Laggard
  • Gender
    Not Telling
  • Location
    Los Angeles
Contact Methods
  • Yahoo
    Brianwisconsin@yahoo.com
  1. Roger: Like these? https://garrettwade.com/product/archimedes-screw-drills
  2. Tough to find. I’ll keep looking. Thanks. So far all these solutions are out of my price range. Can someone suggest an affordable push pull drill? I bought a really cheap one but it’s not much better than useless.
  3. Thanks. Using a pin vice to pre drill holes for dozens of lill pins seems tedious.
  4. Do any dremels have a 0-36K rpm variable speed? Variable speed drills seem to have three or four speed settings. I need something that can turn at 300 rpm if needed. Thanks
  5. Instructions call for basswood. I screwed up the two provided pieces. No idea how important the wood type is. I have no access to power tools.
  6. Google fails. I tried every modeling site I know with no luck. Anyone? Thanks!
  7. Knee Pads - used for protection as you crawl around on the floor looking for the 2 mm block you just dropped. Broom - a household cleaning device only used when trying to find and sweep up the 2 mm block you just dropped and couldn’t find after 15 minutes on your hands and knees.
  8. My only build would float. Until the putty disintegrated and the integrity of the hull went to heck that is.
  9. Perhaps I should ask how quickly would your builds sink?
  10. “BELT SANDER : An electric sanding tool commonly used to convert minor touch-up jobs into major refinishing jobs.” LMAO. Also capable of turning a mast into a toothpick in the time it takes you to tell the dog to shut the hell up!
  11. Coming back to this as Allans helpful description contained this: “It is basically a groove in the lower edge of the garboard seats as well as the ends of the balance of planking as it rises up the post and stem.” Now as a newbie I have to find out what a garboard is. It’s often one deep rabbit hole just to understand one word. The definition for garboard will undoubtedly have some term that I will need to look up. It never ends. Hell, I have several glossaries bookmarked and still can’t tell you the difference between seizing and stropping.
  12. Well crud. I’m sure it was mentioned as a useful model tool. Guess not.
  13. Stupid thing came with no instructions. Does the end tighten any more than this? If not ‘‘twas a waste of money.
  14. Sorry all. Managed to find a scrap that I can use. Thanks for the offers.
