Gabek
Everything posted by Gabek
  1. Hey there, 3sheets. You're doing excellent work (in spite of the puppy)! Having all the MSW crew behind you is an unbelievable resource, one that I could have used when I started this model. Thanks, Gabe
  2. Thanks, folks. Having this build log and all the great feedback from members it generated was a major factor in pushing me to finish. And, putting pictures up for everyone to see kept me on my toes, so to speak! Regards, Gabe
  3. Feb 3-18 Running rigging and the end game The basic sheets and halyards went fairly well, and I like adding the blocks to the rigging - but how to deal with the falls was driving me bananas! There really should have been more fife rails. After long searches I spotted some very old photos of pilot schooners. It dawned on me that this was a working boat, with seasoned professionals manning her, much like tugboats today. There would have been a practical, no-nonsense approach to sailing her so I decided to coil the falls where they lay. Flemish flaking was good for the navy and yachts, but not for this hard working little ship. I had a small problem, though. I had run out of the line from the kit. The closest I could find was slightly smaller diameter, but I think this worked out in my favour. I began making coils of line for the cleats using a little jig made of bent wire pushed through card stock. The thinner thread made it look like lots of rope was belayed, but it wasn't bulky. I followed a trick I learned here of using watered down glue to help shape the line and make it lay flatter. I tapered the end of a dowel to wrap glue-soaked line for the coils on deck. Once wrapped, I gently nudged the coils off the dowel with a dental pick. While wet I could still shape them a bit. I trimmed the tag ends of these coils and glued one turn of the original fall to the top of these coil mounds to make them look the right sized line. The finished product was adhered to the deck with a few drops of cyano. I figured that the fore gaff downhaul would not have much line, being hoisted up to its maximum height, so I decided to just layout a figure eight fake for this line. I'm not entirely sure that this would have been done in 1805, but I learned about this technique on a Canadian Coast Guard page so I thought I would add this to the Swift as an homage to them. I had assembled the anchors, filed the mould lines and spray painted them black about a month ago. Of course, I had to research anchors. So, now I added puddening to the anchor rings and did a real hash of the seizing. Actually, the cyano glue made a hash of them, causing the thread to go translucent and ugly. I ended up painting the seizings with an off-white model paint. I had toyed with the idea of building wooden stocks and even gluing veneer to the white metal, but decided to paint them to look like wood. Another hobby of mine, painting miniatures (Warhammer, in particular), has given me some skill in painting wood grain on pewter or plastic. I base-coated the stocks with a dark brown, then streaked on a fair amount of a tan, then gave the whole thing a wash in brown ink. They looked ok. I was all set to tie anchor bends to the anchors but I did one more check on my booms and, once again, I was tying anchor clinches. My first attempt took almost two hours and looked hideously bulky and the cyano had wrecked the look of the seizings. I cut off the brutish hitch and tried another time with a much thinner thread. It was ok, but I was so tired of dealing with these clinches that I resurrected an idea that I had when I was making the base for the model. I ended up drilling a hole in the top of the oak base the same diameter as the anchor cable and ran the cable into it to look as if the Swift was at anchor. Considering that she had no sails it only made sense. My 1 mm bit would not reach all the way through the base, so I used some steel wire to push the cable in, giving it a bit of cyano to keep it in the hole. The Swift gently tugging on her anchor I glue-soaked and coiled the extra anchor cable around a tapered felt pen cap to fashion coiled mounds like for the running rigging. I tied the free ends of the cables to the knight-head and glued the coils down to the deck. A few weeks ago I posted a question to MSW about rigging flags and got great advice. http://modelshipworld.com/index.php?/topic/5145-correct-hitch-and-advice-on-rigging-a-flag-needed/ A long time ago (probably 12 years ago) I bought a union jack to put on my model (sorry to my American neighbours). It had adhesive backed material that you just folded down to make a two-sided flag. I curled the flag around a few different diameters of dowels to make it appear to ripple. A short length of string with an eye spliced into it was attached to the 'seam' end. Even using this very slender thread the collapsible eye needle worked its magic and an eye splice was done in seconds. I cut and sanded down some thin birch dowel to make a small toggle to attach above the flag. The kit instructed to run the flag halyards to giant deck cleats. I quickly made a smaller cleat out of http://modelshipworld.com/index.php?/topic/5145-correct-hitch-and-advice-on-rigging-a-flag-needed/ walnut and attached it to the mainmast. It was fairly simple to thread the toggle through the eye-splice above the flag, and tie on a sheet bend in the eye-splice under the flag. I hoisted the flag, tied the flag halyards to the cleat on the mast and added a drop of cyano to keep it there. I started squaring away the model: matt varnish was painted on blocks, threads and other debris were cleaned off the model, a few stray smears of glue were dealt with... ...the Swift was done. I'll follow up with a reflection soon.
  4. New Year's Day, 2014 As soon as I started looking at what was involved in the running rigging I realized that I wouldn't be finishing this model today. On almost every line that needed to be run I had questions that could not be answered in the instructions and I was researching every knot, hitch and halyard. While I liked reading and checking all of this I was now getting headaches from all the decisions I was having to make. Although I really wanted to finish today I wasn't about to give up on trying to complete as good a model as I can. Jan 2-3, 2014 Resolved to take my time I first prepared the blocks. I felt that, right out of the box, the blocks looked too square, so I sanded down the edges to make them a little more oval and worn looking. I also stained them to make them look a little more like oak by putting a few drops of stain in a ziplock bag and tossing the blocks around in it for a few seconds before turning them out on a paper towel. After spending a lot of time researching the multitude of blocks and which strapping, pendants, etc are used on a ship and how to make them for a model I made a list of what was needed for the Swift. I found an excellent method of strapping a block on another modeller's website (sorry MSW). To make all the straps consistent in size I went back to my fly tying gear. A made a jig out of steel wire that would allow me to hold the block in place while I made a larger loop of thread around it. A simple overhand knot and a drop of cyano under the block made a good simulation of the splice and I then used a much thinner thread to seize the loop tight to the top of the block and form the eye. This became an easy task and I rather liked making these. The gaffs Based on several sources I decided to add stop cleats on the gaffs for the peak halyards. After trying to cut wedges to size, with no luck, I ended up just cutting small blocks of equal size, gluing them in place and shaping them with a knife afterwards. Stop cleats on the gaff to keep the peak halyards in place. I went with eye splices on the throat halyards not only because it was the right choice but also because I found that a collapsible eye needle was the perfect tool for this. I can thank my sister who does a lot of beadwork for making me aware of this invaluable tool. In just a few minutes I had spliced an eye around the ringbolt on the gaff and several other places. Next time I think I'll thread the parrels AFTER doing all this! (I discovered that I'm bad at handling beads - there's probably more on my floor than I could count. So, once I got them on the gaff I wasn't going to take them off!) Preliminary steps in splicing an eye around a ringbolt. The actual installation of the gaffs and boom involved simply threading the parrel lines through the jaws and tying an overhand knot to simulate a stop knot. A drop of cyano finished the job. It was about this time that I really began to notice serious flaws in the rigging plan. For instance, why would the throat halyards be tied directly to ringbolts on deck instead of to tackle? Even if, historically, it was tied off this way, what hitch would you use in the middle of a rope that would be secure enough to hold up a gaff and sail, be fairly quick to release for setting and trimming but not so easy that it could be accidentally unhitched? After A LOT of research, a post for advice here on MSW (http://modelshipworld.com/index.php?/topic/5145-correct-hitch-and-advice-on-rigging-a-flag-needed/), and the fact that I didn't have enough blocks to correctly add tackle to the halyard (I almost stole some from the Harvey kit I have), I installed the gaff as per instructions and used a slipped buntline to tie off the halyards to the deck.
  5. Thanks, Russ. Although I kinda wince at my work in the photos...lots of little imperfections really become obvious! Regards, Gabe
  6. December 30 - January 1 Standing Rigging I was excited. I broke out the thread from the kit and, with 3 days to the 27th anniversary, was positive that a few feet of string and a couple of knots were not going to be a problem. And I'm quite sure that the veteran modellers here might be chuckling at me right now. This being my first model I had no idea what I was getting into. The instructions of course, were no help whatsoever. The standing rigging seemed to be straight forward. I had read enough to understand seizing and, thinking about how to wrap thread around another piece of thread, another hobby of mine came to mind: fly tying. The small tools made for tying bits of feather, fur and other materials onto a hook seemed to be just perfect for this job. I first made some jigs out of some stiff steel wire to hold dead eyes in the fly vice for seizing the shrouds and to make consistent eye-splices. These worked quite well, in my opinion, and I managed to quickly prepare most of the standing rigging. Tying an eye, not a fly. I used black lacquer from my fly tying supplies to glue the seizing Pull the wire out and the eye is free. Not thinking ahead enough I had to scramble to colour the lines black. Most stores were closed. I ended up dipping them in a ziplock bag with a few mLs of black acrylic airbrush paint I had on hand. To spread the paint on the thread and to remove the excess I fashioned a little squeegee from a clothes pin with some foam glued in the jaws. I hung the lines to dry with spring clamps on the ends to keep them stretched. I have always been amazed at pictures and drawings of the maintop on ships and how well thought-out the arrangement of the shrouds and stays were. When it came time to install the rigging on the Swift I tried to keep in mind which arrangement would make sense for mutual support. The foretop on the Swift. (Ignore the wire jig for now) Installing the shrouds and stays went fairly smoothly. I was not happy with having the forestay attached to a ring on the jib boom with just an eye splice, so I made a thimble with some thin brass shim. I was rather pleased with the result. I think I made a small mistake on the shrouds, though. I was researching every step of the way and most of the literature showed that the tail end of the shrouds should face forward when seized to the upper deadeye. When I ran the halyards for the first few deadeyes I made sure that I did this, but it just didn't look right. I did a bit more snooping and found a picture showing the tail ends facing aft. So, I switched all the work around. After I finished tying all the halyards I happened upon another book (don't remember which one) that outright said the tail ends should face forward. Well, I just wasn't going to change them again. I was running out of time if I wanted to be finished New Year's Day. Next model I'll make sure they're done right.
  7. December 28-30, 2013 I was now pushing myself to try and finish the model for New Year's Day so things were happening fast and furious. With the masts stepped and sail hoops made I next went on to install the gaffs. As I threaded the parrels into the jaws the string was a bit too snug to fit and it actually tore through the wood, ruining the hole. Drat. I glued a small wedge of mahogany over the hole and later sanded it back to shape. Drilled the hole again and used a thinner thread for the parrels. This time the hole held.. While the glue was drying on this patch job I prepared the lower dead eyes by wrapping the chains from the kit around them. I must admit I was nervous about getting a tight fit and a nice, 90 degree bend on the wire. I concentrated on pushing the brass hard against the dead eye as I worked it around 360 degrees. To make the bend "crisp" I used a pair of hobby pliers without teeth and, holding the wire at the right location, bent it by hand over the side of the jaws of the tool. I was actually surprised and pleased at how smoothly this went. I followed Mastini's method to mark the location and set the angle for the chains by taping the shrouds in place first. I then used a sanding cord to make notches in the channels for the chains. Holes were drilled in the flattened part of the chains, I shaped them to the curve of the ship and I drilled holes in the hull for the pins. When, as I was about to attach the eighth and last chain... ...the flattened tab snapped off. Great. At first I thought of soldering the pieces back together but didn't think it would be a good joint. I ended up using some brass shim stock that I bent like the blade of a shovel around its handle. To avoid possibly overheating the brass and discolouring it I used epoxy to attach the new tab. Once the epoxy set I filed it down, shaped the tab and installed the last chain. The broken tab and its replacement Right after the epoxy set. Cleaned up with a file Installed.
  8. Hey there, Russ. My biggest frustration is with the instructions (or really lack thereof) and the rigging plan of this kit. Because I haven't built one before but have done tons of reading, I find that I'm spending a lot of time reseaching each and every knot, hitch, etc. to get it right. The kit has many errors that I'm catching. Ah,well, it's keeping me out of trouble!
  9. Thanks, Russ! I appreciate the feedback. I'm working on the rigging right now and feel like screaming. Getting feedback like this is helping me persevere!
  10. December 25-27 Sail Hoops It was really bugging me (just like it did for Themadchemist on his Swift) to put brass rings for sail hoops. So I used a modified version Edwin Lief's method to make wooden ones - I soaked a piece of light-coloured veneer in water for a few hours, blotted it dry and coated one side with waterproof wood glue. I tightly wound it around a 3/8" foil-wrapped dowel and used masking tape to keep it firmly in place. I stopped wrapping after three complete winds of the wood. After one day I removed the tape. The glue was holding but the wood still felt a little damp so I let it dry for one more day. The layer of aluminum foil allowed me to slide the wood to the end of the dowel, but I did not remove the veneer roll. I used my mini table saw with the rip fence set to 1/16" to cut disks off the end. I wanted to see if I could do this without the table saw so I used a hand-held razor saw and a miter box for a few cuts. I found that I could easily cut disks by hand as well. After a bit of shaping and sanding with a sanding pad I gently pushed the dowel portion out of the centre of these disks, separating it from the veneer hoop. For the most part the aluminum foil came off very easily with just a little help from an awl or tweezers. For a couple of the hoops I had to take a file to remove a little bit of foil that was left behind. Next time I try this method I'm going to spend more time tapering the leading and trailing edges to reduce the amount of sanding needed to make the inside and outside edges smooth and the hoops an even width all the way around. I gave the hoops a coat of varnish and slid them on the masts. As I was admiring my work my oldest son came into the room and I proudly pointed out the hoops. He asked, "So, are you going to stain them?" ?! I was so caught up in making the hoops that I really hadn't noticed that they were almost white! I was actually after a warmer shade that would resemble pine, not alabaster! Ah well, they were already varnished and I really didn't feel like making more. Sigh. In this kit the scuttle butt was just a barrel to be glued to the deck - which I just couldn't believe. So, a bit more research and I found a few good photos of USS Constitution's scuttle butt AND BobF's post right here on MSW: http://modelshipworld.com/index.php?/topic/2900-barrels/?hl=%2Bscuttle+%2Bbutt#entry80571 I made a stand out of mahogany strips and decided to copy BobF's rig. To simulate the scuttle I just glued a small rectangle of veneer in place. I thought long and hard but I chose not to paint the barrel hoops - I thought that it might stand out too much and detract from the model.
  11. December 25-26, 2013 After the gift opening, family phone calls and a bite to eat, I headed to the work room with the goal of trying to finish the model by New Year's day - which would make it exactly 27 years since I started the Swift. The only thing in my way was my stubbornness to not put up with AL's interpretation of ship building, and my lack of skill. After installing several ringbolts on the deck it was time to add cleats. I really could not bring myself to install the cleats from the kit as they were extremely thick. I decided to reduce the width down to 1.8 mm instead of the 2.5 mm using a sanding stick I made by gluing sandpaper to a long piece of hardwood. After thinning the cleats I drilled each one through the middle for a pin and gave them all a varnish. Before installing the bowsprit I read ahead in the plans and, sure enough, a hole had to be drilled for the jib tack and it would be so much easier to do this now. In order to make the 3D bend shown in the plans I also replaced the brass strip that was to be the bracket on the bowsprit with thinner stock. I installed all the cleats on the decks and masts. I now came to a big moment - time to step the masts. I realized that in order to get the angle of the saddles and the mast 'grommets' (I've forgotten the name for the ring at the base of the mast!) correct I needed to establish the angle. I had built a Modified Mastini Mast Machine for this purpose, but I still spent a lot of time messing about trying to get all the angles right and making sure that the saddles would end up parallel to the deck. I'd appreciate any advice on how to make this easier the next time. For instance, should I glue the grommet before or after stepping? I've seen both methods, and I chose to glue them before thinking that it would set the rake of the masts. I also had a problem to fix...namely, the oversized hole for the foremast. I thought I had written about this earlier but, looking back, I see I never posted anything about THIS mistake. So, a bit of a flashback... The deck was done, hull was done and it was time to drill the holes for the masts. After a bit of research, I made my Modified Mastini Mast Machine to set the angle for the drill. Using a titanium bit...I screwed up my courage and started up the drill. I watched in horror as it skipped over and the hole ended up noticeably off centre. I'm not too proud to tell you that the air became blue with curses. I realized that a pilot hole was the answer so, once I calmed down, I drilled a pilot hole for the main mast and moved up to the larger bit - worked great. However, I now had to mend the mistake. Round files were used to widen the hole over and I glued a piece of balsa to fill in the off-centre side of the hole. Next problem, to patch the deck. Over the years the once almost white limewood had aged on the model and the pieces in the box were much lighter. My solution, I used an x-acto knife to lift a piece from where the cabins would cover the deck, fitted it and glued it in place. Release the Kraken? Back to the present, the hole was still a bit large and there was play in the mast when I was dry-fitting it. I wanted to tighten up the hole, but I didn't want to mess around gluing more wood and push the alignment. And this is where living in a cold country makes you an expert on filling in small spaces. I had a roll of closed cell foam weather stripping sitting nearby. I sliced a small piece of it down the middle and glued it to the mast. This made for a nice, snug fit and I went ahead and glued the masts in place, main first, using Gorilla glue. The Modified Mastini Mast Machine was used to keep the mast in place while the glue set. I chose Gorilla glue because it expands while setting, hopefully filling in any gaps around the masts.
  12. I think I might post the completed model, Kester. But, I don't think I'll have a chance to work on it for a couple of weeks. A little behind in my paid work! Regards, Gabe
  13. That exact same thought was going through my mind, Henry. Makes a lot of sense. I think that I'll rig the halyard exactly the way you suggested. Thanks!
  14. I knew I could count on the MSW community to respond! I couldn't agree with Kester more on every account. It's funny - just before posting I took out the phrase "Which makes no sense to me" right after "the throat halliards are tied to ringbolts on the deck." Exactly as you said, there is no mechanical advantage and there would be tremendous force on this rig. And I totally agree that the research is a great part of the fun of building - but I'm getting impatient with these bad instructions. (Oh, if you read my build log...this has been a 27 year project and I'm now stalled on a few knots!). I have almost all the other rigging squared away. Super info on rigging a blue ensign, Blue Ensign! Much obliged. (Sorry to all our American cousins, but I am hoisting a Union Jack on this model!). Thank you, folks, for all your advice. I'm hoping that this weekend will be the last one on the Swift. Regards, Gabe
  15. Hello folks. I'm almost done my first wooden build - AL's 'old' Swift - and I'm getting frustrated with the rigging. The plans and directions aren't much help in what knots or hitches should be used anywhere. I've been forced into doing lots of research (I have Lever, Longridge, and perhaps a dozen more books), which is ok but I can't seem to find a hitch or stop that would be used to attach the *middle* of a rope to a ringbolt. In this model the throat halliards are tied to ringbolts on the deck. With gaffs fully raised on the masts there should be a lot of rope on deck, and I'd like to tie off that line in a logical manner. The closest seems to be the slippery hitch - but was there a 'right' one? A second rigging question is about the flag. Did flags in 1805 American ships have grommets? Were toggles used to rig flags at this time? I'd welcome any advice on how to attach the flag to the halyard. By the way, does anyone who has built this model think that the rigging is haywire? Seems very illogical to me. Thanks! Gabe "So happy to be a part of MSW" K.
  16. Jaws I just hated the idea of installing the brass "crab jaws" that the kit provided so I began crafting wooden replacements. To get all the jaws for the spars to be at least close in size and shape I glued two pieces of solid mahogany with spray adhesive and traced a pattern on top. Before gluing them together like this, I drilled a hole in the centre of the piece and then sawed through the centre of the hole. I kept these two pieces together for all the rough cuts and shaping. I followed diagrams in Mastini and Lever for the pattern but, wouldn't you know it, the day after gluing the jaws in place on the boom I was checking out Longridge and The Anatomy of a Ship book, "The Cutter Alert" for details about the parrels and trucks and realized that I probably made a mistake on the shape and length of the jaws. Ah well, it's at least better than what AL had in my opinion. I drilled holes for the thread that will hold the parrel trucks, which ended up being a bit premature because... I still wasn't happy with the bulky look of the jaws on the spars so I brought out the file once again. After shaping the jaws a bit more I realized that I had just wrecked the location of a couple of the holes I had just drilled! Nuts! A bit more drilling fixed a couple of the holes but I ended up having to patch one hole and drill it again. In my research on the jaws I read that they would usually be lined with leather to prevent damage from friction. Not exactly sure how this looked I did a quick search on the web and found several images. To simulate the leather I painted different shades of brown onto tracing paper. I chose tracing paper because it was very thin and would suit the scale of the ship better. After the glue dried on oversized strips of the painted paper I trimmed them back to size. And speaking of trimming...I decided to sand the spars down a bit more. I brushed on some varethane and ran some thread through the holes in the jaws to make sure they weren't clogged. I tried out the beads I bought for the trucks.
  17. Masts - part one October 2013 The masts had been tapered years ago, but now a mistake in the instructions became evident. There is no mention of shaping in shoulders even though they appear in the plans. From the diagrams I had assumed that there was a bushing of some kind in the kit that would be installed. Not so. Shoulders indicated on the plans...but not addressed in the directions. The good thing was that I hadn't tapered the masts completely to their final diameter. I cut in to the masts with a hobby knife to mark the top of the shoulders and went at it with files and sanding pads. To complete the tapering I put the base of the masts into the chuck of my drill and used it like a lathe to sand them down.. Shoulders cut into the masts The brass strips from the kit for the earrings and bands on the masts were very stiff and snapped when I began working on them. I therefore cut 5 mm strips off of brass shim stock using a straight edge and snap blade knife. My first attempt at the mainmast earrings looked good but when I dry fit the flag mast to to main I realized that the distance between them was much too big. The second attempt was much better. To keep solder from the outside of the brass I purposely left excess brass on the end. I tinned the inside surfaces first and then clamped the earrings with a hemostat and clothespin. It just took a little heat on the outer surface with the soldering iron to reflow the solder and make a tight joint. Trimmed the tail pieces to length, shaped the ends and drilled holes for the rings and the earrings were done. I followed this technique for the bands on the ends of the masts, bowsprit and boom. The final earrings-with the mark I sitting in front Fitted and installed brass bands on the ends of the jib boom and main boom. Here's another place where the instructions and the plans were at odds - and perhaps neither are historically accurate. The instructions called for two ring bolts placed on either side of the main boom through holes drilled in the brass. The plans show only one ringbolt on top of the boom and not through the brass but further out along the boom. The sheet appears to be wrapped around the boom just inside the brass. Again, I hit the books to find which one I should follow, eventually settled on the arrangement on the plans. I believe that, to be accurate, a sheave should be built right into the boom for the spanker sheet or a block on a pendant tied right onto the boom. I may just drill a hole to simulate a sheave. Can't decide just now...I want to get moving
  18. Thanks, Bill! I just can't believe how joining MSW and starting this log has motivated me. It has been a real treat to connect with others in this really supportive and positive environment! Much appreciated, Gabe
  19. August 2013 Assembled the display base. For over 25 years this ship bounced around in a box. I moved 4 times, it was taken back and forth to the cottage and, throughout it all, it was sitting on an assembly stand that I had made out of a scrap piece of oak and the wooden 'sprue' left over from the sheet the bulkheads were cut from. Only a few months ago I switched to Micromark's foam stand and the oak was sitting with my stored wood. (The "chunk" in action as an assembly stand) Now, the unbelievable was happening...I was ready to install the hull on a display base! And, for the first time in over 25 years, it dawned on me that this kit didn't come with a base! At this point I realized that I just had to use that chunk of oak that had been the companion of this model for all this time. I had taken up relief carving as a hobby and, inspired by a book in which a ship modeller carved the base to look like waves, I envisioned a rippling water surface under the ship. I didn't want rolling waves because the Swift didn't have sails, just little ripples as if it was at anchor. (So, now I'm thinking of having an anchor cable over the gunwales and strung through the base to simulate this.) I also toyed with the idea of embedding the keel into the wooden waves but decided against it. While still trying to decide how to attach the model to the base, I took out my gouges and carved waves and ripples into the oak. The waves don't look exactly how I wanted, but they will do. (Note: basswood is much easier to carve than red oak!) I cut the board to size on the table saw with a slight bevel. Sanded and varnished, the base looked ok. After mulling for several weeks and checking out brass and wooden options I eventually settled on wooden craft barrels for the standoffs. After determining the placement of the stand offs I drilled holes through the oak and, using forstner bits, drilled counter sinks into the base so the barrels would sit just a fraction into the waves. How to actually fasten it all together was a problem. A dado in the top of the barrel would hopefully keep the keel in place. I was having a hard time finding screws that were slender and long enough to attach through the base and barrels into the keel so I decided to use a two-tiered connection. First, drill through the barrels and fasten them to the keel with 1" screws that were deeply set into a larger countersink. Second, large diameter t-nuts in the bottom of the barrels would let me use machine screws through the oak. The t-nuts would have to be inserted first, so I chose a size that would allow me to insert a screwdriver through it to fasten the screws. Top, bottom and the bottom of a barrel with the t-nut installed Bandsaw cuts and a utility knife helped make the dado for the keel. Before the actual assembly of the base I installed the rudder. I predrilled holes in the hull using the gudgeons as templates and then affixed them with brass pins that I cut to about 3/16" in length. A drop of cyano was applied to each pin before pushing them in. The idea of drilling in to the keel was making me sweat bullets. I needed to make sure the pilot holes I drilled were centred, straight and plumb, so I used the occasion to buy a drill press for my Dremel. I used reusable electrical tie wraps to level and secure the model to the foam base and set it under the Dremel, where I had marked the depth of the pilot hole on the bit. Thinking of that fast moving bit and how rapidly it can remove material, I got nervous about going off centre and drilling through the side of the keel. So, I actually turned the chuck by hand to drill these holes. Thank goodness this worked. I probably should have searched MSW a little more for advice on how to do this next time. I'd be happy to hear what you folks do. The final assembly of the base actually went very smoothly. Screwed the barrels into the keel, then screwed the base to the barrels.
  20. Cabins The cabins had been built and have been sitting in the kit box since 1993. In general, these builds went well. I was able to get a nice, tight fit between the cabins and the deck by laying sandpaper on the deck, essentially using it like a sanding block, and moving the cabins back and forth. The only real fly in the ointment was that I began running out of the walnut veneer strips. Because this was early on in my model building experience I really didn't know where to purchase more and only managed to find some mahogany strips at a toy store that sold doll houses. (Now, I know the shops in town and have a stack of all kinds of veneer on hand and the tools to cut them to size). I went ahead and finished the companion covers with a mix of mahogany and walnut, thinking that the difference wouldn't be noticeable. Wrong. I considered trying to remove them or just rebuilding the cover but never did. Ah, well. I also should mention that I decided to build the doors based on the Fort William replica ship I saw in 1987. (Mentioned in a previous log entry). One of the pictures showed raised panels on the cabin doors, which were different from AL's instructions. Whether historically accurate for a Virginia pilot boat or not I was going to add this detail. [Photo from period replica] A couple of things that I did do at this time were to add the hinges and cover the all the bare edges of the plywood that was used to build the cabin. These edges, frankly, looked ugly. I was very happy that I did the edging. It gave the cabins a much more finished look. I only wish I had seen Popjack's build log first and got the idea to make these in a dark contrast. The colours of his Swift look great: http://modelshipworld.com/index.php?/topic/1765-swift-by-popjack-artesania-latina-virginia-pilot-boat-1805-older-version/page-7?hl=swift I plan on painting the Harvey model that I started, largely on how his model looks. While the cabins look ok the hinges, however, look huge and a little out of scale. I tried to give them a little bend to simulate the hinge joint and pin. Not entirely happy with the look. [Darn ugly hinges, mixed wood on the companionway covers] The cast metal ventilation funnels from the kit did not look like pipes because the funnel end was flat. To make them look like they could actually carry air I drilled into the funnel by hand using a fairly large bit inserted into a hex driver. The tip of the bit made a cone shaped hole and, I think, looks ok. I spray painted the funnels flat black and attached them to the cabins with cyano. BUT, when I varnished them later they took on a gloss finish. Historically, I'm guessing they would have been flat but, being ventilation and not a chimney, would they have been painted to protect them from rusting? And, would the paint have been glossy? If anyone has some insights on this I'd be happy to hear them. So, the cabins were done, and it was time to install them. And this is my 'encounter' with cyano. In general, I have found cyanoacrylate glue to be a big con job. Anything I have tried to 'super glue' together has pretty much fallen apart. (Of course everything I don't want joined, like my fingers, stick like crazy.) I spent weeks researching the best method to attach the cabins and, because I had already varnished the hull, my worry was about the bond. I was pretty much convinced I should use epoxy but, literally, at the last minute I decided to use a gel formulation of CA that was supposed to give me few seconds before it set. I knew that I wouldn't have much time to manoeuvre the cabins so I found my landmarks on the deck and practiced placing them several times. Big moment came, I took a deep breath, and squeezed out a nice bead of glue on the bottom of the fore cabin (I love the newer bottles with the easy squeeze sides). I lined it up and touched it down to the deck and it INSTANTLY adhered a fraction of a millimetre too far toward the bow. I tried to give it just a little nudge but no way, it was secure. So much for a few seconds. I'm sure that nobody will be able to tell but just under the coaming there is a thin sliver of black that is actually the opening to below deck. Nuts! I was terrified to try the aft cabin now. Practiced that even more. Even so, it ended up just the smallest amount off the deck line I was trying to hit. At least both cabins are square to the deck and don't look off-kilter. The speed that the glue took hold and how firm the joint was totally surprised me. Sure, when I wanted the glue to give me some play it doesn't, and when I need it to be fast it isn't. I learned my lesson and, for the mooring bits, I inserted brass pins underneath and drilled register holes in the hull to make sure they would be glued exactly where I wanted them. Those went smoothly.
  21. Thanks, folks, for the support! I've noticed a huge improvement in my skills over the course of this build and, I think more importantly, an incredible increase in confidence. Having a lot more tools helps, too! Regards, Gabe
  22. February - May 2013 The Rudder I couldn’t make any sense of the instructions on how the rudder should be shaped. That was ok… this kind of stuff didn’t faze me anymore. I just hit the books and internet and soon had an idea of how I was going to proceed. But, sure enough, the kit threw another curve ball my way. The pintles and gudgeons supplied in the kit were just wrong. They were too long, extending past the edge of the rudder. Cutting them down was not an option because the pre-drilled holes were badly placed and, frankly, too few and too far apart. The chunk of brass rod that was supposed to be the pin in the pintle was massive. AND, even if I wanted to use these parts the brass snapped the first time I tried to shape it to the rudder. So…I began fabricating yet another set of parts. I already had some brass tubing and wire (I bought a good stash of these types of materials when a local hobby store was closing. Yup, materials and AL`s HMS Bounty and Harvey!) I just had to get some brass shim stock. Cutting with tin snips or scissors made an ugly curl on the edges, so I decided to just use a straight edge and a snap-blade. It takes a bit of elbow grease and quite a few passes with the knife but you eventually have strips that are quite even and usable. Using a snap blade it was easy to make sure I had a sharp edge. I cut 4 pieces of brass tubing to a length that matched the thickness of the strips I had just cut. I shaped the strips first by wrapping them around half of the tube to make a long, narrow u-shape. I then used a trick I learned when I had to teach electronics one year: I tinned the parts first. In tinning you pre-solder your parts separately where they will be in contact. When it comes time to attach the parts you just clamp them together and just heat the joint with an iron until the solder melts. I used a bit of sanding chord and sand paper to clean the surfaces. To hold things in place I drove a straight pin through the tubes into a board. I then heated one side of each tube while holding the solder against the opposite side. I repeated the process for the bent strips, heating the outside of the bend while holding the solder on the inside of the bend. It only takes a little bit of solder. I fashioned a clamp out of a clothes pin and, while clamping a tube and strip together I just heated the top of the tube just until the solder melted. There’s an obvious movement in the parts when this happens. For two of these I inserted a piece of pre-tinned brass wire into the tube. The next step was to drill the holes for the pins I was going to use to attach these to the rudder and hull. With some careful measuring and a bit of math I decided on a spacing that would look good on both the upper and lower pintles. After drilling the holes in the brass I placed the pintles on the rudder and used them as templates to drill the holes for the nails. Although I'm sure it's historically wrong, I wanted the heads of the nails to be prominent. I cut down oval-headed brass pin/nails and glued them in place with cyanoacrylate. The rudder was done, but I didn't install it yet. I wanted to construct the display base and have the hull mounted first.
  23. February 2013 Wales, stanchions, cavils, benches, fife rail, top rail, scuppers, “battens” Long ago I had planned on installing the stanchions (frame heads) in line with the butt lines of the deck planks. To ensure that I installed them parallel to each other I fashioned a jig for the width of the spacing using some picture matt board. I cut a pile of walnut pieces slightly over-sized so I could sand down to the top of the gunwales later. Before gluing each in place I filed a slight bevel on the bottom edge so that there wouldn't be a gap between the stanchions and waterways. Holding the jig up against the previous stanchion allowed me to quickly position the pieces. Spring clamps and clothes pins made sure of tight glue joints. Once dry, I sanded and filed the tops of the stanchions down to the top of the gunwales. Scuppers were next and, following instructions, I drilled through the bulwarks between the appropriate stanchions. What a headache this became! I ended up marring some stanchions and the deck slightly and had to do some sanding to fix up the boo-boos. Getting them to an even width was also a pain, even with careful knife work and filing. My only saving grace was that the upper wale would run along the top of these holes and at least hide one edge. I'd appreciate any insights on how to do this better next time. In order to get the placement of the main wale right I next installed the “bow gunwales” (not exactly sure what to call these pieces at the bow). A few passes with a plank bending tool allowed me to give them a bit of a curve. With the location for the top of the main wale established with these “bow gunwales” I now took out the wood strip from the kit and discovered that it wasn't low enough to cover the joint between the limewood of the bulwarks and the walnut of the hull. (I always wondered why this kit used two different woods like this). Over the years I've been buying all kinds of tools and stockpiling materials and this is when it all paid off. I happened to have a piece of mahogany the right thickness and a mini table saw so just minutes later I had new, wider planks for the main wales. While installing them I nearly burst into tears because the pins I used to hold them at the bow stood out like sore thumbs and I damaged the wood trying to sink them. I ended up sanding the end down a fair amount and gluing a small, wedge-shaped piece of the same width over the area. By carefully sanding this I was able to feather it with the wood underneath and the joint was invisible. The upper wale installed nicely. The disappearing patch Once the glue dried I drilled through the bulwark for the bowsprit and the grommets for the hawse holes. The kit supplied a little brass bushing to be installed for the rudder hole. After drilling through the deck I began dry fitting this bushing and I really didn’t like the look. Part of this dislike came from a period boat I saw in, of all places, Thunder Bay, Ontario. In 1987, just a few months after starting this model, my girlfriend (now my wife) and I were visiting her brother. We spent a day at Fort William Historic Park (http://www.fwhp.ca/ ) where, a little off the beaten path, was a lonely boat moored and undergoing some repairs. The masts were off, but as soon as I saw it I thought, “It’s the Swift!” Nobody was around to ask, but this was likely a replica of a trade schooner that would have plied the great lakes in the early 1800s. It was obviously not exactly a Virginia Pilot Boat, but there were some cool details that were likely accurate for the period and I decided to take a bunch of photographs. One picture was of how the tiller was rigged. So, instead of installing a thick brass bushing I crafted a wooden ring to surround the hole for the rudder. I used this same picture to shape the end of the tiller. I’m still debating about wrapping the tiller with metal, like in this picture. For now I’ve left it all wood. Photo from a period replica ship. The rails from the kit, in addition to being brittle and difficult to cut away from the die-stamped sheet of plywood did not match the shape of the gunwales. Because I had fabricated new gunwales (see earlier log entry) none of the pieces lined up properly. I did a bit of research on rails and found an article from a modeller in which he cut the entire top rail from a single sheet of plywood. So, I turned over the hull and traced the shape onto the same 1/16” plywood I had used for the gunwales. I drew offsets from this line to the width of the top rail and cut out a single piece using a fret saw. After a bit of shaping and sanding it was then glued in place, tacked with a few pins and clamped using large, reusable electrical tie wraps. By chaining two of these tie wraps together you can get a nice d-shape. Because of the curve at the bow the tie wraps don't work well so I used elastics. demonstration of how I chained tie-wraps to be used as clamps There were a few more parts that were either so brittle or poorly fitting that I had to refabricate them: the “stern battens” (I think they should be called standards) and the fife rail at the transom. I decided to shape the ends of the cavils to make them a look a little more authentic. Details at the stern - several refabricated. Yeah, the hole for the rudder now looks like a toilet seat! [i have to read more carefully or get a new prescription on my progressives! I thought the max size for ALL files in a post was 2 MB. Now that I know better, here's a pic of a cavil]
  24. Thanks, yet again, Keith! I have been following your log! I've been on this site for several months and was looking for ideas for my build. I am so impressed by your mods on the Swift. The bulwarks and decking are fantastic. (Love the figurehead, too!). I hate to admit that I haven't read all the pages - I think I was skipping along to parts of the build that would apply to me (I was looking very closely at your stand)...but I'll definitely look at your bending technique. I absolutely get the feel of community at MSW - and it's the main reason that I decided to post this log. I'm looking forward to many years here! I've been pretty much entirely using PVA myself...I was just wondering if you used cyano for the start of those planks. I'm not a fan of cyano either, and later I'll be posting my CA story for this build. On the first layer of this model I pretty well tried almost every bending technique. When I first started (1987) I got a little impatient with some of the steam techniques so I started microwaving planks wrapped in a wet tea towel. Lately, I like the plank bender (although I did chop right through a couple of test pieces at first! Moral of that story: look at the grain of the wood!. A quick dip in ammonia was recommended in one book I read...only to find in another book that says ammonia makes the wood brittle. Didn't read that until after I bought a jug...it's sitting in my work room right now. I may try it out on some scrap when spring comes around and I can work outside. Regards, Gabe
  25. January 2013 The Mistake It felt so good to be done the planking. I could now look forward to doing something different from shaping and gluing planks. First thing, I had to attach the stern post. And that's when I discovered The Mistake. Now, there were dozens of flaws in the model and I was expecting them. But, this was a big one. I was horrified to find that the deadwood region of the stern was MUCH wider than the sternpost. I had neglected to check the width of the hull before starting the second layer of planks. The wood and filler on the starboard side was left too thick. Checking the log book I discovered that this oversight happened 20 years ago! There was no way to leave it the way it was - but I did not want to have to destroy the second layer I had just finished and reinstall the pieces. I made a couple of decisions: 1. I would do a partial fix 2. I would never display the starboard side First, I shaved down the area to bring the width the same as the sternpost. I then glued veneer strips that matched the widths of the planks in this shaved area but were a bit longer and overlapped the lower wood. I even tried to match the colours. Once set, I sanded down the forward edges of the patches in an effort to feather the joint with the wood below. Except for the bend in the wood the actual joint almost disappeared. I was amazed. What I should have done at this point was just redo this patch job by shaving further forward so there would be a gentler taper. However, I was sick of planking and was worried that I would totally mess up the area. Besides…I was never going to display the starboard side! My credo about this model is now, “Don’t wreck the port side”. "The Patch" for "The Mistake". This little trick of overlapping wood to create a patch came in handy very shortly. ( ) Attaching the sternpost was pretty quickly done. Before gluing it in place I cut in a rabbet to hide the plank ends. Now that the sternpost was in place I could complete the planking of the stern and drill the hole for the rudder.
