mhmtyrl
Everything posted by mhmtyrl
  1. Hello, sorry for not posting the photos of building stages, as I started this model on 2021, but most work was done in past 2 months...I think a real version of this boat would have allready been launched 🙂
  2. thank you GL, i am planning to build a steam boat kit, just planning, did not buy the kit yet....
  3. hello this work is dedicated to the memory of my loving mother, who passed away on june 2021. the original plans do not have a cabin, so added one.
  4. dear all after a long long pause, i am finished with my model. best Mehmet
  5. Hi everyone this is my last build Pazar caique. this is a traditional bosphorus boat used frequently back in empiral times for cargo or passanger transportation. I am done with the hull and the decks. next will be the cargo on the boat.
  6. thank you very much :-) weathering on the wooden parts are pretty easy, i first applied one or two coats of gloss varnish used in yatch decks. when dried applied 1 or two coats of pinotex as a wash. salt streaks on the hull are water based acyrlics, apply them as little dots with the bruh tip and used vertical brush strikes. also sanded pastel chalk works very well for darkening the edges such as deck buildings meet the deck. the rust was made via acyrilics and pastel chalk again. for the sea creatures etc. on the keel, i used table salt. sprey water to the keel and applied table salt on it. that sticks to some degree and some of them fall, so you may choose to apply too much salt later to remove. than painted it with shades of green, and used white pastel chalk to blur its color. i cut the copper plates with x-acto knife from a sheet. for the nail effects i used a little rotary piece, just run it over the cut piece (like cutting a pizza), and sticked them to the hull. plastic modellers do fantastic job with these kind of items on battle ships, tanks etc. and there are great instructional videos on you tube, i highly reccomend watching them. hope these help. best...
  7. many thanks Bob :-) deck; after the deck was planked, I put some coal dust on it and rubbed it. the coal particles then accumulated in the recesses between the planks. later on, I applied 2 layers of gloss varnish (the ones we use for any wood work), when dried I did some washing with walnut pinotex (this should not be so much as it covers and darkens everywhere), so the recesses between the planks were further darkened by this way, lastly I added some pastel chalk to corners (where deck meets bulwarks or the deck buildings) salt streaks; these are ordinary white acrylics. I applied in little spots and using another semi-dry brush apply vertical (from up to down) brush manouvers. if looks to much then you can just wipe it off. the surface of the hull was not very smooth, so wiping off was really a problem. pastel caulks can also be used (in fact I used it at some places. that being said, I feel that acrylics are not very suitable for salt streaks, as they dry too fast before you can apply vertical brush touches. next time I will use enamels. hope it helps, the plastic modellers in youtube do fantastic job with these techniques. you can find many on web. best Mehmet
  8. some more weathering on the hull, basically I added some rust effect (hope not too much). adding rust via chipping using rust color acyrlics gives a wonderfull effect, but easily gets out of control for me :-) so used used pastel chalks,which gives a more diffuse rust effect.
  9. Hello everbody I have started this model long time ago but did some progress only recently. This is a tug boat that have been in service for quite long time in İstanbul Bosphorus, later renovated and currently used as a museum boat. This is my first model that i used airbrush and copper plating. some more weathering such as salt streaks will be added.
  10. I have used expanding foam in a previous build of mine. after expansion and completely dried I pressed on it, apply another layer so that it became slightly solid. I did not try to glue the planks on it (gues CA will melt it) but it served as a base for the planks to lay, supporting planks especially in tight turns. nice and easy method but really sticky and messy :-) mehmet
  11. Thank you Griphos, these kind of boats are not in service for a quite long time, I dont have much info about the engine type or so...
  12. thanks a lot :-) sea surface is epoxy resin and acrylic medium gel. after resin is dried completely I added medium gel randomly, when dried looks like ripples. water from the pump is thin stripe of transparent folder cover, covered with hot glue. later on I added some resin on it. you can bend it the way you want then.
  13. Thank you very much. I also think that this boat is more suitable for shore in reality, but I will use it as a working boat. my problem is this actually, I can not weather the boats in an acceptable way for service :-) hope will achieve one day...
  14. Hello Patrick, thanks alot for comments, I guess I will slightly renew it.
  15. thank you all for comments and likes do you think that condition of bilge pump is way too bad? I mean is the weathering too much? would like to hear your comments.
