HOLIDAY DONATION DRIVE - SUPPORT MSW - DO YOUR PART TO KEEP THIS GREAT FORUM GOING! (Only 66 donations so far out of 49,000 members - Can we at least get100? C'mon guys!) ×
Valeriy V
Everything posted by Valeriy V
  1. Precision is essential when drilling the holes; this is the most difficult step. This is achieved using a coordinate table on a drilling machine. The brackets themselves are soldered sequentially, using the pre-drilled holes. And there's nothing complicated about that.
  2. Thank you all for your feedback and likes, and I continue... Mainmast. Soldering the ladder brackets and assembling the tripod.
  3. Yes, I understand you. Apparently, it's something like this machine. On these rollers, the square that is produced is indeed far from ideal.
  4. This is an interesting machine. I would like to see it. Can you show it?
  5. After removing the wire from the drum and removing the manufacturing allowances, I obtained 2.1 m of the semicircular profile I needed. I think that with a little modification to the drum, it could also be used to produce a square profile.
  6. After being sharpened with a cutter, the wire on the drum took on this appearance.
  7. Then I wound it with 2 mm diameter wire and inserted the drum into the lathe. The length of wire that fit onto this drum was 2.3 m.
  8. Hello everyone! Today I'll share a method for making a semicircular brass profile. Perhaps this will be useful for someone building models. The simplest way to create a semicircle is with a jewelry die. However, when the wire diameter increases beyond 1.5 mm, significant physical force or a special drawing mechanism is required. I decided to make my life a little easier and made this drum.
  9. Yes, I had that choice, but instead of wood, I was going to use plexiglass. However, after thinking it over, I realized that making such a plexiglass dummy would take me much more time than soldering a brass frame.
  10. Details of the foremast before and after installation on the forward superstructure.
  11. Greetings everyone, I'm continuing my work after a short break. The photo shows the soldering process of the artillery fire control station. It is located on the cruiser's foremast. Frame assembly:
  12. And now all that remains for me is to make the parts of the required sizes and solder them together.
  13. Two parts #2 are a truncated cone with previously known parameters. Using a calculator (online) to calculate the dimensions of the truncated cone scan, I get the dimensions I need. https://stanok74.ru/klientam/poleznye-formuly-i-dannye/kalkuljator-rascheta-razvertki-konusa-iz
  14. Phil, thank you for your kind words, I am flattered! In this situation with the manufacture of a sloping visor, everything is also quite simple. If the part is of a rather complex configuration, then I try to apply the following principle: - divide the complex part into several very simple ones in configuration - concentrate your efforts not on the manufacture of one very complex part, but on the assembly of several simple ones into one single and complex part.
  15. Jan, thank you for your feedback! And I will allow myself to comment on it a little. What you called "gifted" I still put in third place in importance. Experience and skills definitely claim second place. But in first place should be the necessary high-quality machines and tools, because without them the necessary experience cannot appear and no gifted can help with this.
  16. Thanks, Gary! There's really nothing particularly complicated about it. The main condition is to maintain the manufacturing accuracy of the parts within 0.1-0.2 mm. And then their assembly by soldering is not difficult.
