Everything posted by Kevin Kenny
- 1,132 replies
Damaged model, looking for the original details on it
Kevin Kenny replied to Kevin Kenny's topic in Wood ship model kits
Johnny thanks you for your feedback. I have past your comments on to the owner of the model and leave it to them to figure it out. Thanks for taking the time best regards kevin -
Thats all i have. The owner of the wreck seems happy with what we sent so i will leave it there . Thanks for all the help. -
Hi Jan The model has 4 mast as does the Arizona, so perhaps its the Arizona and not the Peruvian -
- 1,132 replies
So we don't go over a well worn discussion. Here is the link to the previous one.
- 1,132 replies
I found this on earlier post on the forum.Checking on Ai it came up with the same reasoning. So i will stick with the red. “ The following is more likely the reason. Deck furniture, bulwarks, etc, were red ochre. This was discussed in an earlier post here at MSW in 2021 and it was mentioned that this was for protection from the weather and ochre (earth) colors were inexpensive. In addition, after long sea voyages and during repairs it was also refreshed. The idea that it would hide blood was coincidental, not the reason it was most often red. There are a number of contemporary models where much of the inboard works were painted black. I have no idea if this was original or done at some later time. The Navy Board stated 18 July 1715 that painting (presumably outboard and inboard) was "not to refresh oftener than once a year or two and the inboard works that are from the weather." There is no mention of a particular color or hiding blood. The actual usefulness in protecting the wood from rot and the cost would probably be a bigger concern to the navy than the mental state of the sailors in the age of sail. If you are next to a man that has had some part of his body ripped off, I doubt hiding the blood on a bulwark would make it any easier to avoid fear, panic or the onset PTSD. Allan Edited May 28, 2023 by allanyed”
- 1,132 replies
- 1,132 replies
I was unhappy with the colour difference between the plywood and the mahogany so thought I would go back to the safe colour choice. Still not happy with the fit.
- 1,132 replies
excellent video on boilers
Hi Alan the recoil from the cannon would push it all the way back to the end of the breeching line. After which the gun would be reloaded and i feel will need both port or gun tackles to get it back to its firing position. Also pulling on one side of the gun tackle may cause the gun to move to one side. So my guess is that they pulled both sides together. The train tackle was probably only needed when starting the firing sequence. i also found how the port tackle was flayed. Photograph attached. So they did not coil the side tackles but instead tied it on itself as i did with my guns. These storage solutions for the various tackles would only be used when the cannon was not in use. When in use rope would be all over the place just like it is in a modern racing boat. The tackles would also be tight when the cannon is not in use to prevent ut moving around. i also found a short video which may be useful to those who never knew how the cannons were used in battle.
- 1,132 replies
This is the first attempt . I am sure that i will make these removable doors and windows a few times before i get it correct.
- 1,132 replies
