mtbediz
Everything posted by mtbediz
  1. I have started working on the windlass. Some parts in the photos have not been glued and fixed yet. Just dry fitting.
  2. Thank you Bruce. Be careful, don't let the admiral realize you stole her pot
  3. Thank you Allan. No, I don't think you can use my method at your model scale. I use 1,8 mm of cutter.
  4. I made the companionway, hatches, gratings and skylight according to the drawings in the Alert book.
  5. I am back at my shipyard after a long summer break. I started with the main hatchway to make the deck fittings. As always, I use milling machine when making the grating elements. I used a sandpaper that I attached to a pot to make the camber on the grating. (for those looking for a practical way to create this camber)
  6. I made the nail effects with pencil and added waterways. I started working on the bulwarks and transom.
  7. Thank you friends for your compliments and encouraging words.
  8. Hello friends. I photographed Essex, completing a few minor details. Its construction took approximately 2500 hours in 2 years. Enjoy watching.
  9. I will only apply matte varnish. I got the look in the photo on my USF Essex model I built before and I like it.
  10. Thank you Oldsalt. I will make nail effects with pencil.
  11. I started deck planking. I am implementing 3 butt shift method as shown in the Alert book
  12. Thank you so much for stopping by and your encouraging words Yves. This is my first clinker built hull attempt and I am happy with the result too.
  13. While I was waiting for the hornbeam strips I ordered for the deck planking I painted below the waterline white. I am not very knowledgeable in painting, nor I am good at it. I don't like putty and sandpaper job at all, so I always chose unpainted models before. There are a few points that I need to touch up.
  14. Thank you so much Oldsalt. I have begun the deck planking. Basswood planks in the photos are temporary, I am using them as templates for preparing the margin planks.
  15. I making the bolt effects with 0.7mm diameter black nails. The visible bolt head is spherical and approximately 1.25 mm in diameter. (When we move it to 1:1 scale, the bolt nut size becomes approximately 45 mm, which I think is not too inappropriate in terms of scale). It looks more like a rivet than a bolt nut, but I couldn't find a more suitable material. In the original, the bolts are closer together. I bought all the nails in the store and for now I am doing them widely spaced as the number is limited. Depending on the remaining number of nails, I can make one more row in between.
  16. I stained above the waterline and mounted the wales. Below the waterline will be painted white later. I kept the bulwark caprails in hot water for a while and fixed them in place with clips. I'll glue them when they dry.
