Hi all,
I find myself using my micro mill for drilling as much as for milling.  I make heavy use of the x-y table, especially where hole measurement is critical, such as making the coppering jig for the Syren. .  The problem I am facing is that I dislike have to turn a wheel vs. having a drill type lever or crank.
I will be upgrading my mill (it has other limitations) and am not sure which type to get.  The combined mill/drill looks like it has all the advantages but I am not sure if there is a downside to the construction or use of a combined tool versus using a dedicated mill and just putting up with the hand wheel.
The two that I am looking at are the Sherline (for the standard Mill) and the Little Machine Shop (for the Mill/Drill).
Any thoughts would be appreciated.
Richard
Edited by rtropp
Richard
Member: The Nautical Research Guild
Richard,
If you go with the Sherline mill, one of the accessories you can buy is called a "sensitive drilling attachment". This would overcome your issue as you simply pull down on the attachment to drill. It's designed to take very small drill bits. Here's a link:
http://www.sherline.com/1012pg.htm
The Sherline is a top notch machine and highly regarded by many modellers. I have one and love it. Hope this helps.
