mtbediz
Everything posted by mtbediz
  1. Based on the kit plan, yours looks correct. Since I made the gunports larger, the distance between them decreased. This was due to my carelessness. I probably took the measurement wrong.
  2. It is certainly much easier to do the hull planking with the ship upside down. In all my models, I do not start doing the deck details until the hull planking and copper plating (if necessary) are completed. I even recommend doing the rudder and hinges while the ship is still in an upside down position. It will be much easier.
  3. Starboard side quarter gallery windows are completed.
  4. The first window of the quarter galleries is complete but has not been glued in place yet.
  5. I started the construction of Quarter Galleries. I'm taking the living Old Ironside as a reference.
  6. I've seen yours and they are more accurately done. As I mentioned, I need to improve myself in working with metals.
  7. I applied matte varnish on the copper plating. The shiny and disturbing image is gone.
  8. Thank you so much Greg. I started to prepare the rudder. Since I don't have enough tools to handle the metal material, I make the pintles a little tricky The gudgeons were cut from 0.3 mm brass sheet and mounted in place with nails.
  9. I completed the copper plating of the hull. The next stage is to prepare the rudder and install it in place while the ship is still in upside down position. This job is much easier when the ship is in this position.
  10. Thank you so much Geoff. Yes, this is a hobby that requires patience and most importantly love. I have had many friends who started and quit this hobby.
  11. Thank you Greg. The copper plating has not finished yet, but I estimate that I will complete it in 5-6 working days in total.
  12. I haven't been around for a while but now I'm back in action. I completed the hull planking and started copper plating below the waterline. Even though the copper nailing pattern is not very accurate historically, I prepare copper plates using my own methods because I like the way they look. I use self-adhesive foil tape on copper plating.
  13. You're absolutely right, Greg. It would be more accurate if I did a butt joint after 3 or 4 planks. But as you said, it will not be visible because it will be covered with copper. So I chose a path that was easier for me. If I try to do everything exactly according to the rules, I might hate this hobby, but I don't want that. This is just a hobby for me.
  14. The last few boards remain to complete the hull planking. I'm quite pleased with the result, there is no need for too much sanding. The next phase will be some paint work on the upper hull and copper plating below the waterline.
  15. Thank you Cisco. I am gluing the planks both to the bulkheads and to each other at the edges.
  16. Welcome back. Good luck with your Conny 2. I hope this time things go as they should.
  17. The planks need to be bent to fit snugly into the bulkheads. Both lateral and edge bending is required in the bow. By the way, the end of the road is in sight in planking.
  18. I apologize for delaying the reply. I use wider planks (5 mm) in planking because I can do more precise tapering with wide planks. That's why I use fewer planks. I will paint the ship as it looks today. I will also copper plate below the waterline. I added the counter extensions beforehand because I wanted to do the planking of the transom first. Otherwise, there was a high probability that the stern frames would break as I would turn the ship upside down while doing the hull planking.
  19. Thank you. Yes I will paint the hull.
