I'm currently in progress building the main mast for the Mamoli USS Constitution cross section kit, and have a question.  This may apply to a lot of ships and kits, so I'll post it here rather than my build log.
The mast is made from 3 sections - pretty standard: the lower mast, top mast and upper mast/pole.
What I don't understand is what keeps the top mast and the upper mast in place?
For example, the top mast goes through the fighting top, between the trestle trees.  Yet, in the plans, the lower mast diameter  is 6mm and the trestle trees should be 6mm apart ,but the top mast is only 5mm in diameter.  The bibbs that support the fighting top are also 6mm apart (as they are attached to the lower mast), so they line up with the trestle trees.  The top mast fits between them as it goes through the fighting top, and then continues upward through the mast cap, but is too skinny to glue to the bibbs or the trestle trees.
It doesn't seem that the mast cap would provide enough support for the entire top mast, which also supports the topgallant (upper mast/pole).  I assume the mast cap is primarily for alignment of the mast - to keep it straight?  Then what supports it against the weight of all the yards/sails/etc.?
The Mamoli kit plans show nothing on how this is to be supported.  I looked up the plans for the Syren, and it uses a "FIB" - a dowel of sorts that is drilled through the top mast and rests on the trestle trees.  Should I install a FIB for my Constitution?
Andy.
A fid which is a square wedge-shaped bar and is used as a support for top mast and top gallant masts .it is inserted in the lower portion of the mast and rests against the tressel trees. The fid is removable. This enables the sailors to low the top or topgallant masts in heavy weather.
Sos
Edited by Senior ole salt
New Bedford Whaleboat build. Kit by Model Shipways
I've been making progress on my model and according to the instruction booklet I should be painting it, at least parts of it.
Are acrylic's ok ? I did apply a sanding sealer. but I want to stain the untreated floor boards which are walnut.
Thanks
S.O.S.
Russ, my apologies.  I was concentrating so much in getting the terminology of the other mast pieces correct, I failed on the fid. :-)
Anyway, sounds like a fid is a standard piece of the masting - so a followup question - which may not be answerable:
How the heck did Mamoli intend that mast to stay up?  They make no reference to a fid, and no reference at all as to how the mast is supposed to stay up.  How do other kit builders (especially the Mamoli cross-section ones) build their masts?
Thanks for the replies - I'll install a fid using a toothpick or something.
Andy.
Andy:
I suspect they counted a glue joint of some kind. Or perhaps they simply did not think it was important for the model. Chances are, most modelers would just make it fit with a shim of something.
Russ
So as a follow up to the original question, did to bottom of the topmast rest on the crosstrees or did the fid rest on the crosstrees. If the fid rested on the crosstrees, was the bottom of the topmast just bare and between the crosstrees or did it have some other support?
The fid rests on the trestle trees taking the full weight of the mast. The lower end of the topmast is bare and has no other fittings.  If you want to add some detail, you could include the thwartships sheave in the topmast just above the trestle trees which takes the top rope - the rope used to lower the topmast.
John
Might I suggest that you look in Lee's Masting & Rigging English Ships of War. There are a couple of easy to understand drawings .
The fid went though the bottom or heel of the topmast from side to side not fore & aft the two ends of the fid protruded far enough on each side to rest on an iron plate mounted on top of the tressletrees. The height of the hole for the fid above the heel of the mast varied a little over time but a figure of 2-3 times the diameter of the mast would get you in the ball park.
The manufacturer of your Constitution kit may consider the fid to be too small to depict at that scale
This post on our site may help:
http://modelshipworld.com/index.php?/topic/332-hms-pegasus-by-blue-ensign-victory-models-enhancing-the-kit-a-build-log-of-sorts/page-12
Drown you may, but go you must and your reward shall be a man's pay or a hero's grave
Thanks for all the responses - I haven't yet assembled the full mast, so I've time to think about what I want to do here.  I'm leaning to putting in a fid, black, and having it rest on the crosstrees.
Andy.
Very interesting post and very timely. Both Mike Dowling and I are working on Bounty and have been discussing the lack of instructions for rigging and masting. Based on my kits instructions so far, it would not surprise me if Mamoli simply left something out. I've come across that with my Artesiana latina instructions a couple times already.
