Everything posted by Ondras71
Roter Löwe 1597 by Ondras71
Ondras71 replied to Ondras71's topic in - Build logs for subjects built 1501 - 1750
Thank you very much Silverman. Thanks for the like! 😇 I have been thinking for a long time about finishing the connection of the front stem according to Witsen.. Replica of Barents' ship.. So I added it. The cuts were made with a 0.15 mm thick razor saw, and 0.09 mm black paper was placed.. Klinkbout will be added after grinding.. And now really a balcony.. -
Thank you for like! Channels glued.. I created reinforcing knees. System ala marsalv...😇 The elbows will be reinforced with 0.5 mm pins. Finally wax.. -
Thank you for like! Channels. I had to measure their width so that the ropes would not rub against the railing, because what is painted in the plan does not agree. Channels secured with steel pegs.. So far dry.. -
Thank you for your input and thoughts. Building models according to plan or their historical accuracy is a dilemma that every builder must face. Fortunately, nowadays there are already enough quality plans. I waxed the railing, covered the part where there would be other equipment.. There really isn't room for a Pin Rail on the aft deck on this plan.. Preparation for channels.. -
Well-meaning criticism is appropriate, from a person with your experience, Ab is beneficial. I know from the beginning that the plan of this ship is not good, the authors drew from more sources. The pins in the side railing of Dutch ships can be seen in the pictures, I found a debate on the Czech forum and there the most detailed picture of a Dutch warship - EENDRACHT from 1655 by van de Velde, he has pins in the railing. Another warship.. So the small possibility of placing them on warships was possible !? The Dutch double deck according to the model in the book Der Hollandische Zweidecker von 1660-1670 by Heinrich Winter also has pins in the railing, here this model by Alexander Bielov.. I build the model as competitive, here the main consideration is the agreement with the plan, every change must be documented. So I'm looking for historical data.. -
I appreciate your words Hubacs and Oliver Finished railing of the poop deck.. Drilled all holes for pins in the side railing.. Can I have a question about Ab Hoving? I'm looking for information on other ties that are not on the plan. Can I use the inner railing as on other models? Or Pin Rail on the inside? What is historically more faithful? Thank you. -
That's great news, Abe. I'm really looking forward to this tour. I envy Peter that he has already started the construction of the Vitsen pinas !! 💣💥
Thank you for like! So I finished the front deck railing.. At the stern are the finished pillar rails of the poop deck.. -
I continue to install the railing posts. Some parts are drilled at an angle by tilting the boat with a stand .. And I created a sailor figure to measure the equipment.. -
Greetings and thank you Radek. I won't find out on the plan sheets, everyone shows a different dimension ...⁉️ I made a compromise, 7 mm wide, which is 42 cm in fact, which could be .. 🙄 -
Thank you very much Hubacs Historian, I am very pleased with the praise from a person with a sense for detail. I created an upper mirror.. I draw the mooring places of the rigging in a low-quality plan. I used a plan from Ab Hoving's Zeehaen fluite.. -
Papegojan 1627 by mati - FINISHED - 1/48
Ondras71 replied to mati's topic in - Build logs for subjects built 1501 - 1750
Absolutely famous building Maty! Real inspiration !! Ondras -
Thank you Tony The first part of the railing is finished, the system of sliding the hollow posts on the pins works.. Reinforced with long pins.. Further work, installation of the top mirror plate.. -
Thanks for the like. On a vertical drill, I drilled holes for the support bars of the railing posts. These guarantee the exact shape.. And he completed all the wales at the stern.. -
Thank you very much Hubacs Historian. I continue with the railing of the aft deck .. The edges of the painted strips are fragile, I will have to retouch in one place.. Rounded railing parts .. I tried the wax with which I will paint the moldings of Wales, if it does not destroy the paint with the varnish and it's great.. -
I appreciate your words Backer and Louie da fly Thus covered the railings of the main deck and stretched from it wales. Railings and rails glued with long pins.. -
Czech modeler Doris Obručová advised me to use an external matt spray topcoat. I tried matt Vallejo varnish .. Tests outside the ship have shown the best way to pour a horizontal layer of paint ... Bingo Then dry with a hair dryer and .. the surface is matte! Ship finally unpacked .. I will not edit any more..💥 O. -
The dyeing is already finished after two months, the retouches have stretched a bit. Red sprayed somewhere again. I damaged the acrylic paint with alcohol .. Spraying with matt clear lacquer is also not without problems, semi-gloss paints do not want to matte. I'm studying how to do it.. -
I'm fighting green. The first did not cover at all .. I had to use the darker one. At the same time, the front wall was redesigned.. The result is not so bad.. Retouches are still waiting for me and matte lacquer comes on top..🧐 O. -
