Everything posted by iosto
Cutter Cheerful by iosto - 1/4" scale
iosto replied to iosto's topic in - Build logs for subjects built 1801 - 1850
Cutter Cheerful 1806 by rafine - FINISHED
iosto replied to rafine's topic in - Build logs for subjects built 1801 - 1850
Compliments ! very good work !!!!!- 525 replies
- cheerful
- Syren Ship Model Company
Yes i'll be addìng.I Made the mast and rigging, i'll assembling it in the next weeks -
Thanks Chuck I could not get a clean job like yours, but I'm very happy. I thank you for having made available to your experience in this beautiful site that allowed me to learn a lot. Thanks again -
Construction of the base I wanted to make the base to be set out in the window, in order to have the ship on a slipway site. I wanted to get an antique effect as some models in museums. I used a wooden base that I covered, cherry wood, with the grain in the central part oriented to the long side, and on the edges perpendicular. I added a decoration between the two frames I put the tape to leave free areas for bonding. The finishing was done with shellac -
Construction of the anchors I realized the anchors with the bars and plates of brass. I have realized a form of wood for the curvature. I soldered the pieces with tin. After I finished with the drill Proxxon -
Test of of burnishing I had never used this type of burnishing. From the evidence I've seen that's not good to leave the piece immersed until the burnishing, but it is best to immerse and then take it off after 20-30 seconds, then go left to air and then rub with a woolen cloth. after the operation must be repeated 8/9 times to get a good coating. I had a kind of burnishing that works in one dive, it was given many years ago now is ending and I lost the recipe .... -
Riveting bridge I tried different techniques to see which one was better. I made several holes with tips 0.5 / 0.6 / 0.8 mm I inserted the tip of a graphite pencil in the hole and then I put a bit of glue. then sanded after this is the effect obtained. The system toothpicks is great but very long and I did not want to use it. -
Foto of mainmast and bowsprit. What kind of finish you used for the hull? only beeswax or shellac pad? sorry for my english but some terms are not easy to translate thank you Iosto
- 1,051 replies
- cheerful
