2) Milled Wood Finish
39 members have voted
  1. 1. What sandpaper would you prefer to be used for finishing your milled wood products?
    • 80X
      1
    • 100X
      3
    • 120X
      8
    • 150X
      7
    • 180X
      6
    • 220X
      14
    • Finer
      0
Currently, I use 120x which is well worn most of the time so it is more like 150x.  For really thin material under 1/64" I will use 220x.
For metric guys:  1/64" = approx. .015" and 1mm = .039", so stuff under .4mm
Edited by Boatsinc2000
Jeff
aka HobbyMill
Current Build: Constitution
As long as it is a good finish - mirror perfect may be a waste as most surfaces will need final sanding by the modeller in most circumstances anyway?
cheers
Pat
