sfotinos
Everything posted by sfotinos
  1. So I'm back at this fairing. I've gotten quite a bit done, but still a ways to go. Pics to come later. Question: I build in a small non-conforming basement bedroom without any windows or anyway to vent dust. Does anyone have any recommendations for how to collect the dust? Shop vac seems like it would be way to loud. There is no where I could put a larger dust collector. Any suggestions would be appreciated. Thanks Shawn
  2. So I've been stuck with the fairing of Speedwell for several months. I cannot in my head visualize how to go about this. Should i just go for it? Seems like there is a lot of material to be removed and I don't want to over-fair. Would I be better off installing the fore cant frames before doing this fairing? What would you use to complete this fairing? Dremel, mouse sander, by hand with sanding blocks, or another way? Any suggestions would be appreciated.
  3. Cleaning out my stash… $130 plus shipping. PM me, I will accept PayPal. shawn
  4. Happy 4th. Tried to get a little time in the shop today. However, I’m ready to work on sweep port DF and am unable to find it. Hopefully they weren’t on a different billet? Any insight would be appreciated. shawn
  5. There are only about 5 of these frames that are permanently attached. Some still need final adjustments. Chuck's jig system is pretty fool proof, some adjustment is needed. Not alot. On to working on the sweep ports/port sills. Shawn
  6. I’m considering setting all the “tall frames”, and then go back setting the “small frames”. Or is it best to do the sweep port and gun port frames as I go? Shawn
  7. So I'm building frame 10A. I had already relabeled mine when you posted this. I seem to however already have a set of 10A? All 4 match perfectly. Hopefully I'm good. Shawn
  8. Before I attempt to start getting ready to permanently attach my frames. If I’m going to treenail them should I do it before I attach them and do the frames individually or after they are permanent and can do the whole run? Let there be frames… Thanks shawn
  9. I for the life of me cannot find any of the pieces to build frame 12a. Could I ask someone to look at their kits and let me know which billets I should be looking for these. Thanks in advance. Shawn
  10. I have about 12 frames made, decided it was time to try and see how they looked on the keel. With that frame Aa doesn't extend all the way to the line on the plans. Actually none of them do. They do all line up with each other. Did I do something incorrect? I don't believe this is expected. Shawn
  11. Chuck I see that Modelers Sawmill is doing a wood package for Speedwell. Is it recommended that this is purchased from them, or will this same package come from you when that chapter becomes available? Let me know. Shawn
  12. One completed keel assembly. Still needs finish applied, I may opt just to use sanding sealer. I'm not a huge fan of wipe-on poly. Everything pretty much fell together once things were tweaked just a bit. Couple of things... Be very careful with the knee of the head, I sneezed and broke one. When trimming the apron blocks, be sure to use a very sharp blade and very small slivers, as I chucked a couple I popped the first frame out of it's sprues (and yes I think USPS played football with my box, as most everything was detached). I'm going to look like Popeye after sanding all the char off these frames. I need to probably tackle putting the build board together before I get to far ahead of myself. Shawn
