Posts posted by ronald305
the blades 39-925 you mention Tom I already ordered them from micro-marks LOL and also ordered the 1/4 Forstner bit as well
Ronald
how do I find his store are you talking about a drill bit or a special knife
great idea pm using a forstner drill bit for your gun ports may I ask what size bit you used to drill for the gun port holes I need one that is under 12mm
Hello there
I am in the process of cutting out the second level of gun ports on my model space Victory and found that the x-actor blades are not cutting to good even being new the instruction say to cut diagonally to the center hole and dig out the rest and to leave enough wood to sand to the right dimensions which would be 12mm X12mm, but it is taking way to long my question is there any super sharp blades that would cut thought balsa or what ever the planks are made of to fit a #11 handle
will scalpel blades work better I know they are extremely sharp any suggestions would be fine thank you
Ronald
I like the steamer you have there may I ask where you brought it, for now all I have to bend planks ard a bending iron and a crumper the head of the iron is too
big for the type of turn I need to do for the stern hopefully the instruction will
explain how to get the tight turn for linking the stern when reach that part of the build
Ronald
I understand you moved my post to a appropriate area but may I ask where did you move it to and has any one replied to it because I can not find it now thank you
Ronald
Hello there
I am working the model space Victory and would like to know how to make the sharp bend in the planks for the stern area
of the ship for the bottom when I reach that part of the instructions and most certain that the instructions will not explain how to do it, the video does show a little of how it is done but not very understandable so that is why I am here any suggestions would be most appreciated thank you
Ronald
HI Mike
great job on your completed victory may I ask when you was cutting out the entry ways where the dimensions12mm width wise like the gun ports I want to make sure before I get to that part of the build I'm doing the model space kit version but based on the AL kit like yours
Ronald
it not really about the kit it self but the actual the accuracy of the real thing it doesn't matter who's kit it is even Gill
Victory the entry door looks smaller then the gun ports but any way I ask Kevin
Ronald
HI Jerry
great job you are doing on your victory I have a confusing question what is the accurate door entry
to a gun port now I know your victory is much bigger then mine I'm dong the model space Victory I'm taking that into account, reason I'm asking is I notice the door entry is smaller then the gun ports what are the dimensions
of the gun ports on your model mine is 12mm but the confusing is in the instructions for my model the door is 12mm wide just like the gun ports should the entry be a tad smaller thank you
Ronald
Hey Tom
I have another question for you
on page 27 I could not make out the cannons on the top deck what kind of cannons are they that hardly have any wheels if they do have wheels I can hardly see them the lower deck have cannons with wheels how come the top ones have funny carriages thank you
Ronald
Thanks Tom
for the info and a good idea, it figures that they stop a good thing like selling sets of certion thing
hello there
was wondering why no one can answer this question I asked on July 14 who makes the best USS Constitution
kit thank you
Ronald
Hi tom
I just caught your build log of the Connie you are doing a great job on her may I ask you why you purchased
more cannons didn't the kit come with canons thank you
Ronald
too bad it would have been a nice feature
Ronald
HI Gil
I know the Victory has been finished for some time but would like know how did you figure out the height for the
dowels for making the jig in order to hold the victory up side down for planking and plating the bottom I want to
do that for the Victory I'm doing do they have to be a little bit longer so the ship sits on the support base like in the photos
Ronald
he's right there isn't any
Hello there
I see that you are also building the model space Victory so may I ask you question since Alan from the model space takes a while to reply back, when you got to planks 8 &9 after finishing plank 7 did you notice as I did that they do not mention anything about not tapering plank 8 they only say you do not need to taper plank 9 my question to you is did you taper plank 8 or not even the video left it out as well it only mention plank 9 not having to taper also would like ask you how when you was planking the bottom how did you go about making the tight bend in the stern area with out breaking the planks thank you
Ronald
can you send a link straight here some of us do not have face book or don't want face book
Ronald
- John Allen and mtaylor
- 2
cutting out the gunports
in Modeling tools and Workshop Equipment
thanks for the knife links
