Ondras71
Everything posted by Ondras71
  1. Drilled holes for hinge hooks. The blankets of the shooting ranges are kept, I will place them at the end of the construction.. And I used the week of incapacity for work to progress in the construction..😱 Previously prepared gratings for the aft deck were shaped.. And according to them, deck beams are created.. And added previously prepared knees.. And now I have to fill the lower deck and close the deck..
  2. Thank you very much friends. I'm just trying to look at someone else's job and deal with it.😎 Hooks for goal hinges. Tube 1 / 0.2 and nails 0.5 mm. Very small ..😱 Parts folded and soldered .. The hooks turned out well.. I have already received yarn for knitting ropes, so the production of ropewalk awaits me, I am already studying instructions on how to knit..🛠️ I ordered other light shades for the test, which will be the best...
  3. I equipped the hatches with hinge caps. From the waste, I created an imitation of a loophole with a pitch of hanging eyes..🛠️ Drilled and nailed with homemade 0.5 mm wire nails. Surface waxed..
  4. I thank everyone for the like..😇 I hung the rudder... Further work hinges on loopholes. Previously ground from 0.2 sheet and now soldered 1 / 0.2 tube..
  5. So in the end, the rudder hinges, which I made from a weak material, were damaged by the acid so that they could not be used, they softened completely.. I made new 0.3 mm thick sheet metal and 1.3 / 0.2 tubes.. Extra work, but in the end the hinges are 100% better than the first..👌 Rudder hinges placed..
  6. I created the posts of the stand .. Temporary struts are left for further construction to prevent movement to the sides.. And finally, the handrail of the balcony railing .. waxed ..
  7. Thank you so much Roger.. I thank everyone for the like..😇 I want to finish the rudder before placing the model on the final stand. After a longer time of soldering hinges .. Ready for cleaning and blackening.. I found that cleaning with nitric acid must be done carefully, 0.2 mm sheet metal and tubes with a wall of 0.1 mm are terribly tricky, especially the tubes can be quickly etched by acid .. I had to replace one..😱
  8. Thank you so much Backer.. I thank everyone for the like..😇 Balcony railing glued.. During drying, I stuck a lion statue firmly.. ..and began manufacturing the rudder.. Finished railing waxed, only a handrail..
  9. Thank you so much taby.. I thank everyone for the like..😇 Dark wood posts. When milling with white glue, it is glued to the board and then soaked.. Construction glued to the template.. Railing dry located..
  10. Thank you so much Backer. I thank everyone for the like..😇 I continue to shape the balcony railing on a template made of waste..🛠️ Now it's time for the dark wood posts..😴
  11. Hello. I carved the guide rail on a FET saw according to Andrej Kudin. 2x 45 degrees, then an octagon is created on it..👌
  12. Galion completed .. After waxing..🎨 And with a statue.. Another job is the balcony railing. I'm slowly creating a 3D shape on a template..🛠️
  13. Greetings Bryantes. A clever start with a small boat and then a bigger building.I keep my fingers crossed for a start.
  14. I reinforced the fragile cracked rails with pins.. I patinated the lion statues and other wooden ornaments, heads and cutters. All oil paint..🎨 I continue on the galion..😵
  15. I wish everyone a lot of success until the new year 2022, peace of mind modeling and especially health!
  16. I continue on the galion. Making head rails... The years of wood betrayed me while sanding. It could be glued ..😵 I carefully place ..
  17. After a really long break caused by many "circumstances", I start working on the galion again.. Galion spikes.. Another will be the production of gallon railings..
  18. Thanks for the like.. Grate head deck pinned pins 0.5 mm.. Sidewalls glued .. I'm creating a decorative head deck ..
  19. Thank you very much Steve and Patrick!! Thanks for the like.. I fixed an old bug where the Catheads pulleys were not in a vertical position.. Now I'm creating a head deck grate.. Head deck side pillars..
  20. I work on the sides of the head deck.. The ship gained a new image..🎨
  21. Thanks for the like. I decided to keep the lion statue only in red, that's how I found it..😎 historical picture.. model R.L. from the Gdańsk Museum.. replica Duyfken.. I finished the head deck frame. Again, I came across different dimensions of the drawing of a lion statue on the plan sheets ..😵 I had to lower the lion's back.. This is the size of a lion statue .. Now the statue will fit under the head deck..
  22. Thank you all..!! I sprayed red. Varnish for that. Next in line will be a retouch to highlight the details.. Glued Knee of the head.. Added clinkbout ..
  23. Thank you very much Patrick.. The words of a sculptor I read still ring in my ears. He said he had not created the statue, it was inside the block he was working on. Just removed the excess material ...😇 I tried to create even more details, now it's done ..👌 Basic white spray.. And now red..🎨
  24. Thank you very much Patrick and Gary. Thanks for the like.. The fight with the lion is still ongoing. Gradually in several steps the shape is rounded and slimmed .. Now comes the spray with a primer, followed by red..🎨 And a test on a ship..⛅
  25. Thank you very much Allan and Steven. The lion has a shape.. ..in base color.. ..polished, now I have to fine-tune shapes and details..
