 boats were in a box that went to the Good Will 3 months ago) Don't Ask all I will say is that I was at fault. . So there will be no new Postings to this log , I will still respond to comments and questions . Here are the results from Keel # 5
Current Builds :
 Future Builds :
Completed Builds :
Herreshoff Alerion
Volvo Open 70
 Member :
Nice job, but quite a contrast to the Volvo70.
Bob
Current build:  SS_ Mariefred
