Everything posted by Valeriy V
Yes, Keith, this is the only and main mistake when painting brass. The metal must be perfectly free of grease. If the parts are small, then I clean them by dipping them briefly into a solution of nitric acid or for a longer period into the solution NaOH. If the surface is large, then I use the method of painters in car repair shops - gasoline caloshes and a rubberized napkin. All other solvents only spread the fat layer over the part but do not remove it. I want to clarify that all this applies to the conditions in which I live.
Keith! Soldering such large sheets of brass is quite boring and monotonous. You can solder them in sequence one after another. The brass sheets are massive and do not have time to warm up enough for the previous seam to fall apart from overheating. Everything is very simple here. The deck metal sheets were laid overlapping. Therefore, I need to show on the model steps with a height of approximately 0.2-0.3 mm. Cardboard does not have the properties I need for modeling. Therefore I don't consider it as useful material. Wood veneer with a thickness of 0.2-0.3 mm behaves like a sheet of paper. It has no rigidity and is very sensitive to changes in humidity.
