Everything posted by Kevin Kenny
Hi Anthony. thanks for the kind offer but i have already ordered dry transfer for the lettering. Out of curiosity what material would she cut the stencil out of . The height of the lettering is just over 1/4” and the font is any serif font like Times Roman etc THORN.
- 1,127 replies
Thanks i got it from Greg this morning. Best regards kevin
- 1,127 replies
Does anyone have a digital copy of the frames for the Swan on file? Mine has disappeared and Greg does not seem to have a copy.
- 1,127 replies
I am well aware of that, but its what i have to work with.
- 1,127 replies
I have found some gold dry transfer sheets on Ebay which will arrive here costing about $25. It will not be the right colour but ill take a look at it. Its better that $200 from a professional service. It is the correct font
- 1,127 replies
Gunboat Philadelphia 1776 by tmj
Kevin Kenny replied to tmj's topic in - Build logs for subjects built 1751 - 1800
Based on the description on how the boat was build the off center planks will be fine. -
Moving along great Henry. I just got new glasses so am back on the model. So nice to see detail again
- 257 replies
- pegasus
- Swan-class
As we have all learnt ship modeling is a journey in which we are all very proud .
- 257 replies
- pegasus
- Swan-class
- 1,127 replies
She is really coming along nicely Henry. I am now putting on the channels, getting back into the model
- 257 replies
- pegasus
- Swan-class
Ok enough carving its back to the model of the Thorn. My last piece was my attempt at carving a rose which came out ok. I had to use the Turbo Carver to get the deep thin slots between the petals and between the leaves. Not sure how this could be done with a gouge as the odds are the leaf would break. It was easy to do with the Turbo Carver. I also used a much thicker blank to be able to get the depth in the piece. The main challenge was deciding on the layering of the carving. I had to cut the leaves first and take those to the finial depth, then the next level and so on. When the basic shape was decided on i used the same techniques we learned in Annapolis to carve the finishes using the gouges. Clean up was done with sandpaper and the Foredom using some round diamond bitts. You will have noticed that i have been carving large pieces much bigger that will be needed to put on a 1/4” scale model but i felt that this was what i needed to do to understand how to develop the carving techniques. Also i used a number of different woods of which Mahogany was the easiest to carve. The Coffee wood, Juniper and Acoma with its tighter grain gave a much superior finish and allowed greater detail but was harder to work and required sharpening the gouges on a more regular basis. In total i have carved 37 pieces and can see how my basic skill level has improved. But its time to move on and get back to building my model. I will continue to carve from time to time but found that the workbench was incompatible with model making and carving at the same time. I was constantly having to sharpen the gouges. On a finial note i think i have burned out the bearing in the Turbo Carver for the second time, so that been sent off to service. Thank goodness for the use of my power tools. It makes me appreciate the work of the old masters even more when one realizes that they did not have access to modern tools.
- 1,127 replies
Bob Emser has a wonderful video on making Blocks
- 1,127 replies
