Gerarddm
Members-
Everything posted by Gerarddm
Thanks Charles. I did in fact acquire Leavitt's plans a few months back and have been gingerly proceeding ever since ( see photo of my attempt at the ships' boats ). I understand Chapelle's viewpoint; but my interest in building her is simply I think that this particular design is very lovely, and that August Crabtree built her, and I want to attempt to see how close I can get to his lofty level. That she does not represent an actual ship is immaterial to me. I agree that Feldman and Parker are describing different ships. However, I have Hoeckel's plans too from his monograph Amerikanische Kriegsbrigg. In his bibliography in the back of the monograph, he cites the following: Leavitt, Clyde M, The Brig 'Lexington', Handbook for Model Builder #112, S. 128/137. Fawcett Inc., Greenwich CT. I have been unable to find a copy of this handbook, so if you know a source, please let me know. Between Leavitt, Hoeckel, and Davis, I think the basis of a good model are at hand if my hand/eye skills are up to it. I haven't build a ship model in 40 years, but I did build a 15' sail-and-oar Lincolnville Salmon Wherry a few years back.
I learn something new almost every time I come here. I have never heard the term' bend ' used at all regarding frames in any of the books I have read, so thank you Jaager. I will check out your build log for La Renommee. Meanwhile, Leavitt DID loft all 37 bends so I don't have to, and I show some of them in my first post. Still unanswered for me is why the Leavitt bend/frame/futtocks are not drawn in fair curves i.e. why the projection at the deck beam level. At this point I have half a mind to simply make bends fair, place them at all 37 stations the way I was taught in boat school, bevel away accordingly, and let the devil take the hindmost. I hate to admit defeat, though.
Mark, thanks again, yet still I am as thick as a brick. The projections I was referring to were the ones on the inside or outside of the frames indicating the deck beam level. Charles Davis, in his book The Built Up Ship Model, talks about built-up framing from pages 21-24. The photo herein is from page 21, and clearly shows the projections, but that is because he drew the frame in perspective, no? In other words, am I to assume that the futtocks are all the same molded size for what I will call layer 1 and layer 2 ( both layers, of course, comprising the frame itself ), or am I to cut the futtocks out so that one layer is wider than the other to account for bevel? It seems to me that if the frames were simply futtocks of all the same size for each layer, and placed so that the forward frames were positioned forward of the stations and the aft frames placed aft of the stations, life would be simpler. Aaargh. Davis talks about this, how " the shape of the frame...is the middle of the frame, the seam where the two pieces come together ". He then talks about how one layer is cut on a standing bevel, and the other on an under bevel. Sure, OK, but. Again, aargh. How can the seam line be aligned with the station line of the hull, when the standing bevel layer would need to be larger to accommodate the bevel? I hate the feeling that I am not as smart as I thought I was.
I finally have the Leavitt plans for the Charles Davis Lexington ( so-called ) armed brig, and am puzzled by his frame station layout and his frame plans. See photos. The frames are to be made up with futtocks in the usual manner. What puzzles me is that as you can see, he clearly shows the frames centered on the station lines. I was taught that the frame positions forward of the midship section should be placed forward of the frame station, and aft of the midship station the frames should be placed aft of the frame station, all to allow for the bevels. Then I look at the frame plans, and have not a clue as to why, in certain frames, there are futtocks that project beyond the fair curve of the frame face. Also, there are black shaded areas, some on the outside, some on the inside, but never both. Am I to deduce these are the bevels? Are not the frames beveled inside and outside? What are the multiple of lines showed on each frame? I was expecting something not so rigorous, and being a newbie could use some guidance from the forum. Thanks.
As above, Jim sent me his email address, I sent him my questions and he replied within 24 hours, so it's all good. But yes, he really should get that website email function fixed.
Jim- Thanks for your response, I will send you an email at that address. Muito obrigado! Gerard>
Just curious: twice in the past couple of months I have used the email function of the Byrnes Model Machines website to ask a couple of questions ( there is no direct email address that I can find ) and got zero response. Is he always this uncommunicative?
Using pins
Gerarddm replied to Oddball's topic in Building, Framing, Planking and plating a ships hull and deck
Well, yes, and it looks rather jarring, if not actually unsightly in certain cases. If one assumes that trunnels were 1" to 1.5" in diameter , then some models I have seen photos of have trunnels that, when scaled out, would have been several inches in diameter. -
Using pins
He provides no illustrations, and the tenor of his comments were than he pinned for strength. -
Using pins
In reading Underhill's Volume 1 of Plank On Frame Models, he notes that he ALWAYS pins his work no matter how small that pin or trunnel may be, and does not rely on adhesives solely. -
An olfactory benefit to using pine tar is that your model will smell great and shippy. 🙂 I will follow Nelson's dictum for ratlines, but what about rigging deadeyes? I have seen models with both natural and dark line?
nubie question regarding string and knots
Gerarddm replied to EricWilliamMarshall's topic in Masting, rigging and sails
Xacto makes a sprue cutter, for use in plastic model kits. Inexpensive, cuts flat and cleanly. I would imagine using a dab of glue or shellac would help before the cut. -
In all the books I have been reading ( feverishly, trying to get up to speed ) about plank-on-frame construction, nowhere do I see any mention of how to dimension the molded size ( i.e. the fore/aft faces ) of frames. Even Underhill, in Volume 1 of Plank-On-Frame Models, page 8, doesn't mention or show this. Clearly one has the shape of the frames; in my plans for Davis' Lexington he shows the sided size ( i.e. thickness ) of the frames; but no mention at all of how wide the face of the frames would be at the keel, nor how they would gradually become less wide as one went up to the sheer. Obviously the frames of something like Victory or Constitution would be beefier than a 16-gun armed brig like Lexington. How does one go about correctly sizing frames/futtocks?
Thin hull planking
Gerarddm replied to Gerarddm's topic in Building, Framing, Planking and plating a ships hull and deck
Thanks for all the enlightening answers, very helpful. -
Due to display space limitations, my proposed build of the Davis Lexington will have to be in 1:72 scale. As I have been calculating timber sizes etc., I suddenly realized last night that the real ship would have had hull planking of around 3" thickness. In 1:72 scale, that is barely over 1MM. Being a newbie, my first reaction was, good grief! How do I get wood that thin? And what species of wood can be worked that thin? Then I recalled that people like McNarry and others have built amazingly detailed models at 1:100 or less, so my question is, how does one get wood so thin that the scaled planking would be accurate?
Madrone, madrona, either is acceptable usage according to Wiki. And then there's the Madrona section of Seattle. 😉 I have a couple of well-dried chunks of the stuff, I need to cut it open and see if the splits have rendered it unusable. BTW, Edensaw Woods in Port Townsend WA supplies it in 13/16" billets, S2S1E.
