Posts posted by Garward
Hi, Spiff! Color of a planking of the hull turned out good, but covering levels too short
http://modelshipworld.com/index.php?/topic/745-golden-star-by-garward-mantua/
Hi Garward,
The grid is created by carving the acetaat, painted black and wiped off the black paint so it remains in the carves only. Take a look on the first page of my built log, there are some pictures how it is created for the doors of the machine room. Using mm paper to keep the carves in line. Now using a cotton swab instead of a brush which works more cleaner.
Best regards,
John
Thanks, John, I understood, it is good idea.
Many thanks, Randy! It is pleasant to me that my work is pleasant to you.
Hello, Geoff, good work with masts!
Hello, Sakcha! The nice model turned out, I congratulate!
Hi, Jared, I congratulate on model end!
Hi, Erik, the good hull turns out!
boy......talk about fast service! I just ordered these.......
Hi,Popeye the sailor, of what wood they are made?
Thanks Sjors, I knew something was wrong, but could not find out what. . .
In the meantime have fitted the windows and door to the curved walls of the state-room. There are neither window nor door frames which I donot like. So used mahogany 0.6 mm to create a kind of frame.
Regards,
John
Hi, John, beautiful windows turned out. Of what you did grids on windows?
Known wise expression says: it is necessary to hurry slowly (that is before to make something, it is necessary to think well) .
In new home
Hi, Kevin, In the new house the model looks very harmoniously!
Hi, Geoff ! The excellent photos showing that is visible on a surface of a deck flooring in installation sites of nails !
Hi, Sjors, You will show them drawings of that you do, and they will suggest you to buy only that they have
To process or not treenails to diameter of openings in the deck - depends on a ratio of hardness of wood of the deck and treenails. If hardness is close, it is better to process (an example - Montanes).If the deck flooring is made of firm wood, it is possible not to process treenails. In the Bronze 24-pdr canone Le Fleuron model a deck flooring - the Brazilian maple (has some more names) the dense, firm wood close on color and properties to boxwood. Because of its hardness it is a pleasure to insert birch toothpicks: the conic part of a toothpick "is easily screwed in" in openings, after opening cleaning well keep a form.
Birch treenails, Bronze 24-pdr canone Le Fleuron model
- Archi, avsjerome2003 and hopeful
- 3
Continuation
Bamboo treenails, Montanes model
http://modelshipworld.com/index.php?/topic/82-montanes-by-garward-occre/
- Archi, hopeful, avsjerome2003 and 1 other
- 4
For imitation of nails the toothpicks which ends are pierced to diameter 0,5мм by means of a drill and the adaptation in the form of the brass cylinder with a flat bottom thickness 3мм on which center the opening by diameter 0,5мм is drilled are used. All these operations are done before installation of deckson the hull.
Cool tool lathe Unimat (moved by admin)
in Modeling tools and Workshop Equipment
If there is no experience with machines and their adjustments, it is better not to buy the machine which was in use.
