ubjs
Members-
About ubjs
Sweden
ubjs reacted to a post in a topic:
HM Armed Cutter Sherbourne 1763 by palmerit - FINISHED - Vanguard Models - 1:64 - First Build
HM Armed Cutter Sherbourne by Zvr - FINISHED - Vanguard Models - 1:64
HM cutter Sherbourne by Maid of the Mist - Vanguard Models - 1:64
Polaris by Meekes - OcCre - 1:50 - First Build
Emma C Berry by cdrusn89 - Model Shipways - 1/32
https://shipmodeler.wordpress.com/tag/planking-clamps/
Two masted schooner by lawrence101 - RESTORATION - similar to the Emma C Berry
Norden 603 by Scott Crouse - FINISHED - Billing Boats - 1/30
For first planking, dont miss the instruction to edgebend the first plank a little and try to follow the frame. Maybe you could give us a better picture of the frames. Maybe you could sand more? You should always sand the frames after installing, not before!
- 29 replies
- Sherbourne
- Vanguard Models
Here I think you can clearly see how to plank. I read somewhere that you should think of each plank as its own project.
- 18 replies
- cutter
- Sherbourne
His Britannic Majesty's Cutter Sherbourne 1763 by Paul White - Vanguard Models - 1:64
The bow is quite brutal in its bend. The problem is that if you don't get the plank right here, the errors grow with each new plank. I recognize your planking, my first boat was even worse. I don't think you can fix it all with regular putty, possibly 2-component putty. The alternative is that you shape pieces of wood and fill in all the gaps, they don't have to fit exactly. You can sand off the excess if you glue in pieces of strips, for example. The important thing is that you don't get too caught up in this, the first boat is rarely fantastic but you learn a lot when you build. I see several people struggling with the planking of Sherbourne. Here is a video where I think he succeeds quite well. Maybe it can be helpful.
I usually turn the strip in the bow/stern if necessary. The strip should lie completely against the frame. Soak it for about 30 minutes and bend it over an electric plank bender, a soldering iron can also work, an iron uses some. I usually have to file the inner upper edge of the strip to get it next to the one above it. Don't be careless with this, redo it until it's right. As you can see, it affects the plank that comes after.
- 18 replies
- cutter
- Sherbourne
Learning Ship Modeling One Wrong Step at a Time: Hello, I am new here.
TheWanderingGatherer reacted to a post in a topic:
An electric plank bender is a simple design so I don't know if the Chinese can fail even with one. Amati and Occre sell the tool. I don't know how complicated it is to trade from Norway with EU countries. In Sweden there is https://www.modellhobby.se/sv/batbyggare/87484-amati-electric-plank-bender-amati7205.html In Germany https://www.krickshop.de/Tools-Materials/Tools/Electric-Tools.htm?shop=krick_e&a=catalog&p=388
Welcome I'm also keen on Fram but I've already collected too many kits. I have Bowdoin in my pile, an Arctic schooner built in 1921, Bluejacket is the manufacturer of that model. If you haven't tried it yet, I think you should get an electric plank bender. It solved my biggest problems with bending the planks. Then I want to recommend this builder's videos, she has a lot of interesting tips.
Lotus 72D by DocRob - FINISHED - Tamiya - 1/12 - Plastic/Metal - The Legend
I'm building a Norwegian Pram myself now, but it's not going well. I don't get along with dory builds at all, I've tried Bluejackets before. To all beginners who are trying to put together a dory and not succeeding, I can console you with the fact that it's much easier to build a regular hull with a little more real wood. I've built a number of hulls, Vasa, Bohuslän, Polaris, Spray, Lilla Dan. They're not fantastic builds but ok. But putting together a Norwegian Pram, as I said, doesn't go well. I don't get along with this thin, soft wood. When it comes to bending the hull parts for the Pram, I recommend the same as Palmerit. I usually bend with an electric plank bender, but it doesn't work for the Pram, you get burn marks right away and also sinks in the wood.
It's starting to take hold, now you just have to clear coat as many times as you can with wet sanding in between. :) But it's just a fairly modern plastic body and not a Rolls with real sheet metal so this finish will probably be enough. Is this the best looking F1 with advertising? Of course the Alfas, Silver Arrows and the green Lotuses were better looking. :)
