Posts posted by Garward
Hi, Scott! If you mean glue for fixing of knots on ropes, practically doesn't leave traces shellac.
Hi, Grant! Stain for ropes at water works more slowly (dries more long), usually it is necessary to carry out process several times, but to receive uniform coloring of ropes easier. Stain for ropes at alcohol works quickly, but certain skills that coloring of a rope turned out uniform are necessary. The end result in both cases it is possible to receive the identical.
Hi, Daniel, thanks for the comment!The cast trunks of guns for Le Fleuron and Venus from here http://www.shipmodels.com.ua/eng/accessories/artillery/cannon/index.htmAt the request of them it is possible to get in different types: raw after casting and most to process (that I and made), and it is possible to order trunks with processing.Trunks of guns for Montanes are turned on the lathe.
Hi, Carl, thanks for the comment!
Hi, Daniel! Here a blackening example with the help of solution of selenious acid of a smooth trunk without a decor (the French gun of a frigate of La Venus).
New glues and other materials with interesting properties recently began to appear more and more, it is difficult to follow all this!
By no means, it is a good horse for the purposes. I too sometimes use epoxy glue, but this matter of habit and personal preferences, after all with various materials it is possible to receive very similar results.
Epoxy has been used for decades throughout the aircraft industry. If it were true that all epoxies tend to crack with time and temperature than all aircraft would be grounded.
It is true that you can formulate an epoxy that uses the 'wrong' hardener or ratio and result in a brittle mess, but that is not to say it is true in general. I would agree with Augie that for our purposes we don't have to worry about the occasional mistake of mixing the wrong batch and I have not experienced any real problems with epoxy due to age and temperature.
I am now retired after having been involved with advanced composites (which included a lot of epoxy applications) for more than forty years both in R&D as well as production.
I was connected some time with nondestructive testing of quality of with advanced composites (which included a lot of epoxy applications), since then I treat them watchfully
Hi, Sjors! If you decided to remake chainsplate, it makes sense to replace thus also chains with a wire. By the real ships of that era these details didn't produce from chains. Chains which stand, for example, on my Corsair model, on your Corsair and on a number of these models is an imagination of the producer of a kit, no more .
Probably, we used various grades of epoxy glue, I have generally an experience from the industry. In youth I too was engaged in model aircrafts a little , at me and now there are a lot of colleagues - aeromodellers, but they generally apply various nitroglues.
I have to say I've never seen that happen. But we each have our own experiences.
I also wrote it, relying on the experience of application of various epoxy glues (not only in construction of models) within thirty years
Ahoy Garward
If you are saying that CA might work here too I would agree. I would still perfer epoxy because you can control its final harness by altering the ratio of hardener. CA is brittle and does tend to chip when drilled.
And epoxy glues give too rigid connection which tends to cracks over time, especially under the influence of temperature
As well as at a model choice - to whom what glue is pleasant!
MONTANES by Garward - OcCre
Cable - "template" for the direction of installation of chains.
