I am scratch building  the HMS Victory1n 1:48 scale and I looking to buy   the guns for the upper deck ,forecastle,and quarter deck in scale. But I can't seem to find them...Does anyone know where I can buy same ?
Nick
If you are scratch building such a complex model, you must already have the skills to consider turning master barrels and casting them for yourself.
The Lumberyard (at dlumberyard.com) has 1/4" scale cast pewter cannon barrels for both medium 12-pounders and long 12-pounders, which ought to cover your Victory needs quite well. He even has 24-pounders if you wanna go down a deck. But the two 68-pounder smashers are another matter ...
Nacioffi,
Further to Druxey's  comment, if  you do not have a lathe, purchase one of each size barrel, that you require and then cast your own in resin or pewter.  It is not terribly difficult, it will save a lot of money, and it really is gratifying.  Careful to get good quality, scale, proper era  barrels in the right caliber.
Allan
Naci
Three sources are The Art of Ship Modeling, TFFM Vol. 2 and Euryalus 1803, Vol 2.  Each is a bit different than the other, but all three work.
My preference of course is the last, because it uses a single piece mold, not two part split mold, thus not parting line down the middle of the barrel.
I am sure there are other viable sources that other members will hopefully post for you.
Allan
  • 9 months later...
hello. I have a problem that I need help with.i received the coral victory kit sm23 as a gift. the false cannons and the gun port frames and working lids were missing.does anyone have the part numbers and quanity for these items so that I can order them from coral. I would be thankfull for this information.terry
