The good and the bad. The good was that I did my first ratlines on my Syren's mainmast, portside. The rats were a bit too tight and caused the forward shroud to curve in a bit. I thought it was acceptable for my experience level. I used Neutral Ph adhesive to secure the knots not CA.
On New Years Eve I even found an inebriated seaman who was willing to climb my rats even if they weren't finished-see attached.
The bad, today I thought I would start the ratlines on the foremast while the knots on the main futtock stave set up. I checked to make sure I was using the correct rope. Then I checked again and again.
Nuts, the rope I used on the main ratlines was a hair (literally) too large. It might pass but knew it was wrong. I ran a couple of line on the foremast and could clearly see my error.
So I spent the last hour removing the "fat rats" and their knots. fortunately I didn't slice any shrouds. Thank goodness I didn't use CA and caught my mistake before I got any further into the project.
Another learning experience--
Cheers, Harley<p
Under Construction:    USS Yorktown CV-5 1/200 by Trumpeter
Completed:              USS Curtis Wilbur DDG-54 1/200 by ILoveKit
                                USS Atlanta CL-51 1/350 by Very Fire
                                Liberty Ship John W. Brown 1/350 by Trumpeter
                                HMS Spiraea K-08 1/350
                                 USS Arizona BB-39 1/200 by Trumpeter/Mk1 Design
                                 HMS Sir Gareth 1/350 by Starling Models
                                 USS Missouri BB-63 1945 1/350 by Joy-Yard, 9/11/21
                                 USS Indianapolis CA-35 1945 1/350 by Trumpeter
                                 USS Kidd DD-661, 1945, 1/350, on The Sullivans kit by Trumpeter
                                 USS Alaska CB-1, 1/350, Hobby Boss, Circa 2/1945
                                 US Brig Syren 1/64 Model Shipways, Wood
Started, On Hold:  Frigate Confederacy 1/64 Model Shipways, Wood
Been there,.... done that.....good on ya' for correcting!
JP
Built & De-Commissioned: HMS Endeavour (Corel), HMS Unicorn (Corel),
Abandoned: HMS Bounty (AL)
Completed : Wappen Von Hamburg (Corel), Le Renommee (Euromodel)... on hold
Current WIP: Berlin by Corel
On Shelf:  HMS Bounty (Billings),
I know what it's like, sometimes you can't really see the mistake but in the back of your mind you know it's there! And you have to correct it otherwise you will always draw your attention to it.
Regards, Scott
Completed builds:
Awaiting construction:
