Looks good, have you built the rudder yet? Let me know how the rails go, they should fit right over the sides.
Also, you might want to drill the holes for the rails before glueing them on, it's easier. I found out by breaking them off and drilling. Much easier.
Casey
"I drank what?" - Socrates
Current Builds:
Finished Builds:
Future Builds:
  • Mamoli Golden Hind
  • Mamoli Black Prince
  • AL Swift
Yes, the rudder is built and came out nice. Pictures to follow.
I made the ridges exactly the size of the plans but they are a bit on the bigger size
As I get ready to paint the hull, do I use primer first and then the color. Or, is the color itself enough to cover it.
How many coats does it usually take?
 I have seen modelers on this site water down the paint and apply many more coats. What is the advantage of that??
Paint stores tell me that varnish is hardly ever used anymore. Polyurethane is used instead. What is the difference?
Why am I constantly reading about varnish
I on,y use primer on plastic so the paint sticks better. No need for it on wood in my opinion. I use one coat of satin polyurethane on all my ships (4 beginner kits so far) Gives them a protective coat and doesn't look too shiny. Don't know about varnish, it think it's more of a general term for a lacquer. I would check out the forums here or maybe start one with specific questions. Some of the guys on here should be able to get you a better answer. I am still learning these things as I go.
Casey
Current Builds:
Finished Builds:
Future Builds:
  • AL Swift
Thanks Casey for your comments. I doubt I could do this without your ideas
I have shaped the rail and will drill it as you suggest prior to gluing it on.
I have looked at the rudder metal fasteners and they seem too long esp the top one. What did you do?
Also, the metal fasteners have extra pieces of metal. They are flimsy , so how do you remove excess metal?
I think I will start a thread on  varnish and polyurethane
I clipped the rudder hinges down to size. No biggie about the look,if you paint over. I used a needle nose pliers to clip and shape the hinges. They a flexible so you can adjust them to go flush with the hull. Super glue will work, I clamped them to the hull after putting on the glue. Pretty easy and looks good.
Casey
Current Builds:
Finished Builds:
Future Builds:
  • AL Swift
Trying to figure out the correct drill size for the holes needed on the rail. Any ideas?
Also, the yellow given by model expo for the hull is no where close to the picture on the box. Not bright enough. Any ideas on what the correct yellow is called?
the drill size you want is 1.5mm
i just found a yellow i liked and went with it, it was Sunflower Yellow.  i bought it at Michaels in the cheap paint section acrylics
Casey
Current Builds:
Finished Builds:
Future Builds:
  • AL Swift
Hi Casey,
Checked out your yellow and it is much closer to what I like. I'll go to Michaels and check it out
Here is my finished hull, prior to painting
Got the rudder shaped and attached
The rails were predrilled prior the glueing
A few small mistakes but any comments welcomed
Looking good !
Previous boat builds:
Amerigo Vespucci Occre
Yacht Mary
In the Gallery:
I am starting to paint the transom . Probably an idiot question but do I seal the paint on the metal piece with polyurethane? Although I will be using flat or satin finish for the entire hull, will it look nice if I added glossy just to the metallic gold pieces??
I have multiple areas of excess CA glue stains on the walnut hull and the wales. Do I care about sanding them out completely or will the painting hide them anyway?
Also , what is the best way to clean the wales as they will be only stained?
I sealed the metal with poly. As for the wales I taped them off during everything so they didn't get too messed up. I'll post more pics this week
Casey
Current Builds:
Finished Builds:
Future Builds:
  • AL Swift
I painted my transom in gold paint and I like it. Give the hull a good sand and the CA shouldn't show through the paint. Good idea to tape off the wales though.
Yacht Mary
In the Gallery:
wow! you've been productive! looks really nice, good job! I've been away for a while but back now
Planking was very difficult for me. Are you on the first layer?
Dropped some planks but also gradually narrowed to the planks by approx half, starting where the planks began to overlap at both the bow and stern. Ended up by using lots of filler (probably too much) on the first planking. Second planking was a bit easier. Used the same technique but because it was thinner, it was easier to curve.
I'll post it on your site as well. Show me pictures
