Birch ply is common in all the Calderkraft kits , no issues with it its good material and used in the false keel and frames and even down to 2mm for the deck, birch dowel is widely used for the masts. i wouldnt use it for planking its just too thick 2 to 5 mm are the usual thickness on ply but often widely used in gunport templates where ply sections are often precut with the ports to aid assembly and marking out. I never considred that in my reply until now, never considered birch veneer but I suspect its too white and would neet staining.
Norman
Edited by normanh
Norman
Current build Trumpeter Arizona 1:200 with White Ensign PE and a Nautilus Wooden Deck.
Built Caldercraft Convulsion, HM Brig Badger and HMS Snake.
Awaiting - Zvelda HMS Dreadnought planning to get the Pontos Deck and PE Upgrades, Panart 1:23 Gun deck model and couple of the cannon kits Manatu - French siege mortar, and American coastal cannon.
I've been 'playing' with some solid wood birch and thinking about trying it on the ME 18th Century long boat.  Instead of purchasing birch strips, I purchased a small box of 'coffee stir sticks.'  The stir sticks measures 1/4" x 1/16" x 7.5" and cost about $10.
Pros:  Very easy to work with.  After soaking, it will twist and bend to any shape needed.  Sands to a nice smooth finish. Able to get a sharp corner.
Cons:  If used as outer planking, it's easy to sand to the point where the 'definition' of the planks is lost.  Not as strong as basswood and may flex if the bulkheads are too far apart.  Does not stain well.
While playing with the strips, I found that all 8 sides of the plank need to be fitted before bending.  This is due to the 'flexy' nature of the wood.
Hopes this helps.
Dee Dee
Current Build
 - Glad Tidings -MS
Completed Builds
 - Dragon - Corel - One design International Class Yacht
 - Sloup Coquillier / Shell Fish Sloop - Corel - Based on 'Bergere de Domremy / Shepherdess from Domremy
 - Muscongus Bay Lobster Smack - Scratch build based on drawings from Chapelle's book "American Small Sailing Craft"
On the Shelf
 - Gretel-Mamoli     - Emma C. Berry-MS    - Chesapeake Bay Pilot Boat, Semi-scratch
Find yourself hoping you never reach your destination
I used birch veneer for my deck planking. I brushed it with Minwax pre-stain wood conditioner and then one light coat of honey maple stain. I found it relatively easy to work with.
Sherry
Every goodbye is the birth of a memory...
Current Build: San Felipe
Finished Builds: Mayflower Build Log
Gallery: Mayflower
Thank You Norman, Dee Dee, Sherry and Janos for Your reply. I have some rough birch wood  and I will try to cut it to ticker boards and leave it to dry for 2 or 3 years, and hoping that I will use it some day.
Greetings, Sinan :pirate41:
Build log:TRITON POB 1:72
