Cut out the decks,a quick test fit,and just some small adjustments to be made. A bit of sanding will have it done.
Out comes the Dremmel again as I attempt the first try at the inner panels for the bulwarks.
Last picture : is this for white panels?
In progress:
CUTTY SARK - Tehnodidakta => scratch => Campbell plans
http://modelshipworld.com/index.php/topic/2501-cutty-sark-by-nenad-tehnodidakta-scratched-campbells-plans/page-1#entry64653
Content of log :
http://modelshipworld.com/index.php/topic/2501-cutty-sark-by-nenad-tehnodidakta-scratched-campbells-plans/page-62#entry217381
Past build:
Stella, Heller kit, plastic, Santa Maria, Tehnodidakta kit, wood, Jolly Roger Heller kit, plastic
It is hard to get equal 78 longitudinal holes without standing drilling tool, or very calm and precize hand. One tip, if you do not mind: when you make them ans when you are satisfied, do not takw macro photos, you will se that them are not equal and not on right position, and you will not be satisfied. Watch whole thing from some distance if you dont want to get in perpetum mobile of remaking
In progress:
Content of log :
Past build:
Nenad has excellent advice;  I did my first tests on this in November;  I'm now planning on installing my strips sometime this week...  I have made some progress on other areas in the meantime, but the fact that I cannot get these ovals all equal has haunted me for the last eight months. :huh:
Time for me to just live with the inaccuracies; (most of which will be hidden by other details anyhow) :D
Great job so far!
~Bob
I agree totally with both of you.I'm not seeking perfection,just the feeling of "that looks pretty good" will do for me!
Quick note:  those notches on the rear (poop) deck are not necessary;  the bulkheads need to be trimmed there as well. (If you haven't already done so)..
Decking looks great!
~Bob
Oh well,very dis-heartened today.Just received an e-mail from the museum,and they tell me they are out of stock of the general arrangement plans for the Cutty.They don't know when they will be doing any more,so work has now come to a stop.I guess this model will now have to be shelved,or binned,as I can't carry on with these useless Billing ones.
I suppose I'm going to have to start looking for a new project now.
Ouch keith- the billings plans do show you where the winches pumps bollards etc should be. Could you not check Bob's and Nenads logs for help too?
Keith
Thought I'd knock a few of these up while waiting for everything to dry.I've got to trim them to size yet though.
Take care about thickness of stanchions. In my opinion cooper is too soft for this work, and if you chose thicker wire, it can be too much massive. And cooper can curve when you mount cooper stanchions
Try with thin paperclips or something similar made of steel or iron
Nenad
In progress:
Content of log :
Past build:
Keith;  24 gauge wire is the closest gauge to the actual 1.5" diameter (.0195 scale inches, at 1:76.8 scale) for these stanchions.
There is also annealed iron wire which is used by people who make jewellery and is available from most craft places- using some to make the chainplates for my billings victory.
Keith
Oh well back to it at last.I've now acquired a decent set of plans at last.New deck now planked and in place,and new (3rd attempt) foredeck. The first one was "Billing" shape,and totally wrong,the second one was my own attempt at getting the shape right,and this one is off the new plans.I'm happy with it now! The trim round the edge is built up with 5 layers of 0.5mm veneer.Much easier to bend than a thick piece of wood,and I think it looks okay.
Things go better, I think ?
In progress:
Content of log :
Past build:
When I first assembled the keel, and test fitted the bulkheads,  they were spot on with Campbells plans.  Billings is not a shipshod company;  but they don't seem to carry through to the end.  I'll be curious to see your fitting kit (I don't have one).  I know the blocks and deadeyes are plastic. (No bueno para me)
but the brass winches, pumps, and capstan are invaluable, and I'll either have to fabricate these (yeah, right) or purchase them.
Make it, Bob, do not bye
In progress:
Content of log :
Past build:
Here's a small selection of brass parts from the fittings kit. The deadeyes and anchors are plastic,but I'll put up with them,as are the lifeboats and jolly boat,so I might have a go at building my own. Depends on how much patience I've got!
In this kit, hiden in one of those plastic bag with fitings, there is a thin piece of patience. Find it and use it !!! It is magic!
Grow as you use it !
I am not jokeing
Maybe a little, but patience grow with experience
Dont let you situation when one day start rigging, and decide to use wooden rope ants, to ask yuorself WHAT I HAVE DONE ON DECK?
Every decision in modeling this beast has long lasting consequences
So, if you decide hard, keep it to the end. If you are not sure, stop and think and re-think ten times
In progress:
Content of log :
Past build:
And Her Majesty (beast) deserve and ask for patience
In progress:
Content of log :
Past build:
Seeing those fittings brings back memories! As mentioned in Bob's cutty log i replaced the dolly winches with more realistic sergal ones though i did use the billings rollers and warping drums. In my cutty kit the deadeyes and blocks were made of wood.
Keith
