Everything posted by Valeriy V
Nils, it's great that everything is getting better. I look forward to an interesting continuation of your work.
- 313 replies
- lightship
- Feuerschiff Elbe 1
Yves, the need to cover the hull of the model with fiberglass and epoxy resin of static models is the result of the experience of previous generations of ship modelers. 1) If you leave the hull unprotected, then, as a result of the effects of moisture and temperature changes on the wood, the contours of the wooden slats of the sheathing will appear through the layer of paint 2) For hardened epoxy resin, fiberglass plays the role of steel reinforcement in reinforced concrete structures. Without fiberglass, the hardened epoxy resin will gradually crack and peel off from the hull.
