Posts posted by Wschoenfeld
I was considering sanding more when I visited a few other logs to study up on the tic mark technique used by others to measure plank widths - it would be difficult to see on the middle frames with that laser char still on and is another sign I have more fairing to do. Your feedback confirms my suspicions - thank you!
- Nirvana and Ryland Craze
- 2
Picking back up -
I added the rest of the frames, and placed the rest of the reinforcements. The end result can be seen here:
I realize that I'm a long, long way from the finish line, but this was the first time I really got excited about the project: this thing is starting to look like a boat! After this last piece was in place and all the little battens on top were glued and dried, I started to fair the hull.
For the fairing, I used 240 grit sandpaper. I added a little bit of finishing with 400 grit, but for the most part, I felt that was pretty minimally effective at adding the beveling I was looking for. Since I had never used my plank bender before, I heated it up and bent a scrap plank to what I felt approximated the curvature of the top plank (blanking on the proper term here, sorry). I used that plank to visualize how the fairing should run from stem to stern. No blocks or other implements to hold the sandpaper, I tore off small squares and worked by hand. This is kind of hard to photograph because of the scale and how many frames there are; here are a few views of the bow from top and from bottom so you can see where I ended up.
And bottom:
I should have mentioned that I added the bow filler blocks before I started fairing. The blocks sanded nicely into the contour of the first frame.
As I was going through this process I started to get a little concerned about the fit of the frames as we go aft. Some of them appear closer to the rabbet than others. Additionally, where I cut the false rabbet in the keel towards the stern, some of the frames actually ran into the rabbet. I used a round sanding tool (included with the tool kit I bought from MS, picture a metal toothpick with grit on the tapered end) to smooth these little overlaps out.
Here are some pictures to illustrate what I am talking about:
Starboard stern above, port bow below:
As you can see from these pictures, I did end up adding the stern piece after I was satisfied the fairing was completed. This piece was hand-faired before gluing. This was the only place so far I have been unhappy with the laser-cutting. On one side of the piece, there were a few spots where it looked like the laser took off a little more than necessary:
Might be hard to see here, but those burn marks are actually three-dimensional divots in the wood. Since the inboard side will be covered by the locker, this side is facing the bow. Back to the topic of adding it before framing, it seems that others here have left it off for at least the beginning of planking. It's a little late for that, but I am considering not securing the planks to this piece until they are fast to the bow and the after-most frame.
That pretty much brings my log up to date. I have started to put edge and front bend in two planks but will not start the process until I ask: do you see any errors or worries to be addressed before I start the planking process? My main areas of concern are the frames: that they may be off-center either up-down or right-left in a way that could throw off the spacing of the planks. I assume it is good practice to glue the planks to every frame, so I suppose this isn't a huge deal (?) but I would like to fix issues before I start laying planks. As always, thanks for your input, and I am looking forward to moving forward - my goal is to get decently into planking before my classes start back up at the end of the month. Hope everyone is enjoying the summer!
- Cathead, Ryland Craze, fatih79 and 4 others
- 7
Time for another update! Apologies for the delay - the beginning of August was a bit of a whirlwind but I have had some time to work on the longboat. I will probably need to break this down into a few entries - as a preview, I have completed the framing and fairing and I think I am finally *yikes* ready to start planking the hull.
I'll start with a picture of the jig I worked up, based on the example Kurt posted a few entries north of here. Since this is really my first wooden project, I am short scrap wood, so I bought a bag of basswood odds and ends from my local art supply store. This came together from a block, a plank, and some spare square stock left over from the MS keel framing jig I built in anticipation of starting the AVS (before I "wisely" decided to start with this guy instead). I used a carving tool to notch the slot that holds the stem, and after gluing one of the square stock pieces in place I used the keel itself as a reference to mark where the other should go. This is the final product: clearly a little off-center, but it does the trick.
Another view, with the keel and the first two frames dry-fit:
After that, I started adding frames in earnest. With the exception of one frame (the second aft from the stem, I think), these were all attached using elmer's white glue. I liked being able to back the frames out if I felt they were off-kilter somehow. I tried to use spare blocks as a jig to make sure the frames were square, but I am not completely satisfied with the results. I used dead reckoning on the frames after that, adding one or two at a time.
Here is an example - #0 looked off-center, so I brushed on some water and was able to back it out. I added scrap reinforcements to the adjacent frames before I removed it, which I then replicated on all the frames after seeing that technique used on multiple logs here. In the picture below, you will see my solution to a frame that canted towards the bow - a piece of scrap boxwood and two pins secured the frame in the proper alignment while the glue dried.
This seems like a natural break-point. More progress to follow in the next post.
Thank you all for your input and suggestions! As suggested above, I tried my ruler against the 1/4" scale ruler on sheet one. The results weren't totally conclusive, but after staring at it from a few angles I do think there is a small deviation between the scale of the plans and the ruler reference. This is the best picture I could get of it:
It is hard to tell, but (doing my best to align the first hash on the ruler with the left side of the plan scale) it looks like the scale is ever-so-slightly smaller than the ruler. This would make sense, since my Longboat's keel over-runs the plan images. Additionally, I laid the keel on the second sheet of plans to see how that comparison stacks up:
This makes me feel much better. The keel assembly appears to fit the plan almost exactly (accounting for the 1/16" stern piece that isn't yet attached). I think, per the advice I have received so far, that I'm just going to proceed with the build instead of trying to get another keel, since I would bet that it's the plans that are off instead of the wood cut.
Again, my sincere thanks for all the input on this first question - more to come. This is the kind of thing I would still be scratching my head over if I were going it alone, and I appreciate your all taking the time to respond.
I am heading into a busy end of the week, but I have what will hopefully be a quick sailboat ride from here in Chicago up to Mackinac Island to look forward to this weekend. There are about 330 boats in the entire race fleet, and our goal is to finish at least 329th. Once I am back from the race, I will set about building that jig Kurt laid out above, then start into the bulkhead work. Thanks again!
Hello all,
As this is my second post on MSW and my first crack at a build log, I'll open by requesting any and all advice and criticism (preferably constructive, but I'll leave that up to you). As you can see by the title, I am building the MS 18th Century Longboat. This is my first build, save for a Midwest kit I started and didn't complete sometime around 2002. I have a decent set-up of hand tools and workspace, but I need to build a proper jig - I constructed the ModelExpo framing jig when I bought the AVS, but since I decided to build the Longboat first, that jig is too big for this project. Anyways, on to the building process:
I started out cutting and fairing the simulated rabbet. Using a trick gleaned from someone (sorry, I can't recall who) on the forums, I transferred the line from the plans on to a scotch tape template, and used that to notch the bearding line on the port side of the keel.
After I was satisfied with the false keel, I attached the stem and then the keel. The scarph joint required a bit of sanding, but soon the entire assembly was together. I adapted a tip from Frank Mastini's book and used two C clamps over a piece of scrap boxwood to form a vise (with my desk as the other jaw) and used a notecard to make sure I didn't glue the keel to the scrap. This left me with some paper fibers on the keel - not too hard to sand off, but I will use wax paper next time.
Now, for my first potential issue. After the keel assembly was complete, I laid it on the plans to make sure I had attached everything correctly (hard to see where this could go wrong, but I have learned to never underestimate my ability to overlook detail). I noticed, when I did this, that the notches on the false keel do not match up to the bulkhead cross-sections on sheet one. This pictures should demonstrate what I am talking about:
I can't add reference lines to these photos yet, but if you look you will see that when I align the stem with the plans, ensuring the keel is level with the plan lines, the spacing of the bulkhead notches gradually staggers... out of whack, for lack of a technical phrase, as you move aft.
I took another picture with a different plan view, I believe this shows the same spacing inconsistency.
Now for the possibly dumb question: is this something I should be concerned about? My first thought was to just proceed with the build, trusting the difference would shake out as I build on. However, my only other wood modeling experience is in the realm of Guillow's planes, where everything laid down *must* match the plans, and I thought I would raise it with you all before proceeding. I apologize if this has been covered before; I searched the forum for this issue and didn't find it in any of the many excellent logs I turned up, but I am still getting the hang of the search feature and could have missed it.
Thanks in advance for your help and input - I am glad to have completed the first minor steps, and I am looking forward to getting into the build in earnest.
Will
- MarisStella.hr, fatih79, heksanol and 4 others
- 7
18th Century Longboat by Wschoenfeld - Model Shipways - 1:48
After many months of not really working on the Longboat, the end of my semester has allowed me time to keep working on the build. I will try to backtrack a bit in future posts but for now, here are four pictures of the interior and exterior process. I am planning on painting the entire hull a shade of eggshell white, since my planking was sloppy enough to require a fair amount of filling and sanding. I am looking forward to getting back to more regular posts - as always I appreciate any and all feedback!
Red on the interior is one coat (so far) of Testors enamel. I will probably do the hull in acrylic, the enamel stuff is a bear to get out of brushes - even with the Testors solvent. No masking used on the ribs, so there are some slight imperfections visible.
Nail marks were made with a sharpened pencil point, bored into the wood and sanded with medium-fine grit before a few light coats of matte clear acrylic.
The extent of filling will be clear in this picture... hopefully, the next one will be more precise.
More to come!
