rexnuktia
  • Location
    Parsippany, New Jersey
  • Interests
    RC airplanes, RC sailplanes, FPV and AP drones, Plastic airplane modeling (WW II) 1:48, Plastic armor modeling (WW II) 1:72, Wood small boat modeling, restoring and riding bicycles
433 profile views
  1. Only oars and a couple of final strips near the top to go... might even dream of doing that tomorrow...
  2. Thought about it and assembled everything like this picture. Now the last step would be to place the rudder in position and glue the attachment points one by one with superglue. Turned out well.
  3. Then I started with the rudder assembly. Pin was glued in place but it looked too big. Realized after putting the hinge cover on it that there was thinner gauge wire also included in the kit. So this was all ripped apart and the thinner wire used.
  4. First, the easier mast holder was completed followed by the oar holders
  5. And after a short (2 month???) break which included a truly frustrating session of dealing with PE, I rigged up a sophisticated PE bender today and got to work
  6. So using wood glue now, I find tiny pieces stay in place long enough to stick without clamping. I do let the glue thicken a bit (by waiting for a couple of minutes) before putting the pieces together. Front nose jig will be removed after curing timorrow morning. The back board will not sit properly. I'll need to shave off some pieces from the aft sitting boards which will be done tomorrow as well after the glue is dry. Center board left off as per instructional recommendation. It needs the metal bracket and mast to align base mast holder first. Also built the stand as glue was drying. Pieces stayed at right angles while the glue was drying.
  7. That Sir, is exactly what I was looking for, although to ccoyle's point again, the slow cure CA is another very good option. Thank you very much for the guidance, I'll definitely check out your build links and give the wood glue a shot.
  8. On the home stretch now. Having the foot boards in one piece is a brilliant design move. I was dreading putting these on one by one... A couple of things were glued a touch out of alignment as my patience is running out. Will continue tonight as kids are a full time job during the day. Also just wanted to add that I tried to glue the rear grating using wood glue, but after a few minutes, the part curled up. Had to go back to superglue to tack it in place.
  9. Keel in place. Required quite a bit of sanding on the fore part to make it match the boat without significant gaps. In the end had to force fit the last part with superglue.
  10. But how do you hold these tiny weird shapes pieces in place while waiting for the glue to dry? My clamps are way too big and utterly useless for such a tiny application. 😟
  11. Thanks buddy, you can call me Amar. The "rexnuktia" screen name is just a made up thing from years ago when I used to play onlone video games LOL!
  12. As can be seen, a lot of superglue permiated the shrink wrap and stuck it to the hull. I have no idea how it would be possible to build something like this with a slow cure glue! Lots to learn here...
  13. So today was really a struggle. Easily the most difficult part of the build was cutting the ribs 1 mm apart to attach the final top plank. Despite using a brand new blade, I ended up breaking a few formers. Then it got worse as the rear hull got stuck to the jig. Some man handling and jig demolition was required, but luckily I got the boat out in one piece.
  14. Thank you so much guys (ccoyle & Ybes). Really appreciate the help and kind words. I'll keep these names in mind. In fact, I did get a response from the Ebay seller (Valentina) that she has contacted the manufacturer regarding english instructions. Glad I didn't wait LOL.
