Posts posted by stelios
Stelios,
Beautiful work. The rigging on this boat is unusual (to my eyes) and very interesting.
Ian, thank you; I'd agree with you the rigging is unusual. Just spare a couple of minutes and read the second posting from the beginning of this log., it explains in brief the reasoning behind it.
Dear all,
The small mizzen sail proved to be relatively easy to fit. (unless if today was one of those days with inspiration...)
In the first picture one can see the process and in the second the who thing fitted on the boat. The ropes were not secured yet,as I need to have "breathing" space on the deck.
One of the side projects that I need to tackle, are the belaying pins. The challenge will be to make them small enough to be close to the ship's scale.
The other challenge that will be dealt with at the end, is the rope coiling; to hang coiled rope so to add a touch o realism.
cheers
Stelios
- druxey, ianmajor, aykutansin and 4 others
- 7
Dear all,
The time has come to start rigging and fitting the sails. The process of trying to understand the plans it is a real fun (read:pain in the neck).
Anyway, this is how I ended with the main sail (it is called sakoleva). The threads are not secured yet, I need to adjust it a bit higher, in order for the mast to hang on the air, currently touching the deck.
The picture below shows how the plan depicts the position of the sail.Hopefully, I will manage to fit it it and adjust to its correct position.
Stelios
Jay, I didnt have any circlips so I tried my roundnose pliers. I think they worked out ok.
Sam
This is a neat job Sam.
Thanks for posting this, I am at that stage right now and was trying to solder my parts in place and creating briquettes in the process. Gonna try this, thanks again.
One question, are you using hard silver solder or silver bearing plumbers solder?
Ok two questions, are you blackening after crimping to your deadeye?
Sam
Sam,
apologies for the belated response, activities other than ship modelling are keeping me busy...
First of all, the attached picture shows is the pliers I use, not an expensive one, it just gives me the flexibility to choose the inner width of the ring.
The soldering material I use is in tube (1 oz paste) and on the label it is stated: Fusion Brazing Paste prod: STL-1205-655. As I mentioned earlier in this thread, I used Russ' tutorial. I think it mentions the same paste. It is very easy to use especially for novices like me.
The blackening process comes at the very end. The dead-eyes (wooden) were not affected.
Cheers
Stelios
Very nice work. Athens is one of my favorite cities. Been there many times, and spent 6 weeks there in 1972 while in the US Navy. I was on the aircraft carrier John F Kennedy.
That's a long time ago John! I was at junior high school at the time. I do recall the carrier and the sixth fleet. I still remember the sailors with their distinctive Popeye hat.
Dear all,
I was browsing my archives and I found the pictures of my first working jig.
I still remember the pride I felt when I managed -easily- to wax the threads for my then first build.
It was used after the Bounty build with my two scratch builds and still rests in a self waiting for the next build. ( I hope).
It is a rudimentary construction based on similar jig (more refined I must admit) I found in Ship-modeling forum. Since it works, I followed the rule number one: if it works efficiently, just don't touch it!
The principle is very simple:
- Bring to melting temperature the wax in the small jar. This can be accomplished if you place it into boiling water (bain marie they call it)
- Pour some boiling water in the big jar and the then emerge the small one and seal the lid.
- Pull the string and wipe it with a rag. it is so easy.
The construction itself I think is explained in the pictures.
cheers
Stelios
John,
impressive work! what is the next step?
Michael,
I was thinking, to build so many details is one thing, to spend time on top and record the progress by taking pictures, is something else.
We all know how time consuming it can be when we want to take pictures, especially when the pictures are of such quality and detail like yours.
A job well done!
Stelios
Ilhan,
I remember this build from the old MSW, thank you for re-posting, it is a good reference for the rest of us!
regards
Stelios
Dear all,
Until the rat-lines are finished, I occupy my mind with the next steps, in relation how to fit the sails.
Being ignorant about sails, I try to decipher the plans and figure out how to proceed.
What I recall from Dry Docks (before the MSW era) is that normally you start from inside going out, when it comes to sail rigging, and this is what I'm going to do, at least, I'll try.
So, this afternoon, just for fun, I made the stirrups out of 0.6 mm brass wire. I managed to solder the rings, without melting the wire... the finishing with the needle file was a challenge, as together with the wire I was trimming my finger tips...
Anyway, the next step is to blacken them and attach them.
In the past, when I built my first kit -a Bounty- I had settled with black thread hardened with CA glue. I think brass wire will look better...
Stelios
Elia,
Greetings from Athens and Happy Birthday!
I silently follow your project!
cheers
Stelios
A job well done Dave!
If I may add my own experience:
make sure the sewing machine is well tuned. I did not know that sewing machines need tuning, util a professional seamstress examined my work... (I use an old singer a 60ties build). Actually she played with those rods that regulate the feed of the string. Once fixed, the stitching was even. If you ask me If I can do it by myself, no, I can't. I'll have to consult her again...
I used some textile glue, only tiny quanities to secure the corners. Not visible, acceptable results.
regards
Stelios
Dear all,
I think that with this post I arrive from past to the present, as the picture from now on are considered as current.
In the following pictures another milestone is logged, and this is the installation of the main mast on the ship.
I decided just for fun, to show the details first, then the overall picture:
The dead-eyes ready to be fit on the shrouds.
In order to have an understanding about the dimensions, just note that the square on the mat is 1cm x 1cm.
The jig (spacer) used between the dead-eyes.
Nothing fancy, just to brass wires, in the shape of a staple.
NB. all my threads are waxed that's why you don't see any fibers coming out and around the thread.
The mast with the shrouds before the installation.
The bowsprit.
The bowsprit is finally fit on the vessel.
In the next two pictures I just tried to make some double blocks, to be used to the guys.
I did not finally used them,(i did not like how they looked on the sprit) but the methodology I think is worth noticing.
The strip of wood with the little nail, is the jig to hold the small bits in place and attach the thread around.
Stelios
John,
Thank you.I cannot tell if I'm accurate or not. The truth is that for this build I do not rush and I spend more time studying the details, which is fun actually!
Michael, I'm honored!
Stelios
John,
a fine job! I really enjoy the log.
Stelios
In today's economic environment, people need to be multiskilling (and sometimes) multitasking.
Oops, wrong forum!
What I wanted to say is that this hobby requires to develop many skills, one of them is to know how to use a Singer. Actually, I use an electric sewing machine made back in the early 60ties. the mechanical parts are line new. I only had to replace the motor, as after so many years, it simply died; it had lived beyond its normal life expectancy....
In the following pictures I try to portray the various steps, I think they are self explanatory.
Stelios
Notes:
- The fabric in use is poplin.
- The pencil marks were removed at the end my hand washing the sails with detergent.
- the patches were glued with textile glue
- the eyelets were mabe from black thread, hardened with some CA glue, to give the metal "feeling"
- ah, yes, at the end I steam ironed them (that skill please do not share with my wife...)
In the following pictures I try to portray the construction of various metal parts.
For some reason, when it comes to metal works ans soldering, I really enjoy it.
There is always room for improvement, the more I exercise, the better the outcome, (I like to believe).
In the next four pictures, you can see how I make the rings, as I did not have tube available to cut. The principle is simple: coil the wire and then solder it. With some trimming it becomes a nice ring.
The methodology of the little ring construction was already mentioned.I just share a better quality picture. Anyway they will be used further below, so it is relevant.
Some wood work: the masts, sprits etc.
A small deviation to make my anchor; yes it is an ugly duck, but I love it, it is my first anchor!
In the following picture you can see various metal works, I think they are self explanatory.
Stelios
...and while I was preparing myself for the next step, (the construction of masts and their paraphernalia),
I stepped back for a while and took some macro pictures.
I'm always fascinated from macro pictures as they give you an entirely different perspective.
Stelios
PS. for the record, the date was 24/12/2011
Russ,
Just to say hello, I'm back and following the progress of your build.
regards
Stelios
Symiaki Skafi by stelios
Rigging in the making
From the captain's log- not much of the progress, as I spent some time to make some tiny blocks.
In the two pictures below you can see the preparation of the main top sail.
In the third one, the main yard with its foot rope.
