Waldemar
Posts posted by Waldemar
  1.
    3 hours ago, Alvb said:
    Is there any evidence of what the hull and frame lines of older carracks looked like, around 1450 to 1470? And were there differences between English and Dutch carracks?
    Quite possibly the Northern European Late Middle Ages, with its Hanseatic cogs and other cog-like vessels, Scandinavian ships, earliest carracks, etc., and all their somewhat later derivatives, also needs attention, because this period is in fact as conceptually unexplored as the early modern era has been neglected so far.
    Funnily enough, various researchers are able to carry out really complicated hydrostatic and hydrodynamic calculations, as well as expensive experiments of various kinds, including real-scale sailing, except for the “ trifle” that it is still unknown how these ships were actually designed to satisfy the results of all those modern scientific tests and calculations :).
    As a result, it is simply not possible in the present state of knowledge to draw some conclusions of a more general nature, for example to the extent you ask.
  2. On 5/27/2025 at 8:23 AM, Alvb said:
    Only the reconciling sweeps—circular segments that connect tangentially to given arcs—should be easy to find using graphical methods, but no!
    Could you perhaps briefly explain to me how to find these sweeps?
    It occurred to me later that one could still show a geometrically rigorous way of determining the reconciling sweep tangent at both ends (that is, to bottom line on one side and to lower breadth sweep on the other). Although the method is extremely simple, it is highly doubtful that it has been used in practice, and especially at actual scale on the mould loft, as can be seen particularly well on sample number 3, where the auxiliary lines extend far beyond the contour area of the frame.
    The method using a flexible instrument, shown previously in the entry #40, is by far the preferred one, not only because it is hassle-free, but also gives excellent results in terms of the precision of the contours obtained, and this is true even allowing for the minor inaccuracies of handling such a flexible instrument.
    Be that as it may, below is a method employing formal geometry:
    1. make a perpendicular to the line of the bottom at point A,
    2. mark point c2 on this line at a distance R from point A,
    3. connect points c1 and c2 with a line,
    4. find the midpoint of the line c1–c2 and make a perpendicular at this point to line c1–c2,
    5. the intersection of the two perpendicular lines (described in steps 1. and 4.) yields point c3, which is the centre of the reconciling sweep.
  3.
    The fact that the joinery is anything but sloppy (or perhaps better: irregular) does not mean that the design itself was also careless. Let's take, for example, the buildings of the Incas, the pyramids of the Egyptians or Neolithic Stonehenge. Despite the considerable irregularity of the stone components used, astronomers still find remarkable precision in the assembly of these structures. The same is also perfectly true today — aesthetic aspects aside, it actually does not matter whether the floor in flats and offices is made of boards or tiles of varying dimensions, as long as it is level and sufficiently even. So why waste a good material?
    The oldest shipbuilding manuals very rarely mention the width of the planks, if at all, as opposed to their thickness and sometimes the minimum length required for more "strategic" components of the structure.
  4.
    Well, fine, now that it's “all” cleared up, I at least have a smooth excuse not to spend a perverse amount of money on the decent quality copies of source material needed to prepare free presentations after all. I'm off back to my favourite 16th and 17th century (and European archives :)).
  5.
    41 minutes ago, Martes said:
    It's the European, and in particular, French privateers you're looking for.
    Ah, you may have spoiled my surprise, but perhaps that's for the better, as the further fate of this very venture is quite unclear indeed. On the one hand, you might have had it easier, as we have discussed the issue privately before, yet, on the other hand, with your watchful eye for shapes you yourself must also have noticed the striking resemblance to French light craft of Louis XIV's time, such as the frigate l'Aurore 1697 (body plan shown in the thread on the Mary Rose 1511).
    Now, I would still like to say that people, while attempting similar analyses, usually focus on comparing dimensions, which is completely missing the point. After all, absolute dimensions, just like many of the proportions, are simply determined by a kind of circumstances which have little in common or being quite independent of design methods, as you pointed out above.
  6.
    9 hours ago, Chapman said:
    M.V. Brewington thought about the design of the first US frigates many years ago.
    His article, with plans for the first US frigates, can be found online. I don't know if you're familiar with it.
    Published in: The American Neptune Vol. VIII No. 1 January 1948
    Indeed an excellent article (and easy to find online) — many thanks, Chapman. In a convenient, compact way, it provides information that creates the necessary historical context for this issue. I have also refreshed myself with the content of the related section in The 32-gun Frigate Essex (1799) by Portia Takakjian, published 1990, however, it looks like, that in terms of today's state of knowledge regarding the design methods employed by early American designers, the statement just made by Brewington in his 1948 paper is in fact still relevant:
    BrewingtonM.V.-DesignsofourFirstFrigates-cap_34.thumb.jpg.09c7aa50d0f3620c5b8cc41cc35f0789.jpg
  7.
    22 hours ago, trippwj said:
    The original photos of the pages are not publicly available (ownership issues).
    The document is available online for anyone interested (see link below), just only up to page 162 of the manuscript. In a malicious twist of fate, the page with the data for Randolph 1776 is already on the next, first page of the non-accessible part of the whole document, that is 163–164. And the archive wishes USD 37.50 for making one scan of this double page available. Funny.
    Historical Society of Pennsylvania: DAMS : Volume/Folder : Principal Dimensions [1719-1828] [10581]
    Under the circumstances, I won't even bother to approach the other archive (the navy) for a better copy of the original ship's plan anymore, and I think I'll give up on this project altogether. It's a pity, because the results and conclusions of this investigation could be really interesting, and actually unknown or unrealized until now. More precisely, I already have near certainty about the design methods applied in early American ships, nevertheless, adequate input material is obviously needed to present this adequately.
  8.
    Thank you, Tony. Yes, I have this publication in my home library, as well as probably all of Chapelle's other major works. Indeed, there is a wealth of interesting, important and useful information about this frigate (actually the whole frigate series) contained therein. Nevertheless, I intend to do something that even Chapelle himself did not do, which is to reverse-engineer the design of the Randolph, and to do this I need a copy of the original design in the best possible quality, as opposed to later redrawings which necessarily distort the original somewhat and, worse, somehow lose very important details found on the originals. By the same token, British-made plans of these early American ships are also unsuitable for my purposes.
    The point is that I have some observations about the presumed design method used (in a conceptual sense) and I would like to take a closer look at this for confirmation (or otherwise) of these presumptions. They may explain why the American designs were marked by such a specificity of shape rather than another.
  9.
    14 hours ago, trippwj said:
    I can vouch for the accuracy of the transcription [...].
    Thanks, Wayne. Nonetheless, I'm already having some doubts as I've noticed in several places in the document that ‘foremast’ has been reworded to ‘foremost’ (and the other way round) and in addition, for Randolph itself, the distance between decks seems to not match the draught (5‘ 2" versus 5‘ 7").
    And, almost forgot, the Randolph is listed in the title as a 23-gun frigate instead of 32-gun one.
  10.
    This is most probably the only US ship (frigate) from the Revolutionary period for which original plans have survived. Admittedly, they are available online, but the quality is not the best, as it appears to be essentially a scan of aged microfilm of not very good sharpness, so a lot of the detail is blurred. Does anyone have a better copy than the one available on the archive website?
    In addition, does anyone have and can provide a good quality scan of a page from the Joshua Humphreys' notebook concerning this very frigate? Granted, this page is already transcribed and available (as is the entire manuscript), but I would nevertheless like to verify the numerical data, which is quite easy to get wrong in the process.
    Besides, what does the term ‘hanging gundeck’ mean? The stated value on the transcribed page is 1 foot 7 inches.
    The copy of the draught itself available at:
    https://www.history.navy.mil/our-collections/photography/numerical-list-of-images/nhhc-series/nh-series/NH-65000/NH-65618.html
    And reproductions of both mentioned above items:
  11.
    2 hours ago, Kenchington said:
    There's an embarrassing story to that one.
    Thank you also for that last entry, Trevor. Some interesting, previously unknown details, giving useful context and enriching the overall picture.
    As for your reservations about your text, well, that's my personal experience too, as well as probably that of many authors in the world. I've even accumulated quite a few things that I myself would like to improve on in my past publications, be it paper or on-line, nonetheless one usually doesn't go back to it anymore, just creates new things... There is simply no such thing as absolute perfection and this has to be taken into account. But that's still not at all bad, like completely abandoning further attempts or research.
    I'm also glad to hear that you've remained a fan of the field despite the different paths your career has taken :).
  12.
    Oh, also a mention that I am familiar with one of your publication, indeed already decades old, yet still relevant and I actually use it as well. Attached below for convenient access for possible readers.
    Trevor Kenchington, The Structures of English Wooden Ships: William Sutherland's Ship, circa 1710, 1993:
    Kenchington Trevor - The Structures of English Wooden Ships - William Sutherland's Ship, circa 1710 - 1993.pdf
  13.
    1 hour ago, Kenchington said:
    When I got drawn into nautical archaeology [...].
    I'll say frankly that I enjoyed the spirit of that post, especially the observation (if I understood it correctly) that for effective puzzle solving in this particular field, even the closest interdisciplinary cooperation, which can work so well in most other fields, may not be enough. The way I see it in practice is that, to oversimplify somewhat, historians usually have no idea about engineering, engineers usually have no idea about history (including the history of shipbuilding), on top of that one still has to know several languages (written period sources!), geometry, know CAD software for the necessarily personally conducted tests, be critical, persistent and enthusiastic, and so on. Ideally, it all just should be in the same head, if possible.
    And well, yes, I have read somewhere that the term "Fragments of Ancient English Shipwrightry" for Baker's manuscript has been in reality coined by Samuel Pepys a couple of decades later :).
    1 hour ago, Alvb said:
    If only these texts were available in a precise German translation, how I would love to delve into them...
    Indeed, today's translators do particularly badly with Germanic languages for some reason. I don't think I can help much, except that, if necessary, I can sometimes try to describe something in other words, in the hope of a better automatic translation. But that's also one of the main reasons why I generally reduce the volume of text in favour of graphics.
  14.
    On 6/1/2025 at 1:33 PM, Kenchington said:
    However, I still get the feeling that I am missing the foundations of your conclusions.
    Nevertheless, I would still like to show a quite fresh paper (a 2023 publication on the very important shipwreck of the Lomellina of 1516), which exemplifies the way in which archaeologists up to now actually evaluate shipwrecks in an attempt to reconstruct their shapes. In the shortest terms, missing conceptual elements, such as the rake of the posts or the rise of the decks, are borrowed from some manuscript of the period that is deemed adequate (which may still be appropriate in itself, albeit under certain conditions), yet further on this attempt is reduced to merely manipulating the cross sections to just get the hull shapes as smooth as possible, and by the modern method of synchronising hull lines, which has little in common with the methods of the era. And nothing more, no effort to deduce the true design method that was actually used by the ship's builders.
    Personally, I have no objection if someone is satisfied with such archaeological evaluations, however limited in their aims, scope and methods. But by being carried out in such an unambitious manner, they certainly cannot clarify perhaps the most important issues, namely those related to ancient ship design methods. On the other hand, such a state of affairs is also the result of a generally poor level of knowledge in this area, and this, in turn, precisely of the pernicious influence of today's doctrines which, through their misguidedness, have in fact only led to practical impotence or stagnation and a consequent lack of progress in this kind of research. I am thinking in particular of the today's doctrine of shipbuilding by ‘feel’ or by ‘eye’, i.e. with virtually no conception whatsoever (yet so convenient for humanistically profiled scholarship), and the doctrine of the ‘spontaneously or independently born English school of design’ (yet having just been virtually stripped of its alleged ‘evidence’), and this still conceived in a frighteningly orthodox manner.
    However, just to repeat — if someone is nevertheless satisfied with such a take, there you go.
    Max Guérout, Beatrice Frabetti, Filipe Castro, Revisiting Lomellina,  1516: The Hull Shape, 2023:
    Guérout Max, Frabetti Beatrice, Castro Filipe - Revisiting Lomellina, 1516 - The Hull Shape - 2023.pdf
  15.
    Hello,
    The excellent sources for the rigging of 18th century Spanish ships are certainly:
    — Juan José Navarro, Álbum del Marqués de la Victoria 1719–1756, Lunwerg Editores, Museo Naval Madrid 1995, ISBN 84-7782-352-9
    On-line alternatives:
    https://catedranaval.files.wordpress.com/2014/09/mdlv.pdf
    https://armada.defensa.gob.es/museonaval/aplicaciones/coleccion-marques-victoria/#
    — Isidro Rivera (ed.), Arboladura y jarcia española de la segunda mitad del siglo XVIII. Compendio Compuesto por: Cartilla Marítima, Santiago Zuloaga 1760 & 1766. Tratado instructivo y práctico de maniobras navales, Santiago Zuloaga 1766 & Reeditada 1806. Reglamento de Jarcia, Marqués González de Castejón 1773, Associació d'Amics del Museu Marítim de Barcelona, Barcelona 2010, B-42878-2010 (includes rope dimensions)
    https://bibliotecadigital.rah.es/es/catalogo_imagenes/grupo.do?path=1006025
    https://bvpb.mcu.es/es/catalogo_imagenes/grupo.do?path=151659
    — Modelos de Arsenal del Museo Naval. Evolucíon de la construccíon naval española, siglos XVII-XVIII, Lunwerg Editores, Barcelona–Madrid 2004, ISBN 84-7782-959-4
    — Isidro Rivera, Joseba Burdain, Jesús J. Adán, Teoría y Práctica Ilustrada de la Maniobra Naval Española según el Marqués de la Victoria 1729–1752, Vagara 2021, ISBN 978-84-09-55974-9 (excellent, detailed explanations, both textual and pictorial, yet without dimensions of the rigging components)
    Promotional pages of the latter item (by the author):
  16.
    As a kind of epilogue to this thread, I am also including here a case from another, rather distant part of Europe, nevertheless thematically and chronologically highly relevant to the issue.
    In 1570, the Polish ruler Sigismund Augustus, intending to build a royal fleet practically from scratch, instead of turning to Gdańsk/Danzig, which, after all, was at the time one of the largest, if not the largest builder and exporter of ships in Europe, but over which he had almost no political control, asked none other than the Venetian doge to send an expert (granted) who could design and build ships. Most telling, however, is the expressed rationale for this request, clearly stating that Venice was second to none when it came to the ability to build the best ships in the entire known world of the time. Or at least that is what was thought at the time.
  17.
    I would also like to add, for the sake of greater clarity, that this very issue, in its historical terms and significance, is indeed very closely related precisely to Mary Rose herself, and more specifically to her incomplete, haphazard and simply wrong conceptual interpretation (or rather only a residual attempt at such an interpretation, limited to ‘forceful’ matching of a more or less random arcs to the contours of Mary Rose's frames), published in one of the chapters of Mary Rose's archaeological monograph. Archaeologists themselves, or at least some of them, are nowadays drawing attention to this fatal circumstance, it is just that no one has so far been able to offer a complete yet convincing solution.
    In addition, this disastrous state of affairs has also been largely contributed to by the failure so far to offer a proper study and publication of Mathew Baker's manuscript, which essentially, as it seems, describes the Venetian methods he learned there. In fact, even the availability of the manuscript itself is so far strictly restricted to only a small circle of interested parties, maybe not without reason. As a result, in today's historiography and consciousness, “classical Venetian methods” are taken for “classical English methods”, and — quite ironically and also misleadingly — the Baker's manuscript itself is even called the Fragments of Ancient English Shipwrightry.
    I am attaching below a file with published conference materials from 2003, from which one can see just how weak premises today's doctrine on this issue has been based on (apart from the general historical ones, which by the way you cited earlier, the catastrophically wrong conceptual interpretation of the Mary Rose case and a handful of rather naive explanations, or rather speculations, of a conceptual nature). Sadly, this is the result when technical issues are looked at and explained in, shall we say, a predominantly “humanistic” way.
    In fact, it may be even surprising that nobody has done anything about it so far, at least not in an effective way, but this, I guess, may have been influenced by more than just substantive considerations.
    Nowacki Horst, Valleriani Matteo - Shipbuilding Practice and Ship Design Methods From the Renaissance to the 18th Century - 2003.pdf
  18.
    Are there earlier threads in which you developed your arguments?
    Thank you very much, Trevor. Yes, a whole series of threads in this area have already been created. The majority of the most mature, and also the most closely related to Mary Rose's case, as they concern the Northern European tradition, are on the sister nautical-modelling forum (easy to find, I believe). All in all, it has been quite a long and difficult road allowing for the eventual breaking free of the overly speculative and yet universally uncritically accepted doctrines of today on this issue.
  19.
    Later design parallels
    Ships of similar design concept to Mary Rose 1511, from different periods and different regions of northern Europe, have already been mentioned earlier in this thread. Below are a handful of such quite numerous, specific examples, ready at the same time to be shown graphically.
    Among the cases studied in detail so far, mention should be made of the design of the French heavy frigate of 1686 by Pierre Chaillé (relevant presentation to be found in another forum), and the design of the French light frigate l'Aurore of 1697 by Philippe Cochois (awaiting a separate detailed presentation). Here a reconstruction of the body plan of the latter frigate superimposed on her original period plan. Among the fundamental features, decisively determining the similarity of the methods employed, attention should be drawn first and foremost to the order in which the contours of the conceptual frames were formed, as well as the specific geometrical procedures used for this purpose. Identical as in the Mary Rose case, the bottom (green) was formed first, followed by the lower breadth sweeps (blue), and only in the last step were the two sets joined by reconciling sweeps (red), tangentially at both ends. Among other things, it is still worth pointing out here not only the very fact of the use of quarter frames, but also the same specificity of their use as in the case of Mary Rose.
    And the draught of l'Aurore of 1697 in its entirety, including the body plan shown above (French archives):
    Regarding the fundamental importance, in conceptual terms, of the hull bottom, which is in fact the design basis of ships built in the Northern tradition (in the literal sense, as opposed to the Mediterranean tradition), and the specific use of quarter frames, this is particularly very well illustrated on the surviving design proposals of French capital warships of late 17th century. Below is a drawing of one such design for a first rate ship by Laurent and Étienne Hubacs from 1679 (French archives), and among the not very numerous design elements (but already unambiguous for obtaining the specific form of the hulls), there are in particular the two design elements mentioned earlier (that is, the bottom featuring its curves and both quarter frames). Notable are the much fuller shapes at the midship than those of the Mary Rose (providing in themselves better lateral stability and, of course, carrying capacity), required for a heavily armed vessel. In passing, only one of the two double master frames is drawn on the plan (the aft one is omitted), presumably because of the quasi-identity of this pair.
    In fact, it can be said that the entire description of the Mary Rose's design concept so far, even including the comments on the specifics of the shapes and the resulting properties of ships, is also relevant to the above examples (which, of course, no longer applies to their proportions, individually selected for the intended, specific application of these vessels). Also, by the way, it is worth appreciating the overall flexibility of the Northern method, allowing a wide range of shapes to be obtained according to needs and requirements, which is probably why, among other things, it has been widely used for such a long period of time.
    It is possible to point to more similar period sources, written and iconographic, as well as providing more detailed explanations, but I guess everything should have its limits 😊.
    Nevertheless, leaving aside the almost unexplored archaeological finds from this conceptual angle, it is probably appropriate to point out, perhaps more as a curiosity, yet attractively much closer chronologically to Mary Rose 1511, the case of an intriguing votive model of a galleon, dated to the late 16th and early 17th centuries, now in the collection of the Historical Maritime Museum in Stockholm (Votive ship -Sjöhistoriska museet / DigitaltMuseum).
    Although an attempt at a conceptual reconstruction of this model has already been made by Peter Kirsch and presented in his excellent publication The Galleon. The Great Ships of the Armada Era, published in 1990, but now, in the light of recent investigations in this area, it may raise objections due to it being essentially based on English shipbuilding manuscripts of the first half of the 17th century, closer to Mediterranean traditions, which in effect generated the trapezoidal hull cross-sections in this reconstruction, characteristic precisely of Mediterranean three-arc master frame designs.
    However, the cross-sections reconstructed in this way are quite noticeably different from the round cross-sections featured by the original model, as can be judged from the following comparison graphic (as an aside, an identical treatment was attempted in the inevitably unfinished attempt at a conceptual reconstruction of the Mary Rose herself, published in one of the chapters of the ship's monograph). Naturally, it has to be taken into account that the hull of the original model is probably somewhat flattened in the manner typical of votive models; nevertheless, the specificity of the shapes in this model is quite telling and begs for the use of Northern, single-arc master frame design (plus reconciling sweep), precisely as in Mary Rose 1511. Admittedly, on the one hand, such a choice might be made easier by more confidently establishing the provenance of the model itself (essentially unknown) on criteria other than the shape of the hull, yet, conversely, this very feature might help to establish the place of origin and time of its creation.
    As for the plausibility of the very specificity of the shapes of the Stockholm galleon model itself, at least in the light of the corresponding cross-section shapes of the wreck of the Swedish naval ship Bodekull, in service between 1661 and 1678, it does not raise any reasonable doubts, as can be compared with the sample graphic below. It is worth noting here that Bodekull was built in the period when English design methods were only just beginning to be implemented in Sweden.
    The 3D scan of the wreck is made available on the Sketchfab website by Swedish Historical Maritime Museum (3D models by SWEDISH NATIONAL MARITIME AND TRANSPORT MUSEUMS (@maritima) - Sketchfab), and more about this wreck and the ship itself may be found in a paper by Niklas Eriksson, A New View of the ‘Edesö Wreck’: identifying the Swedish naval vessel Bodekull, built 1659–1661 and sunk 1678 from written sources, 2018, and attached below.
    Eriksson Niklas - A New View of the ‘Edesö Wreck’ – identifying the Swedish naval vessel Bodekull, built 1659–1661 and sunk 1678 from written sources - IJNA 2018-47-2.pdf
  20.
    48 minutes ago, Baker said:
    So they went to battle in a rather hasty and disorganized way, it seems. In an area with little room to maneuver.
    Thanks a lot, Patrick. That's interesting and new information you provide above regarding the unfinished process of clearing the ship. Also, this is probably a good time to say that your adventures or endeavours, especially those concerning the formation of the hull shapes of your impressive Mary Rose model, which you show in your thread, also influenced the very idea of dealing with this case :).
  21.
    Admittedly, It was still planned to make and present a regular line plan of the underwater part of the hull, possibly for use in model building, for example. Instead, until then, for a demonstration of the final shape of the underwater part of the hull, below are quick renders including waterlines, perhaps best illustrating the nature of the Mary Rose's hull shapes. As a reminder, the waterlines shown here are purely consequential, that is, they took no part in the formation of the shapes (i.e. on the basis of the cross-sections, waterlines and buttocks synchronization, procedure not applicable at the time). These were obtained in their entirety by the found design method shown earlier.
  22.
    7 hours ago, Martes said:
    [...] because until introduction of heavy broadside artillery this was a very successful design [...].
    Agreed. Overall, the hull shapes may be considered successful indeed, deserving the term ‘the noblest shippe’ — the lines of the hull seem to be sharp enough for the ship to move and keep to the wind well, yet not excessively, which would only make her prone to the pitching effect and to the rapid hogging as well (incidentally, as could be revealed from the wreck's scan, at the time of her demise, some 1.5–2 feet at the midship). Just that circular hull cross-section with the narrow bottom, and the resulting lateral stability problems...
