Norwegian Plastic
Everything posted by Norwegian Plastic
  1. Hi! Well, almost done. Need to make and shape some rope coils to go on the pins and lay up the sheets as it is when sailing.
  2. A little finishing left before I can put some paint on and install downlights and acrylic glass. Hope to have it finished next week so I can put the boat in a safe place.
  3. I finally found time to start building a show case, plans have changed… I am not a carpenter, but with some acrylic and paint I hope it will be presentable.
  4. Hei George. Jeg har enda ikke flyttet inn i nytt hus og er opptatt med snekring. Men om en måned....
  5. I have made a file for the Cricut and have a lot of adhesive paper. If you give me your adress i will cut all the masking you need for the main sail and snailmail them to you?
  6. I found out today that they are not telltales but ropes to tie the sail when reefed?
  7. Started to paint the main sail tonight. Made some masks from contact paper with the Cricut, put a generous layer of matte varnish to seal the edges and then a thin layer of Tamiya red.
  8. It will be a static model but able to sail. Believe I will sail it to get some cool pictures and a video and then it will be put in a glassed box built into the wall😂
  9. A little more sewing today, not overly happy with the result but bad boltropes are better than no boltropes…
