abelson
Everything posted by abelson
  1. Fantastic model. It shows your talent, experience and knowledge. What are the dimensions of the display board? The FA instruction manual says it should be as long as the overall length of the model.
  2. Getting back to rigging the cannons. I purchased 26 gauge black copper at Michael's – it’s more flexibile than 20 gauge that came with the kit. I bent the wire around the single blocks and twisted the wire using flat nose pliers, and then formed a hook at one end using needle nose pliers with round ends. I found that there was enough space at the opposite end of the block to pass 0.3 mm manila hemp tackle line between the block and the wire. I passed the tackle line through bees wax to make it more pliable to work with. Next, I tied the tackle line to the single block which will be attached to the eyelet on the cannon. I followed the same procedure for the double blocks which will be attached to an eyelet on the inboard bulwark. Note: I used double blocks as shown in Figure 20 in the Instruction Manual, but I have read where some modelers have said double blocks are not correct. The tackle line was weaved through the blocks by hand – a tedious job. Reaming the block holes helps in passing the line through. Even with bees wax, the line tends to unravel when it passes through the block. The cleaner the cut at the end of the line, the easier it is to pass through the blocks. A thought I could use a small sewing needle but it’s too difficult to thread the 0.3 mm hemp. So far, four tackle lines complete. The tackle lines look a little sloppy. I'm hoping that they'll look better when rigged on the cannons.
  3. Progress update: Finished all fourteen cannons, except for some eyelets. I decided to replace the #412 (3/16”) belaying pins for the quoins with a larger 5/16” belaying pins. The larger pins look more to scale. Spray painted the gun barrels and the anchors with matte black paint. Decided that I will rig the cannons – purchased additional 3/32” single and double blocks, and cordage, from Model Expo. The 3/32” blocks are very small and difficult to work with, so I used 1/8” walnut single and double blocks instead. I’m holding off on gluing the various inboard fittings until cannon rigging is complete. I painted the capstan and drilled the hole in the deck plank to mount the capstan and added the pawls. I noticed the capstan in the main deck photo on page 42 of the Instruction Manual is quite detailed. I haven’t seen this detail on any member build logs. I’m curious what other modelers have done with the capstan and where I can find details. Added panels to front of quarter deck cabin. Completed the steering wheel. I flopped the position of the steering wheel and the standard because I think it looks better. It’s not authentic, but I like it anyway. Also, added the decorative trim to the stern transom. Painted the trim and the edge of the fancy cap with gold glit. Even though the windows are not in the correct position I’m happy with the way the transom came out. Holding off on Installing the rudder. At this point, I’m about 16 weeks into the build.
  4. Jerry, where did you find the detail for the ships wheel mechanism? This is not detailed on the MS plan sheets. I'd like to add this detail to my build.
  5. I've notice on some FA build logs that modelers have detailed the ships wheel. Can anyone offer advice, photos, details on how to create the authentic wheel mechanism?
  6. Thanks for the explanation and drawing. That clarifies it. The pawls will be an easy add-on.
  7. Thanks, Mark. Here's a picture of the capstan pawl from the plans. I have no idea what this is or looks like. I'm thinking of just leaving it off the build.
  8. To Fair American modelers, the MS kit doesn’t include pawls fittings, and the plans don’t detail them. I’d like to know what other modelers have done to create them. What is the best material to use for eyebolts and padeyes, and what’s the best way to form these? Also, page 42 of the Fair American instruction manual shows a very detailed capstan. The plans don't detail this and I've not seen this on other builds. Where can I find capstan details?
  9. Thanks, Dave. I've been using the kit brass strips. You're right, it is difficult to shape them because they're so small. Nonetheless, I'm continuing with them. I'd like to know what other modelers have used. Did you use the kit eyebolts for the gun carriage? They look larger in your photo.
  10. Decided to concentrate on the guns. I pre-assembled all of carriages. This was a mistake, as I found that the axles are fragile and easily break-off when you try to mount the wheels. The axles are also square and need to be rounded to fit the wheels and to give it an authentic look. I made a prototype. I cut-off the axles and replaced them with tooth picks of the proper length for an authentic look when the wheels are attached. I made the transom, quoin bed and quoin from scrap material. The quoins are small and tedious. I used a #412 belaying pin – I think it looks out of scale. The transoms aren’t really necessary because you don’t see them when the guns are in-place but, for authenticity, I decided to incorporate them. The eyebolts for the gun carriage look too small. I haven’t decided whether to add them. Painting the guns is tedious. I painted the wheels before punching them out. In hindsight, I wish I had done the same with the gun carriages. I’m contemplating spray painting the guns. Not sure if I’ll add the gun straps, yet. I'm satisfied with the prototype – only 13 more to go. Yaks!
  11. Next up, the flag staff chock and socket and the main sheet horse (I used the 0.032" dia wire for this), gangway steps, and quarter badges. On the quarter badges, I used the transom window frame castings for the window mullions and glued a piece of clear plastic to the back of the quarter badge to simulate glass. The problem with this, the quarter badge doesn't sit completely flush against the bulwark. I cleared-the-deck of in-board fittings, cleaned the main and quarter deck plank with alcohol, and applied two coats of polyurethane water base clear satin. I fashioned the rudder from 3/4”x 3/16” stock, shaped it, and added the chatter groove. I made the pintles and gudgeons from 1/64”x3/32” brass strips and attached them with pins. I added pins to fix the rudder to the stern post - holding off on this for now.
  12. Continuing the build, with the planking complete, next came the beak head. I made the cheek knees in two pieces. I traced the profile from Sheet 1 onto wax paper and transferred the image to a piece of stock by using a pointer to mark the outline in the wood. I marked the outline with a pencil and then cut the shape with a coping saw – this worked out well. For me, the head rail knees were the most difficult part. I decided to partially paint the wales, black strake, and outboard bulwark plank at the bow before placing the cheek knees. I made the fore tack boomkins, timber heads, and knight heads. The timber heads, and knight heads are intricate. The cat heads were from laser cut stock. I was experimenting with gold gilt and decided to try it on the beak head - looks good so far. The fashion piece at the transom was a bit of a challenge because of the angles but, once I figured it out, with some filing and shaping it looks natural. Next up, the quarter deck fancy rail, stanchions and cap. The stanchions are intricate. I didn't dowel them. I carved the hance from stock. So that I wouldn't have to carve two, I carved one block to shape and cut it in half to make the two hances. This worked out well and saved some time.
  13. Continuing the build, installed the black strake and main whale, then the inboard and outboard bulwark plank. The inboard plank was more difficult than the outboard plank. I wasn't totally happy with the way that the inboard plank came out, but with some wood filler and sanding it looks pretty good. With trepidation, I turned my attention to the lower hull plank. I read Planking the Built-up Ship Model and was a bit overwhelmed. I tried the batten approach but abandoned it as I thought it was purely subjective as to what is "fair & easy lines." I did not follow the conventional/correct planking procedures, rather, I let my eyes and judgement guide me - trial and error. I used the tapered ends of toothpicks as trunnels. I pre-drilled the plank before tapping in the trunnel. This forms a nice wedge to hold the plank in place. I applied glue at each bulkhead. After the glue dried, the trunnels were trimmed and sanded/filed. I purchased the ModelExpo hull planking clamps, but found them not be useful. I started planking at the main whale down and later switched to the keel where I installed the wide garboard and first board strake. I did not cut any quarter checked stealers, and used a few half-checked stealers. Though unconventional, I found tapered planks effective to fill-in gaps between planks. Wood filler covers irregularities and imperfections. All-in-all, after a lot of filing and sanding, I'm pleased with how the planking turned out, considering it is my first P-O-B and that I intend to paint it rather than show it off. The most difficult part, for me, was the planking at the transcom filler. I used heat and horsing (bending), but I couldn't bend the plank sufficiently to avoid breaking. I just left the break in-place and sanded/filed it later. I some instances at the aft filler block, I used a thicker, short piece of wood and sanded/filed it down. At this stage, I'm 8 weeks into the build.
  14. Continuing with the build, just a note on the keel. I should have pinned the keel because it became detached at some point in the built. I basically followed the instructional manual but improvised it. I beveled the bulkheads before installing and cut the rabbit. After placing the bulkheads, I proceeded with the bow and stern filler blocks. These were tricky and very time consuming. Being able to see 3-dimesionally is a must for these. I didn’t find the Buttlock L&M templates to be helpful. I made the transom frame in one complete piece, glued it in place, and then glued on the counter planking. One mistake I made here was setting the widow frames too low -no big deal, part of improvising. I filled the minor spaces between planks with natural wood filler which I have found to be invaluable. After making the hatch coamings, I turned my attention to the gun port framing. With that complete, I painted the hatch coamings, installed the grating, and glued coamings in-place. Next, installed and painted the waterway, and house front, the fancy rail and cap, main deck thick plank, and main deck outer plank, quarter deck, transom forward side plank, and the transom cap. At this point, I'm about 4 weeks into the build. Ready for inboard and outboard bulwark planks.
  15. After a 45-year hiatus from my first build (Model Shipways Rattlesnake solid hull) I decide to build another. I'm retired and living in a condo, so I needed a hobby. I chose the Fair American because it was similar to the Rattlesnake, and I wanted to try a plank-on-bulkhead model. I started the build April 12, 2019. So far, I'm pleased with the progress. I wish that had taken more progress photos. Going forward, I will try to take more photos to document the progress. When I received the kit, I went through the parts list to make sure everything was in the box. I labeled some wood parts but not all. In hindsight, I wish I had labeled all the wood parts. Like some other modelers, I found the keel was too short. I made one of the proper length from scrape material and continued on.
  16. Dave, I experienced the same keel problem with my Fair American kit. I made one of proper length from scrape material. I contacted
