Stephen Walters
NRG Member-
Everything posted by Stephen Walters
I have just listened to Mr. Pissaro's videos on planking the Winchelsea and have enjoyed them so much. He presents the information so clearly. He is a natural teacher. I just have one request to make and then with his help from those masterful videos, I will be ready to try my hand at this wonderful pursuit. In his first planking video, he mentions that in Chapter Two he discusses how to line off the hull, something I very much would like to know. I have looked for this chapter on the site, but have been unable to locate it. Can someone tell me where it is? Stephen Walters
Thank you so much for your fast, informative, and kind reply. I wish you much success in your build. Kind Regards, Stephen Walters
HakeZou, congratulations on starting your build of the Endurance! I look forward to your posts. They are always informative. In the meantime and when you get a minute or two, could you let me know where you purchased your bulkhead corner braces and the clamps you used on the bow of the Endurance? I hope to get my Occre kit soon and would like to order these items as soon as possible so I could have them ready for use when my kit arrives. Kind Regards, Stephen Walters
Hi, Toni. got my second kit this morning (First kit had delaminated panels and I had to reorder.) and opened it just now. There is some warpage on the two bulkhead panels. The first photograph shows the panels as they came in the kit. The second photograph shows the panels reversed. I'm not quite sure how to take the warpage out of the panels. Any suggestions? Kind Regards Stephen Walters
Well, Toni, I'm so confused about rabbets. I got the kit for the half-hull planking project and am ready to start but I need to get a clear idea about how the rabbet cross section change as it rises up the stem. I first thought that the 45 degree bevel on the upper portion of the keel extended up through the stem with no change. After reading that portion of your build log on MSW dealing with rabbets, I discovered I was spectacularly wrong. If I read your build log correctly, it shows the complete rabbet at the top of the stem to be in the shape of a mortise. My understanding of a mortise is that it is a cut that has a rectangular cross section, but when I look at the first photograph that shows the mortise portion of the rabbet darkened for clarity, I am confused by the darkened triangular area that extends from just below the third waterline from the bottom to just above the fourth waterline. Is this area still the flat area of the bottom of the mortise? If it is, it would appear that the bevel steepens from 45 degrees at the bottom of the triangular area to almost 90 degrees at the top of this area. Is this true? When you get a few minutes, could you help me out? I have a feeling that I have missed something important here. Kind Regards, Stephen Walters
Mr. Levine's half-hull planking project would be of great help to me in understanding hull planking and would like to learn more about purchasing his kit. Could someone let me know where on the site I could go to find out about the price? This project seems like a remarkable learning tool. Kind Regards, Stephen Walters
A most beautiful model. Thank you so much for your help. Stephen Walters
- 270 replies
- red dragon
- artesania latina
Hi, Nigel. I just found your build log on the Red Dragon by Artesania Latina. What a gorgeous and beautiful model! It deserves to be in a museum. I, myself, have started the Red Dragon build and in about a month will be facing a problem you have so masterfully solved. It involves gluing the bulwarks to the deck, and especially at the bow where they attach to the bow bulkhead. They will be attaching at such a severe angle that I'm worried that the glue will not be able to permanently hold them. In your build, I believe you mentioned that you would be preforming them before attachment. Excellent idea! When you get a minute or two, can you tell me how you did this and what kind of clamps you used, especially at the bow and stern? Kind Regards, Stephen Walters
- 270 replies
- red dragon
- artesania latina
Good evening from Tulsa, Oklahoma. I'm new to the forum and new to modeling and just hope I ask questions that make some sense. I've just started my build of the Bluenose II by Artesania Latina. Eventually, I will be edge marking the deck planks to simulate deck tarring. A number of modelers I've talked to say stay away from edge marking with any pencil lead because it leaves indelible smudges after sanding. Others recommend marker pens. I've tried some marker pens but the ink weeps away from the edges onto the tops of small test planks I'm using. The test planks I'm using come from the 0.6 mm x 5 mm basswood planks in the AL kit. Can of any of you experienced modelers recommend inks that won't smudge on sanding, or if that is unfeasible, recommend other ways to edge mark the planks? One way or another, I'm going to build this exquisite model. It is so beautiful. Stephen Walters
