Tyguy35
  1. No worries, doing my math I got 45mm from the bottom of boot to keel. Then making it only 5mm thick. But I think I like your idea of making it 5/16” thick. that math was just based off the scale of the actual ship vs the scale of the photo in the drawing. So I may be off a few mm I’m glad I was close. how about the colours you used on the hull which great and white or light grey? thanks
  2. It would have been nice if they marked where the line should be or atleast put it in the manual.
  3. Are you able to tell me the boot line top and bottom from the keel? I can’t seem to find the measurements to draw the waterline in the kit.
  4. Hey, I’m currently building the trumpeter 1/200 scharnhorst and I’m trying to figure out where the waterline starts or how to measure it. How thick the black line is and where that starts. I can’t find it in the instructions. Or maybe I missed it. does anyone know where the black line starts and ends from bottom up. Thank you
  5. Semi gloss oak varnish. I do wish it was matte, does anyone know if a light sanding of 220 grit would get rid of the shine
  6. The stencil used to make the holes was a little bit off, I could have fixed it before making the holes but I didn’t notice until after I added little planks of wood to make up the missed space where the anchor for the mast sits I know it won’t be seen anyways but I’ll know and I’m a bit of a perfectionist
  7. Placed these 4 ribs into place, which surprisingly took a long time to glue, sand and cut
  8. Got some planking done, had to sand down the plank at the top as one side was not at large an opening as the other. I believe that was my error when I placed the central beam down the glue hardened quicker than I thought. It’s maybe off angle by quarter to half a mm.
  9. Hey, first time starting a build log here. Always wanted to build a kit of the HMS Victory but do not have the skill yet to complete a large kit just yet. I came across this cross section by AL and thought this might scratch the itch of wanting to build the Victory until I can actually do it. so far it’s been pretty easy going, not a huge fan of the video instructions I would have preferred a photo. Slowing the YouTube video speed helps a lot. I’m a fan of the little spacer tools the kit came with to get the correct spacing. enjoy have a great one.
  10. I hope that when I get to making mine that it looks even half as good. Great work amazing wood work.
  11. Thank you, love the Ontario welcome haha.
  12. I have gone over your posts aim the Diana probably a hundred times. You’ve done a great job.
  13. I appreciate everyone’s advice. I am going to have to do some more research. You all are more than likely correct and I will likely pick something different as a second kit. I do not want to get discouraged if I cannot figure something out. Thank you everyone.
  14. Repetition is not such a big deal just do a bit at a time. But yes decent instructions would be best. The only thing I think I would struggle on with any of them is just the planking of the hull. I’m just not sure which technique is best to go with a a learner.
