Valeriy V
Everything posted by Valeriy V
  1. Thanks, Gary! There's really nothing particularly complicated about it. The main condition is to maintain the manufacturing accuracy of the parts within 0.1-0.2 mm. And then their assembly by soldering is not difficult.
  2. Hello everyone! I am making progress on the cruiser model. And it is time to solder the smoke pipes. 1. The pipe frames are soldered.
  3. Thanks Phil! For painting, the degreasing process is of primary importance. Surface roughness is secondary. I degrease surfaces with caustic soda (NaOH).
  4. Everything shown in the photos is soldered without using a radiator. I very rarely use a radiator. In this process, you need to determine the correct soldering sequence. First, the most massive parts are soldered and only after that the small parts are soldered. In this case, you can do without a radiator.
  5. Thank you all for your feedback and likes! And I have a small continuation of brass soldering. These are the upper tiers of the bow superstructure.
  6. Congratulations, Pat, on a successful completion of the project! 👍👌 Thanks for the great report and I look forward to your next one.
  7. I am starting work on the metal part of the cruiser model. Assembling the engine room casing.
  8. Pat, you have some great skills building large scale models! I'm really enjoying your thread. I'm curious how you handled the dual steering. What kind of linkage did you use?
  9. Thank you, Tony! Yes, whoever designed these ships did a great job! Their hulls were very graceful and fast.
  10. Hello everyone! I continue working on the cruiser's hull. Installing plates covering the joints of the armor plates.
  11. Hi, Sasha! You have made a wonderful model of an interesting ship! I wish you good luck on your long journey.
  12. Phil, when soldering is done with silver solder, there is no need to worry about the structure being destroyed. This soldering can withstand the heaviest loads.
  13. In this photo the screws are installed randomly and therefore there is an error. When the model is finally assembled all the screws will be installed correctly.
  14. The entire propeller-rudder system is pre-installed on the cruisers hull. The blades will be twisted and the propellers will be fully polished later, before final installation.
