Posts posted by Garward
Ahoy MSW
Found this link below and thought it might be helpful to others.
http://www.thenrg.org/resources/articles/The%20carronade.pdf
Thanks for the link!
Can someone please tell me where to buy these for a model? Can't seem to find any.
Regards,
Al
Look here http://www.shipmodels.com.ua/eng/accessories/artillery/cannon/index.htm
On a photo the template from aluminum for production of a framework of gun ports is shown
http://modelshipworld.com/index.php?/topic/82-montanes-by-garward-occre/page-2
Motionless details of a template are stuck together among themselves CA (capacity with CA is visible on a background). The template sustained production of several tens framework and further is suitable for use.
Really, grinding drums available on sale have too rough sandpaper which should be replaced.
For these dead eye the corresponding chain are made of a brass wire with a diameter of 0,75 and 1,5 mm. The template in the form of the brass cylinder with a diameter of 7 mm pierced under diameters of dead eye is used. The brass hoops which go around the deadeyes are soldered by a gas torch with application of argentiferous solder (40% of silver). In this case application of soft solders on the basis of tin gives insufficiently strong connection which can easily collapse at installation and a tension of shrouds http://modelshipworld.com/index.php?/topic/82-montanes-by-garward-occre/page-12
Thanks Garwood, I didnt think that a piece of wood wedged would stay in place. I will be making a few of different sizes for myself.
In vain you think that the wooden wedge won't hold sandpaper. Such fastening of sandpaper on drums is widely applied in various machines, there is only a difference in a wedge material - a tree, plastic, rubber, metal. On a photo - the Vanda-Lay firm machine with similar fastening of sandpaper.
Hi Commander, thank you wery much for your "dokumentation" of the jig saw...
Regards
Tylmo
Always please, Tylmo, I am glad that this documentation is of interest for you
In summary I wish to tell that meanwhile jig saw I am satisfied by work, though already there are ideas for its completion. I wish to tell also that all who heard work jig saw and FET (relatives, friends, neighbours), mark essential reduction of noise in comparison with FET (on hearing of time in two).
Garward
Wonderfully made piece of equipment. There's just something about making it yourselve. In my chemistry research I had the chance to disasemble for repair and maintainance many wonderful toys, but the one I'll always remember is the instrument I built and did the bulk of my research work on.
Bet it works like a dream, looks like the rip fence can be installed on either side of for left or right cutting.
Beautiful piece of equipment,
Keith
Thanks for the comment! Finally I managed to construct the tool almost completely corresponding to my initial plans.
The table rotates on a steel axis in diameter of 6 mm which ends are fixed in vertical steel racks (corners) in the thickness of 3 mm (photo IMG _2109). Turn on 30 degrees of the flywheel shown on the same photo provides moving directing on a table surface on 1 mm, turn on 3 degrees gives according to 0,1 mm.
32 pound ship guns 1:48 scale
in Discussion for a Ship's Deck Furniture, Guns, boats and other Fittings
It means: iron (steel, pig-iron) guns without a decor.
