ECK
NRG Member-
Everything posted by ECK
Looks Great. Good planking work.Here is a picture of the stern are of my HMS Surprise, a very similar frigate design. You can see how low it is below the bulwarks. You may be running into the same issue I had with the whale being too wide.There is a discussion on my build on it and if you look at the Diana book you might see a difference from the instructions. I had to cut mine down. Yours looks about 1 row too much. Sorry if giving advice but the comments from others saved my bacon.
HMS Diana by ECK - Caldercraft - 1:64
ECK replied to ECK's topic in - Kit build logs for subjects built from 1751 - 1800
Nice work but having recently wrestled with the stern fascia I think it is high in the picture as the windows line more with the bottom of the lower deck gun ports. If you look at the box picture, the upper deck bulwarks end stick up above the top of the stern piece. The side galleries would be to high as well. The instructions are hazy of course. The book picture also has it lower to my eye. It may be just the angle of the side shot. ECK
I think the error turned out ok as when you look at the Diana book, the wale is narrower and lower with more distance between it and the gunports. I have found the pictures on the box and plans do not always correlate well and some things do not fit quite right depending on where you look so I have made a few adaptions to get things to line up especially with the side galleries/ -
Good to see you back. Had used your build for some references earlier. -
Just added the b ling. There is a beam that goes atop the side gallery in the plans but I can't find anywhere where they describe or number them to knwo how to make it. Any suggestions? Still have to add the side figures to the stern -
Copper always looks nice. Left stern unfinished as I will put in the rudder after doing the lower hull painting. Rudder easier to do now with nothing to damage on upper decks. -
This is how the coppering will look. I taped out the line and painted the area copper to help hide any slight spaces after the copper goes on and provides an edge -
So here is the new look. It looks appropriate although if you look at the model on the box it does have the 1+6 strakes. The above picture has 4 of the 1x3 mm strakes and is less curved than the model plan so will stick with the real thing as outlined by our gracious expert. Pardon the copper paint but I was prepping the back ground before I had to make the adjustments so will remark out the copper lines later. -
Thanks all for the info. I agree it seemed too large despite the plan's instructions. Looks like I need to remove the 2 lower strakes. Will give it a try this evening. Stay tuned. -
I checked the instructions, so 0.5 by 3 mm strake starting below top 1 by 5 mm second plank then 6 1x3mm after it for total of 21 mm or 7 planks. The strake by the picture may make it look wider from the angle and hard to distinguish it so not sure to leave as per instructions or remove lower most plank. -
Finished the whales, I think needed a bit more curve but followed the plans. When I look at my Agamemnon, it should be okay. Gun deck ports and bulwark painted.At this point I am going to copper the hull for the next couple of weeks. I find it easier to do now as nothing to damage when I have it flipped over or sticking out to snag . -
After sanding, filling defects and sanding am ready for the whales, then paint the gun deck then copper. -
So I first saw an add for HMS Victory by De Agostini. Formidable as first build, my kids said I should do it, having previously done balsa wood airplanes. SO I got it 5 yrs or so ago. It had excellent instructions and You tube videos. Although not perfect came out reasonably well. Then did their Soleil Royale (plans ok) and constitution (had to print instructions from internet). The company plan for planking involves using more stealer strips than trimming for the bow. Also coppering done d\differently with straight line at water level and then cutting pieces at keel. Easier to get straight line that way. Finally did their Surprise kit, which was the prettiest but plans less detailed. Had to do mast/yard and rigging from on line plans. Major issue with the company is horrific costumer service, often never getting replies or the parts. An issue as had often missing cast parts (which I eventually received). Hard to buy needed pieces as have to search to fing products similar as the company does not say where source kits are from. Next did Caldercraft kits. Plans ok but helped that I had done the others. Only pars issue is never enough rigging line for running rigging but easy to buy. Did one Occre (Montanes) kit and have Trinidad waiting to start after Diana. Instruction not to bad but short on some rigging thread and blocks. Also box did not have brass cut out for stern and had to have them send it . There costumer service site works but took a few months to cross the pond and I had to do follow up emails to make sure things were being done. All in all, although plans, depending on the model, are a little harder to follow, most complete kit were the Caldercraft ones. Only wish could have sails but the ships look good with just the rigging. After looking at this form, I am can't wait until the Amati Victory is available as will be the biggest model to date. Has anyone heard about when it might come out? ECK -
Glad to hear form the originator. Actually look forward to working on it. It is definitely not a beginner kit but after a couple of thers it is manageable especially with these forms where you can see what others have done. -
I also wished the false keel and bow could be added latter as in most other models as it makes planking easier and neater. -
Thanks. With the kids in college, I can spend 2-3 hrs a day working on it as my stress reliever. Biggest problem with the kit is the vagueness of instruction at times, definitely worse than other of their models. Will sand today and fill in cracks as it will be all painted and coppered. I will then put in the whale and copper. I like to copper at this pint as it avoids breaking things . They should change the order in their instructions. -
Yes It is planked to the stern and trimmed off
