mtbediz
Everything posted by mtbediz
  1. Thank you so much Oldsalt. I have begun the deck planking. Basswood planks in the photos are temporary, I am using them as templates for preparing the margin planks.
  2. I making the bolt effects with 0.7mm diameter black nails. The visible bolt head is spherical and approximately 1.25 mm in diameter. (When we move it to 1:1 scale, the bolt nut size becomes approximately 45 mm, which I think is not too inappropriate in terms of scale). It looks more like a rivet than a bolt nut, but I couldn't find a more suitable material. In the original, the bolts are closer together. I bought all the nails in the store and for now I am doing them widely spaced as the number is limited. Depending on the remaining number of nails, I can make one more row in between.
  3. I stained above the waterline and mounted the wales. Below the waterline will be painted white later. I kept the bulwark caprails in hot water for a while and fixed them in place with clips. I'll glue them when they dry.
  4. Thank you so much for your suggestion Ywes. I will look at them.
  5. The second layer of planking is complete.. In real life, these planks were fixed to each other and to the frames with bolts + treenails in a certain configuration. I want to reflect this on the model, otherwise it will be a very raw look. I know some methods to give a treenail effect, but what can be done to give a 1:36 scale bolt effect or to represent the bolt? I would be glad if friends with ideas can guide me.
  6. Murat Bey, great job on the hatches, coamings, windlass and other deck stuffs. Everything looks so beautiful. Do you keep building the Alert, any progress on the model?
  7. Clinker planking of the port side is complete. I am happy with the result. I think it doesn't look so bad at all for a first time job done. I used 1.5x8 mm planks in planking. Maybe it would be more realistic if i used a bit wider planks,
  8. I finished the first layer of planking on the port side and started the second layer. Since the original planking of the ship was clinker type, I started it from the keel upwards. This is the first time I'm making a clinkered hull. In case I fail and get stuck, I decided to complete one side first so that I wouldn't have to deal with the other side in vain. Normally I do it on both sides.
  9. I cut the stem and keel in accordance with the drawings in the Anatomy of the Ship Alert book and mounted them in place.
  10. Hello guys, I just finished Essex. I couldn't share the finished version because I haven't photographed it yet. I will share as soon as possible. I have started my new project, HM Cutter Alert 1777. I used Vanguard's kit plan for cutting the bulkhead former and bulkheads. Since I chose a slightly larger scale (1:36), I cut the bulkhead former and bulkheads out of 6 mm plywood accordingly. As such, because of relatively stronger structure I eliminated the bulkheads securing patterns and lower deck pattern in the plan so the cutting work was considerably reduced. Since I will make the rabbet where the ends of the planks will enter in the bow part with my own method I cut the bulkhead former accordingly. I made the bulkhead former in 2 pieces in case it was warped because it was a little long. I cut the deck from 2 mm of plywood and glued it in place. I filled the bow with balsa. I will mostly use the drawings in the Anatomy of the Ship book during my build.
  11. I have completed the boat and hung on the hooks through the inboard eyelets. I attached those clamps as weights to stretch the lines and applied dilute PVA on the lines. I will remove the weights after the glue dries.
  12. I am now making a boat to hang to the stern davits.
  13. Some additional progress. I have made, mounted and rigged the spritsail and sprit topsail yards.
  14. Thank you very much Bob. That means a lot coming from you, master.
  15. The rigging of the yards is now done. I will add a gaff to the mizzen mast to complete.
  16. I have now done the fore lower, topsail, topgalant and royal yards and their rigging.
  17. Hello friends. I watched a few videos on the internet on how to make rope coils for the belaying pins, but I couldn't get the image I wanted in the trials and I developed my own method.
  18. The yards and rigging of the main mast have been completed.
