Posts posted by captgino
On 6/13/2018 at 3:39 AM, popeye the sailor said:
yea....I kept comparing the nets to the rigs, just to make sure they were wide enough. for the beads, I strung them on some thread and air brushed them. if that's the kit box under the plates, what is that box off to the side? did you get a fitting kit? good for you!!!! more parts the merrier!
This is just some replacement parts since some were missing from the kit when I received it.
Do you have any suggestions on how and where to rig the anchor?
Time to attach the buoy line.
As I was preparing the dry fitting of the nets to the ship. I discovered that I made a mistake. The poles hold the nets were poining forward instead of back. This was making the nets been off-centered. I had to remove them and rigging them again. Not too bad, just a bit nerves racking.... 😥
Here is an example of the dry fitted net. 😊
Good idea. I will look into this evening. I saw this on your build and I think it is an easy change to make.
- popeye the sailor, JpR62 and yvesvidal
3
Thank you for sharing this. I am checked and saw a lot of intersting items. Once I am done with this kit, I will have the equivalent of 3/4 of the same kit left on the replacement sent by billing boat. So I'm planning of making one for myself in the next few years. Maybe at this point in time, I will purchase whatever upgrade of fittings I can find on the site.
Thank you Denis !
I do not have a lot of freedom to do changes without affecting the 'original' work. As I was evaluating what was already doneand how to proceed, I came to the same conclusion as you and the previous builder did. This was the best approach.
I have continued to restore and repair the kit started by the previous builder. I am trying to keep as much as the original work and color as possible.
1. resanded and stained the deck to match some of deck furniture colors. I am planning on doing one or two of wipe on Poly to blend in everything.
2. Added some trim to the main cabin to hide some of the huge gaps. They were everywhere, all around the pilothouse and base of the platform.
3. Constructed the ropes and nets lifting mechanism.
I am planning on painting it black and dry brushing metal and rust.
- yvesvidal, lmagna, popeye the sailor and 1 other
4
CUX87 Krabbenkutter by captgino - FINISHED - Billing Boats - 1/50
Finished. 🤔 I think... 🤣 Oh yes... I am ready to move to another project.
Here are some shots.
