Dave3092
  • Gender
  • Location
    Arizona, USA
Contact Methods
  • Yahoo
    brinker1@pacbell.net
744 profile views
  1. Thanks for your comments. If you are doing this model, one thing I would particularly tell you to watch out for is preparing the deck fixtures and mast tops for rigging ahead of time. Both belay pin racks for the masts required holes to be drilled in a couple of the vertical posts, which would have been easy before I installed them but very difficult afterwards. The same was true with the mast tops. Overall, check the rigging diagrams before you start on the deck fixtures or masts to determine what might need to be drilled before you actually get to the rigging. Good luck! I think this is a good ship to learn modeling on.
  2. December 19,2020 Finishing Touches This build log entry covers the completing the last finishing touches on the H.M.S. Beagle. Anchors The wooden anchor cross members were, unfortunately, cut with the grain across rather than lenghtwise, so both broke when trying to fit them to the anchors. They were, however, easily glued back together. The anchors needed to be filed down (and the holes in the cross members enlarged) to get the pieces to fit. I added metal strapping to the cross members as was indicated in the drawing, although it was not mentioned in the instructions. The anchors were then mounted on the foremast shroud supports and rigging lines run from the davit and a hole in the bow. Aft Lifeboat The aft lifeboat was hung from the davits and secured to cleats of my own construction (as I thought that the rings provided didn’t look appropriate). I set the lifeboat part way down so that it would not hide the stern transom moulding, as I really liked the way it had turned out and wanted it visible. There is even a workmanlike rendition of the British Coat of Arms (at least for that scale). Model Base I thought that the model base was pretty inadequate for the ship. SMS recommends a longer base. Using the recommendations of SMS, I obtained a piece of birth 1x4 plank, then drilled holes in the hull at the intersections of the keel and frames at the appropriate distance. I added two wooden beads to raise the ship slightly off the plank. The end result was a clean and very sturdy base for the ship (the plank weighs about as much as the ship). Flags There were four flags provided in the kit. In order for them to drape more realistically, I mounted them temporarily on wood dowels, sprayed them with starch and then weighed down the bottom corner of the flag until they dried. Here is how they look on the ship. Rope Coils Although not mentioned in the instructions, they were recommended in SMS to add detail to the model. To create the coils for the belay pins, I wrapped the rigging line around a dowel and tied it off adding some fabric glue. I then placed the tied loop on a tying jig I made with two brads in balsa wood. This held the loop in place while I tied the ends and glued. I then trimmed the excess line. In addition, I added four deck rope coils for the Topsail halyards for both masts, the mainmast jeer and the mizzenmast boom halyard. These were coiled on double-sided tape, then coated with varnish. When dried I applied them on the end of the lanyard on the deck. This coil was the very last thing added to the ship. Total Build time – 607 hrs: 23 hrs for the work in this build log entry. Fun facts: The breakdown of the build time is: Build Segment Build Time Percentage Time Preparatory work 45 7.4% Hull & Deck 215 35.4% Deck Fixtures 115 18.9% Masts & Rigging 209 34.5% Finishing 23 3.8% Total 607 100% There are 55 rope coils on belay pins, and 20 rope coils on the deck (including the 16 coils I had added for the cannon earlier). SMS – Ship Modeling Simplified by Frank Mastini
  3. October 29, 2020 Rigging This build log entry covers the installation of rigging on the Beagle. Before starting the rigging, I put a finish on the masts, yards, booms and blocks. For the yards I chose to use a dark walnut stain. As I worked through the rigging, the aft railing came to harm a couple of times. I, therefore, decided to lash together the four corners of the railing to provide additional support until the rest of the ship is finished. They will be removed when the ship is complete. In doing the rigging I decided to follow the order defined in SMS, rather than the instructions provided in the kit. I found that doing a lot of the work on the masts and yards before stepping the mast through the deck made a lot of sense. Also, leaving the lower shrouds to almost the end made it a lot easier to belay the other lines on the interior of the deck. What follows is the order of work defined by SMS and my comments. 1) Fit masts (and hull) with blocks I rigged the blocks in one of two ways. For blocks that needed to be closely tied to a mast or mounted on a deck, I used two strands of #34 black annealed wire twisted together. I twisted about two feet at a time using a drill, vise and guide rod. For block that were on a line, such as a pendant, I seized the line using one strand of #343 wire in a standard seize wrap. Here is a picture with both types. And a picture of the bowsprit showing both. Here is the hull with blocks installed. 2) Rig futtock shrouds to masttops I originally tried clamping the futtock shrouds and deadeyes to the masttops or tying them to the masts, but I found that neither way stood up to reeving the upper shroud deadeyes to the futtock shroud deadeye or rattling down the upper shrouds. I ended up gluing the futtock shroud deadeyes to the masttop. Here is one unsuccessful attempt using clamps. 3) Rig lower shrouds to mast I seized the shrouds using a length of #34-gauge wire, similar to the blocks. To keep track of the lower shrouds, I coded them with pieces of twist tie from 0 to 3, 5 or 6, i.e. 0,1,10,11,100,101. 4) Rig topmast shrouds to topmasts 5) Fit ratlines to topmast shrouds Here is a partly completed ratline installation on the upper shrouds. There is more detail on ratline installation below. 6) Fit the yards with blocks and pendants I used the same techniques here as for the mast and hull. 7) Put the yards on the masts and rig the halyards and yard lifts It was much easier to rig these lines with the mast held in the vise, rather than trying to work with the mast installed through the deck. I did not glue any of the yards to the masts. I thought it would be more instructive working with the rigging if the yards could move. Here are the masts and yards with blocks and pendants 😎 Put the gaff and boom on the mast and rig lines for them Although not included in the instructions, I added a boom rest to the mizzenmast. Like the yards, I did not glue either of the booms to the mizzenmast. 9) Step the masts through the deck This step was pretty easy, as I had previously squared off and fitted each mast to its mast box in the hull, so alignment was built into the way the masts were constructed. Here is the ship with the masts stepped, included the bowsprit. 10) Belay the yard lifts and halyards I created a belaying tool by taking a piece of coax cable, stripping part of it down to the copper wire, flattening the wire, then drilling a hole in the end. This allowed me to push the line under the belay rack to wrap around the lower part of the belay pin. Tip: If the line goes around the upper belay pin clockwise, then the line needs to be turned counter-clockwise to get the line underneath to finish the belay (and vice versa). When you’re doing this on a boat it is easy, but when you are staring through a number of other lines while trying to belay with two tweezers in a tight location, it is not. Here is the upper part of the mainmast rigging. 11) Bend standing rigging in this order – Foremast stay to bowsprit, all mizzenmast gaff and boom rigging, mainmast stay to foremast and Mizzenmast stay to mainmast To create the loop needed for stays, halyards etc., I wrapped the line around a toothpick, then tied it with two half hitches. The stays were created and installed on the masts in step 1, then connected here. 12) Rig the lower shrouds to their lanyards and fit ratlines to lower shrouds SMS suggested a single deadeye gauge in the outer holes of the deadeye, but I found this too unstable when trying the seize the line around the upper deadeye. So I created two gauges from staples (widen to the correct length for deadeye separation). (Gauge next to original staple) I placed these in the four inner holes of the deadeye and locked them in with a alligator clip attached to one of the gauges. To install the ratlines, I used a ratline tension tool (suggested on the masts, rigging and sails forum -- https://modelshipworld.com/topic/14818-rat-line-tension-tool/?tab=comments#comment-460820. I put sandpaper on the inside of one of the pieces to help hold the shrouds in place. I hadn’t really seen any good details on how to approach tying the ratlines. Even SMS was somewhat vague on the details. So, I have enclosed my own little tutorial showing the technique I (finally!) found most effective (assumes that the overhand knots are being tied left over right.): a) Tie the first knot on the rightmost shroud. b) Run the line in front of then behind the next shroud, bring it out underneath the line. c) Finish the overhand knot and tighten pulling on the line while pushing the knot against the shroud with tweezers (not shown as I do not have three hands!). If you wanted to work left to right (for instance if you are right handed), I think the same process would work if you tied the overhand knots right over left. Here is the complete ratline run. To ensure that the starboard and port ratlines were at the same level, I measured down from the masttop for each ratline on the starboard side, then duplicate the same distance on the port side. Here are the completed starboard side foremast shrouds with ratlines. 13) Rig the backstays 14) Fit and belay all yard braces I found that installing the yard braces from the top down work better, because the topgallant yard braces are inside the topsail yard braces which are inside the mainsail yard braces. When trying to balance the yard braces during installation, I found it helpful to clamp the line at the blocks on the mast to maintain the proper tension so that the yard remained perpendicular to the keel of the hull. I found that when I started trying to belay the bowsprit yard braces, that the bow belay rack, installed according to the instructions, didn’t allow for the last belay pin to be used, plus the anchoring to the thin strip of wood was too weak. I, therefore, moved back the belay pin rack, drilled two holes through the rack into the deck and added two brads that were glued to the rack and the deck. This worked fine. Here you can also see the bow crosshatching that was installed after the bowsprit woold was completed. Here is the completed rigging – starboard view … and bow view Build time to date – 584 hrs: 149.75 hrs for the work in this build log entry. Next: Finishing Kit Note: I had to purchase additional line to supplement what was in the kit. I bought additional .8mm line, black .4mm line for standing rigging, black .25 mm line for standing rigging and tan .25mm line for running rigging. I ran out of the last as I was preparing to rattle down the lower shrouds. For the .8mm standing rigging I dyed some of the line with a black magic marker. Fun facts: 42% of the time was in installing the shrouds and ratlines (it seemed longer than that!). It took 582 overhand knots (tied with two tweezers!) to install the ratlines on the upper and lower shrouds. SMS – Ship Modeling Simplified by Frank Mastini
  4. January 18, 2020 Masts & Yards This build log entry covers the preparation of the masts and yards and assembly of the masts. However, before I started on that there were a few items remaining to be done on the hull. The shroud supports had been glued to the hull, and now the deadeyes had to be installed. This is when I found out that the shroud supports for the foremast and mainmast were not symmetrical (see 3rd picture below). The deadeye slots were closer to one end than the other, and the way they were manufactured and labeled caused them to be offset differently on each side of the ship. I tried to compensate for that (as well as even out the spacing) when I widened the precut slots to accommodate the deadeye holder. Note: The metal parts in this kit have no deformation capability; they just break. I found this out trying to bend the deadeye holder around the deadeye as indicated in the instructions. To properly align the deadeyes to the shroud lines coming down from the mast, I construct substitute masts of the correct height, then ran thread down to each deadeye slot, so that I could determine the proper angle to put on the deadeye link when mounting it to the hull. This was suggested in SMS. For the mizzen mast deadeyes, I found that the provided deadeye links were too long for the hull that is available at the stern, so I shortened and re-bent the link to fit the available space (this is the only metal that is pliable). After installing the deadeyes, I covered the edge of the shroud support with a piece of mahogany lath, which seem to blend very well with the shroud support wood. The second item was crosshatching in the bow. It is shown in one of the instructions, and the material is provided for it, but there is no mention of adding it in the instructions. To fit the material in the bow space, I created poster board templates for the port and starboard sides to give me a starting point for cutting out the crosshatching. I then put together a grid of laths to accommodate the templates, cut out the pieces, and sanded them until they fit into the bow area. These will be installed after the bowsprit woold is completed. Now that I was ready to start on mast construction, I started by building the masttops and crosstrees for each mast. Although not indicated by the instructions, I added a chock between each mast for all the masttops and crosstrees, as suggested by SMS. I believed this would aid in aligning and securing the masts during assembly. For the main and fore mast masttops, I added bolsters, also suggested by SMS, to protect the shroud lines extending down from the masts. I then proceeded with cutting and shaping the masts and yards. I drilled holes in a 2x4 and labeled each hold with the respective mast or yard putting them in order from stern to bow. I cut out all the masts and yards from the supplied material leaving excess material to be used to handle the wood through the shaping process. I shaped the masts and yards as needed by setting up a homemade lathe using my electric drill (another SMS suggestion) with a loop of Velcro (felt side) to hold the other end of the wood. The other piece of Velcro was over the trigger to keep the drill on. As I mentioned previously, I had built square mast boxes in the hull for the three masts, so I now needed to square up the masts to fit into those boxes. I did that by placing the mast into the vice, leveling both, then filing down each side of the mast – another MSS suggestion. I did the filing iteratively with testing the fit into the hole until I achieved a tight fit. I then labeled the side of the mast facing the bow, so that I could build the rest of the mast segments on top facing in the correct direction. I used the same process to square the tops of the masts. The mizzen mast boom and gaff required yokes, which again were indicated but no material was provided. So I fashioned the yokes out of a bit of oak by drilling the mast hole, then cutting the yoke out using the hole as the base. In addition, I drilled a hole in the bowsprit mastcap for the martingale. The yards, booms and mastcaps were supposed to be either dark walnut (instructions) or black (paint diagram). I chose to go with the former. The last thing to add was the mast woolds on the main and fore masts (see picture below). Here the amount of 0.8mm hemp rope was completely inadequate to do the woolds, no less that other uses for that diameter on the ship, so I had to order some additional rigging line. Now that I was ready to assemble the masts, I first ensured that the workbench was level. Since the masts sit vertically in the hull, then I could everything as it was being added with a level. In addition, I verified that the masttops and crosstrees were parallel to the deck planking, and I tried to make sure that the masts were parallel where they overlapped. I also verified that all the masts were aligned when looking from bow to stern and vice versa. Since SMS recommends rigging the masts before stepping them, I inserted the masts into the hull for assembly, but I did not glue them to the hull. Lastly, I put a rope gannion on the bowsprit jib. It wasn’t shown in the instructions or diagrams, but it did appear in a diagram in MSS, plus it makes a lot of sense to hold the jib boom in place. Build time to date – 434 hrs: 59.5 hrs for the work in this build log entry. Next: Rigging PS - 95% of the time was in preparing the materials; only 5% of the time was spent in actually constructing the masts. SMS - Ship Modeling Simplified by Frank Mastini
  5. January 18, 2020 Masts & Yards This build log entry covers the preparation of the masts and yards and assembly of the masts. However, before I started on that there were a few items remaining to be done on the hull. The shroud supports had been glued to the hull, and now the deadeyes had to be installed. This is when I found out that the shroud supports for the foremast and mainmast were not symmetrical (see 3rd picture below). The deadeye slots were closer to one end than the other, and the way they were manufactured and labeled caused them to be offset differently on each side of the ship. I tried to compensate for that (as well as even out the spacing) when I widened the precut slots to accommodate the deadeye holder. Note: The metal parts in this kit have no deformation capability; they just break. I found this out trying to bend the deadeye holder around the deadeye as indicated in the instructions. To properly align the deadeyes to the shroud lines coming down from the mast, I construct substitute masts of the correct height, then ran thread down to each deadeye slot, so that I could determine the proper angle to put on the deadeye link when mounting it to the hull. This was suggested in MSS. For the mizzen mast deadeyes, I found that the provided deadeye links were too long for the hull that is available at the stern, so I shortened and re-bent the link to fit the available space (this is the only metal that is pliable). After installing the deadeyes, I covered the edge of the shroud support with a piece of mahogany lath, which seem to blend very well with the shroud support wood. The second item was crosshatching in the bow. It is shown in one of the instructions … and the material is provided for it, but there is no mention of adding it in the instructions. To fit the material in the bow space, I created poster board templates for the port and starboard sides to give me a starting point for cutting out the crosshatching. I then put together a grid of laths to accommodate the templates, cut out the pieces, and sanded them until they fit into the bow area. These will be installed after the bowsprit woold is completed. Now that I was ready to start on mast construction, I started by building the masttops and crosstrees for each mast. Although not indicated by the instructions, I added a chock between each mast for all the masttops and crosstrees, as suggested by MSS. I believed this would aid in aligning and securing the masts during assembly. For the main and fore mast masttops, I added bolsters, also suggested by MSS, to protect the shroud lines extending down from the masts. I then proceeded with cutting and shaping the masts and yards. I drilled holes in a 2x4 and labeled each hold with the respective mast or yard putting them in order from stern to bow. I cut out all the masts and yards from the supplied material leaving excess material to be used to handle the wood through the shaping process. I shaped the masts and yards as needed by setting up a homemade lathe using my electric drill (another MSS suggestion) with a loop of Velcro (felt side) to hold the other end of the wood. The other piece of Velcro was over the trigger to keep the drill on. As I mentioned previously, I had built square mast boxes in the hull for the three masts, so I now needed to square up the masts to fit into those boxes. I did that by placing the mast into the vice, leveling both, then filing down each side of the mast – another MSS suggestion. I did the filing iteratively with testing the fit into the hole until I achieved a tight fit. I then labeled the side of the mast facing the bow, so that I could build the rest of the mast segments on top facing in the correct direction. I used the same process to square the tops of the masts. The mizzen mast boom and gaff required yokes, which again were indicated but no material was provided. So I fashioned the yokes out of a bit of oak by drilling the mast hole, then cutting the yoke out using the hole as the base. In addition, I drilled a hole in the bowsprit mastcap for the martingale. The yards, booms and mastcaps were supposed to be either dark walnut (instructions) or black (paint diagram). I chose to go with the former. The last thing to add was the mast woolds on the main and fore masts (see picture below). Here the amount of 0.8mm hemp rope was completely inadequate to do the woolds, no less that other uses for that diameter on the ship, so I had to order some additional rigging line. Now that I was ready to assemble the masts, I first ensured that the workbench was level. Since the masts sit vertically in the hull, then I could everything as it was being added with a level. In addition, I verified that the masttops and crosstrees were parallel to the deck planking, and I tried to make sure that masts were parallel where they overlapped. I also verified that all the masts were aligned when looking from bow to stern and vice versa. Since MSS recommends rigging the masts before stepping them, I inserted the masts into the hull for assembly, but I did not glue them to the hull. Lastly, I put a rope gannion on the bowsprit jib. It wasn’t shown in the instructions or diagrams, but it did appear in a diagram in MSS, plus it makes a lot of sense to hold the jib boom in place. Build time to date – 434 hrs: 59.5 hrs for the work in this build log entry. Next: Rigging PS - 95% of the time was in preparing the materials; only 5% of the time was spent in actually constructing the masts. MSS - Model Shipbuilding Simplified by Frank Mastini
  6. Allen, As it happens, a duplicate copy of the plans were included in the kit that I purchased. I would be willing to send them to you. Send me a private message. Dave
  7. September 18, 2019 Last Touches to the Hull This build log entry covers the remaining items to be attached to the hull / deck. Before I start, however, I wanted to mention two things that were useful during the last build, but I forgot to mention. To hold down things being glued to the deck, I created 3 sandbags, which had sand double bagged in plastic zippered bags. They were very useful in applying pressure to the deck fixtures while the glue was drying. Also, I decided to update the wood inventory to compare what I had left to build with the material on hand. This was important in deciding what piece of wood to use when it was not specified in the model instructions. This proved doubly useful for this segment of the build. This part of the build covers the steps, shroud supports, lifeboats and cannons. In some ways this was one of the most difficult sections, as there was little information on the construction of the lifeboats and cannons, and I felt the sparse mounting of the cannons was inadequate. The wood inventory told me that but I didn’t have enough 2x3mm wood available to use that, so I used 2x4mm wood, which I have plenty since I had purchased an additional meter of it earlier. I think the steps turned out well with that material. When installing the shroud supports, I decided to add a 2x4mm beveled brace (since I knew I had enough) under the shroud supports to provide additional support to them. It seems likely that would be helpful when rigging the shrouds later on. There were no instructions regarding the assembly of the lifeboats, so I had to improvise based on the diagrams and pictures available. Since the wood inventory told me that I did not have enough wood from the kit to provide the keels, railings or inner railings, I decided to acquire some wood that was just about the right width from a well-known, but unnamed coffee shop. With a little sanding, they were the perfect width for those additions to the lifeboat hulls. Since the aft lifeboat was 75% the size of the main lifeboat, I made the keel, inner railings, aft bench and bow bench 25% smaller on the aft lifeboat, but I left the other bench sizes the same on both. I installed the keel, railing and inner railing, then stained the railing and inside of the lifeboats. The benches were made from maple lath and glued to the inner railing. For the bow and aft benches, I made a tape template from the inside of the railing, and I used that for the first cut of the bench, then shaped as needed. After installing the benches, I shellacked the railings and interior and painted the outside of the hull to finish the lifeboats. In the kit, the cannons were shown on the deck with nothing holding them in place and no instructions about their assembly. I thought that looked too simplistic, so I decided to add side tackles and a breech rope to each cannon. I purchased the smallest blocks available from Modeler’s Central and used tan sewing thread for rope. [Kudos to Modeler’s Central – four of the blocks were misdrilled and they sent me replacements free of charge!]. I also added an elevation block to each carriage. It was shown in the diagram, but not mentioned in the instructions. I also drilled a hole on each side of the cannon carriage towards the rear to mount the side tackle block. I positioned the cannon carriages on the deck, which was covered In tape. I marked the position of the wheels, then cut out the tape and sanded the exposed deck so that the glue would adhere. I then glued the carriages to the deck. I stropped the blocks with #34 gauge black annealed wire (a suggestion from MSS). I used an alligator clip to hold the block while attaching the strop. I then attached the breech ropes and side tackles to a set of half ring with a straight end. After building each side (for 4 cannons), I inserted the straight ends into holes drilled into the deck. I then installed the side tackles and breech rope securing the side tackle block to the cannon carriage. That was followed by installation of the cannon with the holding brackets followed by attachment of the breech rope. I completed the cannon installation by winding the appropriate amount to rope to run out the cannon next to each side tackle. There were created by winding them on two-sided tape, then applying shellac to hold them together. I then lifted them off the tape and installed them on the deck overlaying the end of the side tackle rope. [This technique was suggested by barkeater in the Rigging Forum]. After the cannon were installed, I attached the main lifeboat amidships. Finally, I marked the waterline on the hull. After fooling around with a pencil and bracket, I realized I could use a laser level, sitting on my toolbox. As long at the hull and laser level are both level, it makes it very easy to draw an even line across the contours of the hull. Build time to date – 374.5 hrs: 54.75 hrs for the work in this build log entry. Next: Masts and yards MSS - Model Shipbuilding Simplified by Frank Mastini
  8. July 12, 2019 Deck Fixtures This build log entry covers the fixtures (or deck furniture as Fernando calls them!) on the decks. Given the conflict between finishing the deck and attaching the fixtures, I decided to build all the fixtures attaching the ones that I could where it would not create a problem when it came time to finish the deck. For example, I attached the anchor davits and cleats to the foredeck, but I did not attach the ladders to the foredeck, as I needed to finish behind them. Since I was doing so much work on the deck, I decided I needed a better holding mechanism for the full. I added an angled brace to the keel in the front and a rubber band in the back to push it against the brace. The first brace did not hold up, so this is version 2. There are a lot of pieces for this part of the project, so I used egg cartons to store the completed pieces until I was ready to install them. This way I could keep them in order and tell starboard fixtures from port fixtures. For all the posts in the fixtures, I added pins to help hold them in place (another recommendation by MSS). This includes the binnacle, the belay pin racks around the masts, and the balusters for the railing around the quarterdeck. To drill out the belay pin racks, I created a die from balsa wood so that the holes would be properly positioned and evenly spaced. I used this technique for all the belay pin racks. To try to make sure that the hatches and skylight moldings were square, I glued them together inside the square corner of a box. I put wax paper underneath so that the fixture would not get stuck to the box. In order to be able to drill the balusters for the quarterdeck railing, I created another die that would mark the center of the baluster so that I could drill it (there was not a lot of room for error on the baluster!). Here is a completed set of balusters for one side of the railing. I marked the top and bottom of the railing while side by side to ensure uniformity in baluster placement. I used the end of a brad in the hand drill to make the corresponding holes in the railing and deck for the pins. This same technique was used on the other fixtures with pins. Here are the decks with everything installed before the finish was applied. The green tape masks off areas for gluing on fixtures that will be added after the finish. … And here are the decks after finishing of the deck and the remaining fixtures, then installing everything. · Anchor davits, cleats and bowsprit belay pin rack on the foredeck · Binnacle with bell, ladders, foremast belay pin rack, forward belay pin racks and cleats and the forward hatch on the main deck · Second and third hatches and lifeboat cradles · Pump, mainmast belay pin rack, middeck belay pin racks and cleats and forward skylight · Middle skylight, ladders to the quarterdeck, helm and hatches to quarterdeck on the main deck · Quarterdeck railing (including belay pin rack), aft skylight and davits for aft lifeboat on quarterdeck Note: The kit provided windows for the three skylights, but was short two windows for the second skylight. I made up the remaining two windows using extra window in the middle window fore and aft, as they are the hardest to see (normally!). Build time to date – 319.75 hrs: 61 hrs for the work in this build log entry. MSS - Model Shipbuilding Simplified by Frank Mastini
  9. Hi, Fernando! Yes, the deck fixtures are next. There are a lot of pieces, but it seems pretty straight forward (famous last words!). Looking forward to getting started. PS I like your emoticon! Dave
  10. February 18, 2019 Complete hull, decking and hull attachments First, I want to give credit to MSS for the deck plank cutting jig. I should have mentioned that in the previous blog. Also, the use of a compass for drawing cut lines on the edge deck planking (mentioned below) was suggested by the article, A primer on planking by David Antscherl, that I found in the database of articles on Framing and Planking. I continued with completing the main and fore deck. I used a compass set to 1 or 2 board widths to provide an initial cutting guide for the edge planks. This made fitting the planks go a lot faster and cleaner. Here is the ship with all decks planked. A closer look at the plank fitting on the main deck. I then went back to build in gunwales on the open portion of the main deck (as mentioned in the previous blog). I added a 2 mm wide length of underplanking on each side, then covered it with Maple lath on the front and top. I also add Maple lath to each end of the opening. I think the result turned out rather well. The next step is planking the keel. Before starting that I drilled out a hole for the Bowsprit woolds. The hole is a little ragged, but I’ll clean that up when I cover it with planking. I planked the entire keel bow to stern, including the edge of the keel. Note the hole for the bowsprit woolds. In order for the planks on the keel bow to be at a consistent angle, I set up this cutting jig. However, I don’t think planking the edge was planned for in the kit, because I ran out of the walnut planking. I’m guessing that it wasn’t to be planked as it is for the most part painted (similar to the inside of the bulwark). However, I have decided to leave the hull unpainted to better see the beautiful woods used to make it. I ended up ordering additional planking from Modelers Central in Australia. While ordering, I got a 2mm x 4mm walnut plank to replace the one I had to use on the port side sheerstrakes (along with a 2mm x 2mm plank) when I was short of the two 2mm x 3mm walnut needed. I also picked up a couple of blocks missing in the kit and some blocks for anchoring the cannon on the deck. The company was easy to work with and delivered as promised. After completing the keel planking, I planked the rudder. The rudder came without the cutouts for the hinges, so I had to do that before planking. To create the dowel for the tiller, I rounded off the edges of a 2mm x 2mm piece of walnut. After all planking was done, I applied diluted wood glue to the edges, wiped off the excess, and sanded (another MSS technique). This is the same thing I had done on the hull and the decks. It does an amazing job of smoothing out the planking. I attached the rudder to the hull with the three sets of hinges then finished the lower part of the keel, rudder and lower part of the hull. Since I saw many recommendations of using diluted shellac for a “primer” coat, I decided to use shellac for the finish. I did the primer coat, the two additional coats of shellac full strength. I like the look and feel of the finished product. Next was putting the fenders on the aft section of the ship. This is where I found out that 25 year old walnut (yes, the kit was 25 years old when I got it!) was pretty brittle. Out of the six pieces I originally cut, only three survived carving out the hull profile. The other three I made from the recently purchased 2mm x 4mm walnut. It was much easier with the new wood. I used my notepad with the various lengths to keep track of the fenders. The poster board template I used to make the initial cuts is also shown. The metal pieces were the next things I worked on. As you can see, after banging around in the box for 25 years, they were pretty beat up. I used steel wool on them, then re-sprayed them. The taff rail was the only piece that survived pretty much intact. I did the following detail painting on the metal pieces: · Bow Serpents – I painted in the grooves with brown. · Taffrail - I painted the background brown to bring out the carvings. · Transom molding – After some research, I realized that it was the Royal coat of arms of the United Kingdom. I tried as best I could to replicate that. Given the size, I thought it turned out rather well. The instructions had minimal painting instructions regarding the transom molding and none for the other pieces. However, the pictures on the box had shown the painting indicated for the other two items. All metal items, including the rudder hinges, were attached using epoxy glue. The installation of the bow decoration, bow serpents and bow serpent bottoms were shown in Diagram 9 of the instructions, but no instructions were given regarding their installation. In addition, the bow serpent bottoms, which are indicated in the parts list to be metal, were missing from the kit. I decided to carve them from some existing fir that I had available. Here is how they looked after rough carving. In the end, I thought they turned out pretty well. I filed down the attachment points on the bow serpents to more closely match the hull / keel surface and provide contact area for the epoxy glue. TIP: The metal in this kit is very brittle and does not bend! Believe me, I found this out the hard way! The last item to be installed was the transom molding. I thought that the windows provided in the kit looked unfinished in the molding (plus the lines framing the windows did not match the actual opening too well). I decided to frames the windows with small pieces of Tanganyika wood (used for the decks and hull). Lastly, I decided to put a little more color to the inside of the bulwarks, so I stained the bulwark with a maple stain and painted the stanchions black. Build time to date – 258.75 hrs: 57.5 hrs for the work in this build log entry. MSS - Model Shipbuilding Simplified by Frank Mastini
  11. Thanks to everyone for their comments. This gives me options to consider.
  12. I am at the point in my build of the HMS Beagle that I need to start thinking about finishing the wooden planked hull. I am looking for suggestions on the best products, finish and application technique to do this so the wood is shown to best effect, yet it is easy to maintain after completion (i.e. doesn't attract dust, etc.). Product - Tung oil, shellac, spar varnish or other Finish - matte, satin, semi-gloss or high gloss Application - brush, spray, cloth or other Also, I understand that is hard to glue the detail work to the deck or hull after it has been finished, but it would also seem to be hard to finish the deck or hull with all the detail work on it. Comments? Thanks!
  13. 10/19/18 Happy Thanksgiving! This is a special post to recognize 200 hours of effort so far on the Beagle. In this entry I opened up the bulwark between frames 4 and 8, added the railing and started planking the decks. I found that for this work, the best way to hold the hull was to put it on the keel stand, but put the bow in the vice to stabilize the hull for the work. As I opened up the bulwarks, I realized that the original intent of the kit was to have the deck below the level of the step that defined the bulwark on each frame. Unfortunately, the way the frames were cut the top of the deck came out even with the step. I decided that I would complete the work on the deck, then add a small section of bulwark at the bottom of the openings between frame 4 and 8 to conceal the interior deck construction. This will be done in the next phase. Before installing the railing, I trimmed back the frame extensions to about 1 – 2 mm. The instructions suggested doing this after the railing was installed, but I thought it much easier to do before the installation. I found the best way to do that was to use a hack saw blade, as it is flexible enough to work down along the bulwark. I then added railing around the perimeter of all decks, piecing the fore deck to match the curve of the hull. To ensure that the rail was in the proper position over the open portions of the deck, I rigged a segment of bulwark (previously removed) to the standalone frame extensions with a rubber band. Also, to try to ensure the 1 mm overlap of the railing over the bulwark, I used a piece of 1mm lath laid on the bulwark when gluing the railing. After the railing was installed, I washed the joints with diluted glue and sanded the railing to fill in the joints. Tip: Since there is very little to hold the railing in place, it is very important to take the time to bend the railing, both horizontally and vertically, so get an exact a match as possible to the compound curve of the hull. Once the railing was in place, the frame extensions of frames 5 to 7 were removed. Again, I used the hack saw blade, since it was flexible enough to lay flat on the false deck to cut off the frame extensions. With the railing in place, I was ready to start on planking the deck. I built two jigs to help with that. The first jig had an 80 mm length on one side and a 40 mm length on the other. Combined with a straight edged side cutter, it was easy work to prepare the plank boards. The second jig was used to add holes at the end of the planking to simulate nails. I put two tacks in a couple pieces of poster board, taped them together, then mounted them on a wood platform high enough to get the planking under them. By pressing down on the nails, I could quickly add the holes. I then highlighted the holes with a pencil point, and ran the pencil around the edge of the planking to help define the edges when assembled. To help ensure that the plank ends stayed in alignment across the deck, I made a small right triangle out of poster board and used it to mark out the joint lines on the deck. The decking itself went on pretty easily. It was fascinating to see yet another compound curve as the main deck is concave fore to aft and convex from the center to either side. It makes a lot of sense to managing water on the deck, but I wonder what it must have been like to walk along the deck that was continuously sloping. [A side note: We were in Carmel-By-The-Sea recently, and I stopped in at a nautical shop that had a number of models. I examined them with great interest, but one thing that struck me immediately was that the decks were flat!] I finished the bridge deck completely (hurray!) and main deck, except for piecing around the perimeter. I will do the fore deck last. Build time to date – 201.25 hrs: 19.75 hrs for the work in this build log entry. MSS - Model Shipbuilding Simplified by Frank Mastini
  14. Thanks for your kind comments. It has been tough at times to keep from pushing through to get on with the next part of the build. However, I am thoroughly glad to be done with the hull after spending over 180 hours on it. It doesn't look like anything else (with the possible exception of the rigging) will be as labor intensive.
