Lecrenb
Everything posted by Lecrenb
  1. Got the rudder installed this evening... Here they are ready to be fitted to the ship, with the bearing half and the quadrant. St. Roch carried a spare rudder on deck, the service rudder could be lifted onto the deck through the rudder well using tackle rigged to the main boom. This was usually done to prevent damage from the pack ice or when the ship was frozen in for the winter. The rudder is made from Ironbark (Australian gum) which does not float, hence the safety chain. These next pictures show the rudder in place, and the bearing clamped while the glue sets. The piece of solder is preventing the chain from falling through the well while its' retaining strap is glued in place on the deck. Here is the deck view with everything set in place, and a view down through the rudder well... Tomorrow I will shackle the steering chains to the quadrant and get that fixed in place along with the chain pulleys. Then I will complete the linkages. After some final paint touch ups on the hull she'll be ready for her display base.
  2. Got some more work done on the quadrant this evening... the first two picturres are parts of the original ship's plans from 1928. They show the rudder bearing and quadrant, the two parts I am working on now. One picture also shows the rudder stops and brake, which I will make once the linkages are done. Here is the quadrant test fitted to the rudder head. The upper chain channel is starting to take shape! Thanks for looking in! Bruce
  3. Greetings everyone, and for those who sent good thoughts for my new knee, thank you very much! The Cori-Robotic surgery was very successful, the full replacement took only 90 minutes and I had a spinal anesthetic, not a general. 4 hours later the feeling came back and they got me up on my pins and taking my first steps! I was in overnight to make sure everything was ok, then I walked out using only the cane! After a week I ditched the cane and was back walking the dog, about 1000 steps per day. The improvement is ongoing, and my second knee is scheduled for June 4! I have been able to negotiate the basement stairs for about a week now so I have been back at the St. Roch, working mainly on the steering linkages. The first two pictures are the alleyways either side of the deckhouse... I added the steps up to the doors and the covers for the steering chains. There are shackles under the covers connecting the chain from the steering wheel gypsy to the steel cables running aft. I used .015 diameter black thread to simulate 3/4" wire rope. I scratch built the four cable pulleys from styrene. Next I followed the original ship's plans to make the rudder bearing, which is bolted to the hull just forward of the rudder well. The bearing halves clamp the rudder post. The two steering cables are just set out of the way using the aft cleats. I have started making the rudder quadrant, as seen in the last picture. Again, I followed the ship's plans to make an accurate shape. The quadrant is designed for chains. On the prototype there are 'Z' channels following the arc of the quadrant, the chains sit in the channels and are shackled to the holes visible on the quadrant. I tried bending styrene channel but this was unsuccessful, so I'm making the channels from individual strips. There are chain pulleys guiding them out to the sides of the ship, where turnbuckles will connect them to the cables. I should be able to have the linkages complete shortly. I think at that point I will permanently mount the ship onto its' display base. Thanks for looking in!
  4. Thanks Alan! Yes, it is supposed to be a smaller incision and more precise placement of the prosthetic... they do expect me to be up and moving as soon as I'm fully awake!
  5. George, glad you found a method that works for you! Probably find plenty more parrels at the bottom of every water hazard! Regards, Bruce
  6. Thanks Keith... they tell me I'll be taking first steps as soon as the anesthetic wears off! The water would freeze pretty fast in an Arctic winter, -40 highs are common. I'm thinking they likely drained it and manually flushed from a pail??
  7. The deck house structures are complete... here is the lobby, head, and wireless office before attaching to the ship. The unit on top of the head is marked as "sanitary service tank" on the plans, and photos confirm it is there... not sure what was in the tank. If it was water for flushing how would the crew keep it from freezing? Another conundrum to add to the list! I used glass beads from the craft store to make the aerial insulators. The aerials are only attached when the main sail is down, and when the ship is getting ready for a scheduled contact, there was no power for the radio unless the auxiliary engine was running. In the 1930s she carried a low frequency morse code (wireless telegraphy) transmitter and receiver. The original insulators had to have passed through the main deck, which made them prone to damage, and would be a shock hazard. This may be the reason the office was moved to the upper deck. There are differences in the doors, explained by the fact the wheelhouse and wireless office are new structures. Plans and photos show portholes only in the lobby and head doors. Here's what it looks like when it is all put together. I have started work on the steering linkage to the rudder, but I may re-make my pulleys as they look a bit out of scale, we'll see how they clean up... Thanks again one and all for looking in and for your comments. This will be my last posting for a while as we are visiting family, then I am getting a new knee next week! The surgeon is one of the few in Alberta to use the Cori-robotic system and I am really looking forward to the procedure! Happy Easter! Bruce
  8. The rear structure framing is complete... behind the lobby and head is the wireless office relocated from the lower deck. The ventilators and galley stack are installed... leaving room for the main boom that passes across the top of the deckhouse. The aft structure is painted and the roof set on to check fit. The lobby and head are original and retained the 1928 stained and varnished finish, The rest of the new deckhouse is white. Here is the ship sitting on the display base, just seeing how it looks for now. I'm making the doors and windows for the aft structure, then time for some paint touch up and a few more small parts then the hull is basically complete! Next up will be the rudder and steering gear, followed by the boat platforms and davits. Thanks for looking in! Bruce
  9. Well, if it was me, I know I could not replicate the scroll work with any hope of fidelity to the original. I would take a picture straight on, or manipulate one with photo shop to appear straight on, then size it to model scale. Then I would make a negative of the picture and send it to a shop that does electronic circuit boards or brass photo etching. You will end up with accurate scrollwork in copper or brass on a substrate. The substrate can be painted and become part of your head timbers. Best of luck! Regards, Bruce
  10. I have achieved Deckhouse! Before fastening the roof I placed the builder's plaque... made from a picture of the original. My historic photos are in black and white, and show a greyish roof. St. Roch had a limited colour palette so I mixed a bit of green into the grey, as if this surface was canvas covered and sealed like the hatch covers and companion roof. Moving right along... I started framing the structure behind the deckhouse. This is original to the ship and was not replaced when the deckhouse was enlarged in 1930. To the left is the lobby leading to the lower deck. To the right is the head. It is 2 feet lower because there is no clerestory underneath. Once this is finished there are some ventilators and gew-gaws (a nautical term for fiddly bits, eh) to put on, then I will move on to the wireless office and steering gear. I hope you like my ship so far! Bruce
  11. The deckhouse is getting close now... The bay window is installed... The wheelhouse roof frame is installed... Here is the roof roughed in to check the fit... While paint and glue were drying I made the rest of the fiddly bits for the poop... Once the goosenecks and ring bolts are installed there will be some paint touch up on the hull, then finally the deckhouse gets installed! I am thinking good thoughts about installing the ship on the display base at that point... but I may wait... The rudder and quadrant mechanisms can go on any time, and the structures behind the deckhouse can be built. After that the lifeboat platforms and davits can be built, the spare rudder and steering cables installed, and the masts stepped! Woot! Love it when a plan comes together! Thanks for checking in! Bruce
  12. ok, sounds good. You can find me on facebook or messenger... Bruce LeCren
  13. We will be in Paris for a brief time in August... a Viking river cruise. not a lot of free time, but if you are available perhaps we could meet?
  14. Wow! Very impressive! You set a high bar, one I will strive for! Regards, Bruce
  15. Feeling ambitious, so I got the lower frame of the bay window together... it is test fit in place so the corners will be accurate once the glue dries. O yeah... I made and installed the ship's clock... It is from a picture I took of St. Roch's clock, that I reduced to 3/16" (9 scale inches). Our printer does a very good job of retaining details, even at that size. The face is glued to a short piece of styrene tube that I coloured with a Sharpie (no drying time required)! Here is the picture of the actual clock... The compass card was an on line photo that reduced to 1/8", and I was surprised the details of the rose remained! Good night all!
  16. Well, the binnacle is completed and installed... The picture is my lathe setup to slice the groove for the lantern's chimney. I set the binnacle into the tool post and mounted that on my vertical slide. This lets me adjust the position of the binnacle in three axes so the groove goes straight down the side of the dome. I used the same setup to drill the recess for the compass card, but offset the binnacle. The next picture is the top view of the wheelhouse with the binnacle installed. Note the chimney and the compass card. I did not want just a brass recess, even though details on the card will not be visible your eyes will see something in there, and "fill in the blanks". Here's what it looks like through the side window... Next I have to make the bay window across the front. From photos this appears to be one window with three panes, rather than three windows. I have roughed out the roof so fitting the window should be a bit easier... I hope! Thanks for looking in! Bruce
  17. LOL Alan! My wife's makeup tweezers are wonderful things... don't tell her though!
  18. So far, so good... now to finish shaping the pedestal portion, then I can cut in the viewing glass and lantern chimney...
