Posts posted by mr_pullings
Well, disaster struck. I used some stronger clamps to bend the first broad plank and the frame lifted out of the building board. When I went to fit it back into the building board I guess I was too forceful and several of the frames broke. 😬
Maybe I'll purchase another of this kit and start over. Or just move on to the 18th Century Longboat I had begun. -
31 minutes ago, bobandlucy said:
Wow! Looks very clean with a perfect shape. Sure this is your first?
Bob
Thank you! Yes, this is my first. Just following the directions. 👍
- druxey and Ryland Craze
- 2
Ok, this will be my first wooden ship build. I had started a build thread for the Model Shipways 18th Century Longboat kit. But I felt like that kit was a little too deep of a dive to start out with. So now I'm beginning with the Lowell Grand Banks Dory.
I've been working on it for several weeks now. The biggest problem I've run into is forgetting how fragile this wood is. Luckily I was able to painstakingly glue back pieces of the frames that I broke (some more than once). And everything seems to be holding together so far.
On to the pictures:
Forming the rocker
Gluing frames
Time for glue...
Working on garboard planks
Bending
Gluing first garboard plank
Both glued, commence sanding
Inspection
They don't line up perfectly at the transom and I really don't want to remove it and start over. So I guess we'll just roll with it and see what happens.
That's all for now...
- 2
Yes, this helps a lot. Apologies for deleting the question. I didn't think it was worded well (and I'm a little embarrassed).
My misunderstanding was thinking that the sanding would go *up* from the bearding line. Also, I clearly didn't understand what beveling meant. So thank you again for the illustration.
- Cathead and Keith Black
- 2
Ah, I see now. That's along the lines of what I was thinking. I just wanted to make sure before I began sanding off a bunch of this piece. Thanks!
- Keith Black and Cathead
- 2
I'm unclear on the beveling of the false keel. Does the entire false keel, above and outward from the bearding line, need to be sanded down to ~1/32"?
I've looked at a few build threads and couldn't get a clear idea of this step.
04/04/21
Well I wasn't planning on starting this one yet. However my airbrush is temporarily out of order. So for the moment I can't finish the Tamiya M4A3E8 Sherman I was close to completing. 😠
Again, this will be my first wooden kit. I may have done a plastic ship or two way back in the day. This is actually the Model Shipways combo kit that came with paint, glue, some tools, etc. The first thing I had to do was to take inventory and orient myself with what was what precisely. And it entailed using a ruler, some masking tape and a pen. I wish I had more exciting progress to post. But I'm still reading through the instructions (again) to come up with an outline. I will definitely have some questions right off the bat. For now, though:
Wish me luck!
- Sea Hoss, Ryland Craze, Keith Black and 1 other
- 4
On 3/14/2021 at 2:18 PM, mtaylor said:
Just a thought... play the Master and Commander movie with the sound up. Close your eyes and listen. Their sound team did a good job on background noises. It's not perfect of course, but the ship sounds are there and so subtle that you really have to listen for them. If you've ever watched it with the sound off and subtitles on, you know there's something missing.... that background noise.
They really did do a great job! Master and Commander won two Academy Awards and one was for sound editing. It's quite something when watched with a decent surround sound system.
I've been getting back in to plastic models due to the pandemic. It's been really wonderful that there's so much more information available thanks to the Internet. YouTube has been especially helpful. The last models I built were in the late 90's/early 2000's, when expensive magazines where the main source (that I knew of) to learn techniques, etc. So far it's been going well as I learn how to use an airbrush (first one!). After 3 completed kits so far I've definitely learned some important not-to-do's!
Because Patrick O'Brian's Aubrey/Maturin series is one of my favorite series of books I've taken an interest in building a wooden ship. I took the plunge with ModelShipways' sale they were having recently. So I now own a 1:24 Lowell Grand Banks Dory kit and a 1:48 18th Century Longboat (combo) kit. I'm looking forward to beginning with the Dory here soon. After I finish up a Tamiya "Easy Eight" Sherman I've been working on.
This forum looks like a great place to learn from as I've already been browsing. When I get started I'll be sure to start a build thread. Maybe someday I might be able to build a full size Dory to fish from!
- mtaylor, Keith Black, JeffT and 1 other
- 4
Lowell Grand Banks Dory by mr_pullings - Model Shipways - 1:24
in - Kit build logs for subjects built from 1851 - 1900
Posted · Edited by mr_pullings
It's beyond my patience to try and fix. A couple of those frames were already weakened from where I accidentally broke them earlier. So I'll probably buy another kit and start over. Lessons learned!
