Everything posted by Ondras71
Roter Löwe 1597 by Ondras71
Ondras71 replied to Ondras71's topic in - Build logs for subjects built 1501 - 1750
Mast parts done. Topmasts supplemented with pulleys.. Making basket supports called Mast Cheeks. Again processing the glued and then soaked parts.. I have already reached model height..💥 -
I modified my lathe to clamp long sections of masts..🔥 Production of topmasts has started.. Add some details and I can start assembling..💥 -
Thank you very much friends, I am trying my best..😁 Finally the main lower parts of the masts..🔥 Temporary direction signs created for exact machining directions.. The tops are machined and holes drilled for the location of the lower tie-down points.. Finished lower parts of the masts.. (Manual dividing device) Done..💥 Now tops and topmasts..🔥 -
I finished the swivel cannons on the railing.💥 I created new smaller chambers.. After blackening.. The last visible detail, the chamber pins.. The last parts of the hull, chamber guns, placed.. And now I can rush to the rigging!!🔥 -
Thank you very much friends. thank you for the like. I'm continuing with the rotating chamber cannons on the railing, luckily there will only be four. I found the current cannon in a book by Ab Hoving: Het Schip Van Wilem Barents and painted it. Then the turning began. It is very small against already created cannons. Created pockets for exchange chambers. Of course, you need to start making a larger number, they slowly decrease during the work.. Added chambers.. Result OK.. -
Děkuji moc přátelé, děkuji za další lajky.😍 Kormidlo hotovo..🔥 Loď vypadá na palubě dobře.. Udělám stojan a pevně postavím loď...💥 -
The boat is ready, just the rudder and place it on the ship...🔥 The 1:60 scale is still demanding on details.. -
boat: bench and railing... It's only 10.3 cm... Now for accessories...🔥 For those interested in a competition or model exhibition : https://wchs-c-2023.eu/en/news/id:11798/czech-championship-of-section-c-2024 -
I continue on the boat..🔥 I found beautiful photos of the Willem Barentsz boat replica. On the website of the modeler Heinrich. shipsofscale.com/sosforums/threads/high-hopes-wild-men-and-the-devil’s-jaw-willem-barentsz-kolderstok-1-50.8662/page-100 The tops of the ribs have been cleaned, the ribs have been cleaned inside, the top edge has been ground flat.. Completed the last rib and bottom of the boat.. Outer hull and bottom of boat waxed..🎨 Now the railings and benches..🔥💥 -
Thank you friends, your interest pleases me and moves me forward. -
Another milestone behind me, the body of the boat finished, sanded and cut from the hoof with a razor saw..🔥💥 Again I used the option of dispersion glue. The sunken place on the bow after removal is wetted and pushed from the inside into the correct place.. A preview of the boat on the ship's deck..😍 Now clean the ribs and arrange.🔥 -
Ship in trouble by Ab Hoving - FINISHED
Ondras71 replied to Ab Hoving's topic in - Build logs for subjects built 1501 - 1750
Hello Ab. I am very glad that you are now healthy and creating again! I'm thinking of putting your picture on my wall...🏆 Ondras -
I continue on the work boat. Bending workshop.. According to the paper templates, I create more rows of boards, the edges highlighted with graphite.. The third row already has an extreme side bend. After a good soaking, the 0.8x3.5 mm strips can be bent well, just persistence. Step one - side bend.. Step 2 - after drying, bend into the shape of the torso, then fit.. I will save material against carving from wood plates..👍 The last part, closing the bottom. Too small, the bottom will not be visible, I helped myself by assembling the moldings from two parts. Otherwise, it would not be possible to do it well..🔥 -
I continue with the paneling boards, paper templates again.. Surfaces created on the ribs.. Gluing with long-term glue D3, fitting takes a long time.. First board..🔥 I wish modelers all over the world a lot of peace and time to build models in the new year 2024. Ondras -
Thank you very much everyone for the likes.. Spraying done, maybe the last one on the ship...🎨 Glued pre-prepared wales from strips 1x1 mm.. The result is satisfaction..🔥💥 -
I continue on the work boat. According to the plan, the boat has colorful decorations. I didn't want to do this on the boat, but the color strip will match the whole boat.. So spray paint white and then red triangles. The board is 2.2 mm.. Red... And the resulting decorations.. I'm repainting and now just clean wood...🔥 -
Thank you very much everyone for the likes.🙂 The most challenging part of a Dutch boat with a round bow and stern. Top board. Made stops to get the shape and cut the boards... ..bending into shape according to a paper template.. First boards glued..🔥 Bow.. Stern.. Finding? Very fragile.. -
Thank you very much everyone for the likes.. I finally finished the folded ribs of the boat.. Future rib height.. Sanded, I can lay boards..🔥 -
Greetings Tomek. Beautiful work, I envy paper art. 🏆 You convinced me again that the Dutch ships were the most beautiful..
- 26 replies
- Seahorse
- De Zeven Provincien
So the WCHS 2023 pre-competition and competition time is over, the boat has returned from its trip.. ...now to start building again and finish the rigging!🔥 -
You have great eyes Johnny. Of course, the plan in our "eastern" sector was for the Soviet ship Tovarišč. -
Binding points laid on the bowsprit stump. The ship is temporarily located in the museum in Rumburk as part of promotional events for the 2023 World Model Boat Championship in the Czech Republic. https://wchs-c-2023.eu/cz -
Thanks scrubbyj, thanks for the like. I hung the finished anchors on the boat. The bow has been properly strengthened.. I will also place the binding points on the bowsprit stump..
