Posts posted by NJQUACK
- GrandpaPhil, avsjerome2003 and mtaylor
- 3
Jacek, Thank you.
Walter
- kruginmi, Mirabell61, GrandpaPhil and 3 others
- 6
- avsjerome2003, hexnut and GrandpaPhil
- 3
Thank you S.Coleman. It never occured to me to paint them black, but what a great Idea. Yes I will be painting them black.
This week I built and installed another yard and continued working on the running rigging.To look ahead a little bit I started looking at the sails.Just want to make sure the blocks are going in the right place and to get a handle on sail building.Sewing is the next model building skill I need to practice.Walter
Thank you Mark. Yes, one of my major goals for this build is to understand the why's, and purpose's of the parts and lines of these ships.
I spend about as much time reading about these things as I spend building.
Walter
This week I was working on the running rigging and constructed another yard.Now that I’m beginning to understand the number and type of blocks required per yardand basically how the running rigging works things are becoming a bit easier.I must thank all the posters on this site, because without the information and pictures here I would be totally lost.Walter
Thank you Charlie. The length of the hull 22 inches not including the cutwater, including the cutwater 24 inches.
Walter
Thank you Mark. I will definitely check into the Magnus hitch. What I’m doing now is using a spacer made from a 4/5 card to locate the knots (see the first photo below). I tie the knots on top of the spacer and adjust them up and down with tweezers if needed. I check the shroud tension when the first half of the hitch is in place and redo it if I’m pulling the shroud. The second photo below shows a rat line in progress with three shrouds tied. When I’m finished tying knots I pull the spacer out. Make any adjustments pushing the knots with tweezers. If everything looks good I hit the knots with a PVA and water mix.
I redid the first set because for me they were too loose.
Walter
The HMS President should make an interesting project.
Yes I would think the rigging plans are pretty much the same. One sheet contains the standing and running rigging, and I have another sheet with the sail plan. Some of the details regarding the rigging are on the sail plan sheet. Neither sheet is to scale so I end up doing a lot of eye ball adjusting.
Walter
Azzoun, Yes another Jerseyan, I try to get in an hour or two after work everyday. Thanks for the kind words. Walter
Thank you, S.Coleman. Walter
Peregrine Galley 1700 by NJQUACK - FINISHED - Sergal - 1:60
Thank you Mark. Everything is so new to me in ship building it keeps me motivated. It's like reading a good book.
Walter
